Shoeshine Boy a mild mannered TJ build - Page 3 - JeepForum.com
post #31 of 115 Old 11-20-2010, 01:16 PM Thread Starter
balzer
OH I'm glad I took this pic! Looks like I need to grab some zip ties and better secure my amp battery cable! Goes to show a good once over is a good idea every once in a while.
balzer is offline
post #32 of 115 Old 11-20-2010, 01:35 PM
Colockum
Originally Posted by balzer View Post
LMFAO curious that most my damage is on the pass side! Maybe I need to learn better "proximity awareness" LMFAO
No that just means your a righty. Most of my damage is on the left hand side so I am a lefty. If you look at a lot of off road rigs that are consistency driven by the same person one side will typically have more damage.
Nice Wrangler by the way. Glad to see another person who is not afraid of dents and dirt. cheers2:
2004 TJ
Not locked or loaded... yet
Colockum is offline
post #33 of 115 Old 11-20-2010, 03:58 PM
Sgt.Fuzz
Jeep looks good. I too am eyeing the S-Pod. It's such a clean install.
My build:
Sgt.Fuzz is offline
post #34 of 115 Old 11-20-2010, 04:05 PM
xWhite420wIDOWx
1967 CJ5
Nice TJ...
xWhite420wIDOWx is offline
post #35 of 115 Old 11-28-2010, 10:42 AM Thread Starter
balzer
Thanks for the compliments guys!
I started on an ammo can console but for some reason I just cannot find my die grinder to cut the slot for the e-brake handle to come through.
So for now, the can is in there and the brake is not. Since I have an automatic I am not worried about the brake for a little while.
Im not exactly sure what the ammo can was for, its as tall and wide as a 20mm box but not as long and it was completely lined with foam. Its about perfect for what I want though.
I dont have pics yet either bcuz right now its just a green box bolted down in my jeep. I plan on making an arm rest pad and some sort of lock. I plan on boxing off the e-brake inside then add some pockets. I will paint it grey to match the interior.
balzer is offline
post #36 of 115 Old 11-29-2010, 08:40 PM Thread Starter
balzer
So trying to do the ammo can console, apparently my die grinder has gone walkabout. So today I splurged on myself and went and bought the biggest Dremel tool set that my local ace hardware had. I got the Dremel 4000 set and a big set of bits to go along with it.
With that, I came home, and was able to cut the necessary holes in the ammo can. So now I have a functional console and e-brake. I still need to make an arm rest pad, and inside dividers, paint the can, figure out a lock, and try to find some sort of material for the e-brake handle opening. I would love the "whisker biscuit" like the transfer case shifter has. Not sure where I would get it or how I would mount it. Ill get to that later. Its solid and roomy and just what I needed the glove box is just too small for the owners manual, legal documents and my ipod and adapter harness.
Thanks for looking!
balzer is offline
post #37 of 115 Old 11-29-2010, 09:02 PM
JeeperCreeper94
Thanks for looking!
Any pics of the finished product?
1999 WJ 4" IRO, Cb, Baja Racing Lights, 31" Treadrights
JeeperCreeper94 is offline
post #38 of 115 Old 11-29-2010, 09:08 PM Thread Starter
balzer
Well it isn't finished but I will try to go get some pics of it so far!
Too dark right now sorry...
I will get some tomorrow
balzer is offline
post #39 of 115 Old 12-25-2010, 02:13 AM Thread Starter
balzer
Sorry I don't have more pics of stuff my camera is just not happy and doesn't want to focus anymore. I did get the arm rest pad for the ammo can made and installed. I finally installed my CB and antenna (I've had it for almost 2 months just sitting in my house lol) Its a small midland 40 channel, I mounted it on top of the dash far left side between the a pillar and the gauges. And a Wilson trucker antenna, I welded on a mount top dead center of my tire swing out for the antenna.
Then we had our family Christmas tonight (Christmas eve) since my bro was here. He got me a slime brand pro power air compressor! Might not be the greatest but its better than nothing. I have a air tank around here somewhere and will probably mount the compressor and air tank and see it it lasts. If the compressor doesn't last i will at least have most everything already there and will be able to swap out the compressor. But all the reviews I can find online for it are positive, so that's a good sign!
I guess its phone pics for a while! I quit my job Nov 30th so budget has become non existant. I thought I had another job before I quit but it fell through on me.
balzer is offline
post #40 of 115 Old 12-27-2010, 02:28 PM Thread Starter
balzer
OK so some pics and update
got my CB finally installed
Made a mount for the antenna but its too cold to paint so it will have to be rusty until spring. this cold weather would just make a big booger
Got some pics of the ammo can console I cut it out with a dremel and made the pad out of a board some foam and some gray canvas like fabric.
Just a few pics of some snow wheeling
and a sneak peek of one of the next mods
slime pro power compressor 2.5 gal air tank and a REALLY loud air horn
balzer is offline
post #41 of 115 Old 12-27-2010, 06:22 PM Thread Starter
balzer
balzer is offline
post #42 of 115 Old 02-19-2011, 09:32 AM Thread Starter
balzer
Ordered a UCF ultra high clearance skid plate in 1/4" alum. Also got some 1" tapered spacers from UCF. My hope is that I can run the skid plate and the spacers until I can afford a SYE, CV rear shaft, and adjustable rear control arms. Then I can hopefully remove the spacers and hammer the floor up a bit to clear the transfer case. I do not want to run a body lift if I can avoid it.
I highly recommend calling Matt at under cover fab if you want to rid your jeep of the factory snag they call a skid plate.
I also remover the front drive shaft and took it to have the CV rebuilt. Local guy who specializes in drive shafts did it for $110.
I have the drive shaft back now but will wait for the skid plate to come in to install both at the same time.
When I had the factory skid plate off to remove the drive shaft I noticed the bottom of the frame, especially around the nutserts had quite a bit of rust. When I take it off again I will be sure to wire wheel the rust and put a few heavy coats of paint under there and hopefully kill the rust before it gets bad.
I will try to take pics when I do the install.
balzer is offline
post #43 of 115 Old 02-25-2011, 12:36 AM Thread Starter
balzer
I just ordered a 1" body lift and a 1" MML. I didn't want one initially, but It will make room for the tummy tuck and I plan on a savvy gas tank skid.
So I have come around to thinking the benefits of the body lift out weigh the cons.
I have a goal in mind now. I am focusing on making more clearance under my jeep and to shed as much weight as I can.
My next few purchases will be, in no particular order...
-Savvy gas tank skid
-UCF alum winch plate
-synthetic winchline
-alum hawse flairlead
balzer is offline
post #44 of 115 Old 02-25-2011, 11:14 AM
kevlarr
great build thread thanks. I am eager to see where you go with the lift. I have also been researching for a few months to get the right lift for me. I wheel some but mostly for hunting and fishing and want to have enough but not too much. Which for me too much is when you have to change a gang of other stuff because you changed the geometry too much. I think a 3" spring and a 1 1/2 BL are the combo with a slip yoke eliminator. And maybe some adjustable arms as needed. Maybe Zone maybe BDS not sure yet. What are you thinking for lift ?
kevlarr is offline
post #45 of 115 Old 02-25-2011, 02:27 PM Thread Starter
balzer
It actually has about 2.5" of unknown lift when I bought it. I think it has settled down to around 2" or maybe even A bit less. My friend has a stock 03 and according to a flat parking lot and a tape to the bottom of the rockers I am exactly 3" taller than him.
He has no lift and 30x9.50x15's and I have the 31x10.50x15's Thats a very poor way to measure lift due to different brand tires measure differently. It doesnt look like I have much lift because the bushwacker pocket flairs actually hinder clearance. (my theory)
However to answer your question I may upgrade to a old man emu 2.5"HD lift some time in the future. But For now I am more focused on other upgrades. I would like to get currie control arms, antirock sway bar, SYE and CV Dshaft, savvy gas tank skid etc. then I will look into different springs. Basically springs are near the bottom of my list. HOWEVER if they continue to sag I may have to look into them sooner.
balzer is offline
98 XJ Mild Build (Documentation) yingpin Jeep Builds 52 09-10-2010 10:18 AM
TJ SAHARA mild build Dog Man Jeep Builds 15 01-07-2009 06:15 PM
well, another 97 SE mild build up cmorganf64 Jeep Builds 14 12-08-2007 06:21 PM
