ShadowNWPA 91ish YJ Build Thread - Page 3 - JeepForum.com
 1Likes
post #31 of 207 Old 12-22-2013, 07:19 PM Thread Starter
Shadownwpa
While I was waiting on the TC to be repaired I started on the other stuff. It followed the same logic as when the frame was nice I wanted a nice tub.. well when the tub was nice I wanted a nice interior. The dash was scrubbed, degreased, and painted along with the door panels, speaker pods, and anything else inside that was ugly and faded. I used some vinyl/plastic paint that Autozone happened to have the wrong price on (-$2/can ) and some adhesion promoter. Rope and bits of wire hangers are a great help in keeping the crud off the parts while painting.
When I went to install the speakers I found that neither pairs of marine speakers would fit in the roll bar pods or the centerpod. So I went back to autozone and picked up some cheap ones I won't be too upset about getting wet.
When installing the door panels I found the pull handles to be unacceptable. I had painted them with the rest of the stuff but they looked like crap so I pitched them in the spare parts pile. New ones were made out of some aluminum strap I picked up at Tractor Supply. I used a hammer, cutoff wheel, a drill, and a vise to shape them, then a piece of 120 grit sandpaper to make them look nice getting all the tool marks out.
Shadownwpa is offline
post #32 of 207 Old 12-22-2013, 07:30 PM
Gage56
Looks Sweet i love the color
Btw you looking to get rid of the carpeting ??
1992 YJ
Gage56 is offline
post #33 of 207 Old 12-22-2013, 09:37 PM
JeepaholicNinja
Looks awesome! I'll never be able to understand how people can take on projects with so much rust! And I live in Maine! Nice work, though. Makes me want to learn to weld...
2000 Cherokee Classic
3" Zone lift, THULE roof rack, Hella 500 Black Magics
JeepaholicNinja is offline
post #34 of 207 Old 12-22-2013, 09:47 PM
daddyjeep87
1987 YJ Wrangler
Painting parts outside on the first day of winter in Pa, something not right about that.
87YJ 5.2/46RH/NP231 D44/9in 4.56 4 link rear, radius arm front
My Build
Start planning for 2014, updated site http://www.bantamjeepfestival.com/
daddyjeep87 is offline
post #35 of 207 Old 12-23-2013, 05:26 AM Thread Starter
Shadownwpa
This was done over the summer. I'm just now putting together the build thread. Unless you mean the patching I did last winter... That was primered to keep the surface rust off and I threw it out anyways.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
post #36 of 207 Old 12-23-2013, 05:27 AM Thread Starter
Shadownwpa
Thanks, and the carpet found its way into a garbage can at Bantam.
post #37 of 207 Old 12-23-2013, 05:30 AM Thread Starter
Shadownwpa
Rusty is ok as long as its cheap, and welding isn't hard to get the hang of once you get past the idea of enough electricity to kill you making molten metal inches from your fingers.
post #38 of 207 Old 12-23-2013, 06:14 AM
mike_breaker_5
how have i missed this build! i suddenly feel like less of a man for buying a new frame iinstead of continuing to cut and weld chunks of steel back to it.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #39 of 207 Old 12-23-2013, 11:58 AM
The_Goob
Hell on Wheels
The_Goob's Avatar
I know me too. Since I know hes done i keep waiting for updates, looking good so far!
-April '14- YJoTM- June '15]
The_Goob is online now
post #40 of 207 Old 12-23-2013, 01:22 PM Thread Starter
Shadownwpa
Thanks, it's not done yet though. I Just can't do any more work on it for a bit because of a project I'm inspecting out of town. I'll probably put up more tonight.
post #41 of 207 Old 12-23-2013, 02:07 PM
JeepaholicNinja
We'll be waiting
post #42 of 207 Old 12-23-2013, 06:20 PM Thread Starter
Shadownwpa
After the rocker plates were put together I started on the front bumper. It will eventually have a bumper on it, but there's other things higher on the list. I started with a piece of 3"x4"x3/16 wall square tube. I cut it to I think 52" so it would be wide enough to keep some of the trees out from between the tires and the frame. The clevis mounts are 1"x2.5" bar stock that I got my dad to mill the outer radius and 7/8" (or 3/4 maybe) hole into with the Bridgeport. I have 4 altogether, two for the front and two for the back bumper. I measured and marked the inner and outer surfaces of the front end of the frame rail, then measured to center the bumper. I kinda designed it as I went, so the pictures will have to tell some of the story. holes were cut with a cutting wheel/grinder in the front and back of the bumper for each clevis point. I welded them front and back with 1/4"ish fillets. The bumper was angled back on the sides by cutting a wedge shaped notch into the back side tapering as it went to the front face of the tube, then heated them up and bent, tacking and welding them when they were equal. The welds were ground flush. For mounting i made two 1/2" thick plates with 4 holes laid out in each. I tacked them to the back of the bumper then drilled through to the front (on the Bridgeport... useful machine that one) in the tap size for a 1/2" bolt. Then I ran a tap through each of the 8 holes ... another awesome toy in Dad's garage is a pneumatic tapper on an arm mounted to the Bridgeport. Then I drilled the front holes out to 1/2", bolts were installed and the tacks were ground out. Then I ground the frame ends clean and welded the 1/2" threaded plates to the frame. Somewhere in there i decided to make an angle cut on the ends and made a plate with a hole to hold an amber marker/turn signal 3/4" LED light.
post #43 of 207 Old 12-23-2013, 06:26 PM Thread Starter
Shadownwpa
More bumper pics...
I guess that's alot of pics for a bumper but I like how it turned out. Next update will probably be about tube fenders when I get to it.
post #44 of 207 Old 12-23-2013, 07:49 PM
mike_breaker_5
you just helped me solve how i am going to mount my front bumper when i fabricate it.
post #45 of 207 Old 12-23-2013, 10:21 PM
daddyjeep87
1987 YJ Wrangler
Agreed, That is a very simple yet very stout attachment. I may consider welding a nut to the bumper and running a bolt in from the back side instead of having bolts exposed from the front. Just my preference, not saying there is anything wrong with the exposed bolts.
My Build
