SH00T3R's Build - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SH00T3R's Build
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 09-18-2013, 06:25 PM   #76
SH00T3R
SH00T3R's Avatar
1987 YJ Wrangler
So im still a rookie at this whole engine thing, so can somebody tell me whats the big difference between these motor mounts? To me it looks like the Novak ones are more adjustable...
Advance Adapters kit $156.00
http://www.advanceadapters.com/produ...ine-mount-kit/
Novak Kit $229.00
http://www.novak-adapt.com/catalog/e...ts/mmx-wd1.htm
SH00T3R's BUILD
SH00T3R is offline   Reply With Quote Quick reply to this message
Unread 09-18-2013, 07:04 PM   #77
skyj
Novak Kit $229.00
I am no expert but I see nothing wrong with the advanced adapter mounts they are both adjustable novak is just a little more, but at $70 more than AA I would go the AA route. I plan to make mine using the grand cherokee mounts and some 1/4 steel. One thing with your durango motor if I were you I would switch over to the grand cherokee power steering mount Durango and Ram pushed it so far out there that it will interfere with your steering shaft. The cherokee one sucks it in up close to the motor, just some food for thought.
build thread: http://www.jeepforum.com/forum/f22/skyj-eccentric-build-1467426/ '90 YJ 5.2 magnum MPI, AX15, NP231 SYE, Dana 30 4.56 open/ 8.8 4.56 detriot locker. 1" shackles
skyj is offline   Reply With Quote Quick reply to this message
Unread 09-18-2013, 07:32 PM   #78
SH00T3R
SH00T3R's Avatar
1987 YJ Wrangler
Ah I didnt know that, Thanks! Ill look into it.
SH00T3R's BUILD
Unread 09-18-2013, 08:20 PM   #79
skyj
Yeah download the pdf file click next to the icon on AA Site its right next to the photo of the mounts and it explains it in the file how they work.
Unread 09-19-2013, 04:17 AM   #80
94jeepman
2005 WK
im doing a v8 swap now also tho its not mopar its chevy but I got the truck for 1000 with 90k on motor and everything is there plus I got full sized axles
[CENTER] [URL="http://www.jeepforum.com/forum/f67/just-another-build-thread-1845953/"][SIZE="5"][COLOR="BLUE"][B][U]The WK Build[/U][/B][/COLOR][/SIZE][/URL][/CENTER]
[CENTER][B]KHAKI MEMBER #59[/B][/CENTER]
[CENTER][URL="http://www.jeepforum.com/forum/f22/my-yj-build-1810273/"][SIZE="5"][COLOR="Red"][B][U]YJ Build[/U][/B][/COLOR][/SIZE][/URL][/CENTER]
[B]The WK mods[/B]: SC flashpaq 3870, flow master super 40, 3.5" X Factor leveling kit, 33" M/T baja claws, 17" pro comp wheels, one 12 inch subwoofer, rugged ridge tailight gaurds, rola rack with 18" extension
94jeepman is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 10:17 PM   #81
SH00T3R
SH00T3R's Avatar
1987 YJ Wrangler
Well tonight I ground down the old I6 mounts. Hopefully I'll be able to order the new mounts this weekend of not early next week. Its slowly coming along!
SH00T3R's BUILD
Unread 09-19-2013, 10:40 PM   #82
Sparrows
Booking right along! I wanna help lol!
Cheers
[URL="http://www.jeepforum.com/forum/f22/warbird-2-a-2242713/"][size=3][b]WARBIRD 2[/size][/b][/URL]
[URL="www.exiledoffroad.com"][size=2][b]EXILED OFFROAD[/size][/b][/URL]
[size=2][b]June '13 YJOTM[/size][/b]
Sparrows is offline   Reply With Quote Quick reply to this message
Unread 09-19-2013, 10:53 PM   #83
SH00T3R
SH00T3R's Avatar
1987 YJ Wrangler
Cheers
Thanks! Im gunna need the help here soon. lol Still haven't figured out how or who im going to have weld in my new mounts but I did see MoparFreak is super good at welding... cough cough hint hint lol
I also need to find a fly wheel (130 tooth I think) and a bell housing.
Id also like to clean the new V8 up a bit after seeing others all painted up. Ah man and the list goes on. and on. and on....
SH00T3R's BUILD
Unread 09-19-2013, 11:39 PM   #84
skyj
Yeah I just spent the night degreasing my motor I think tomorrow I will take it to the car wash snd hit it with the pressure washer/degreaser. Good luck looking good as always bud.
Unread 09-20-2013, 09:23 AM   #85
bmgadg
Novak Kit $229.00
Keep it simple (and cheaper) and go with AA.
My v8 YJ Build Thread
bmgadg is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 09:25 AM   #86
bmgadg
x2 on this. I couldn't even get the motor to fit with the Dodge power steering pump hitting the frame. It was necessary to go with a cherokee pump and mounting bracket in my case.
Unread 09-20-2013, 11:07 AM   #87
SH00T3R
SH00T3R's Avatar
1987 YJ Wrangler
Do I need to swap the pump also or can I just snag a bracket?
SH00T3R's BUILD
Unread 09-20-2013, 11:49 AM   #88
skyj
Here is s shot of my cherokee pump. Hope this helps if not you could always call auto parts store and ask if they have they share same part number. Mine needs a new reservoir the po broke off the return nipple pulling the motor out.
Unread 09-20-2013, 11:49 AM   #89
bmgadg
Hmmm good question. I can't remember what the old pump had for mounting holes. Give me till this evening and I'll look at my setup. Seems like the cherokee pump mounts to a small bracket that mounts to the right side head.
Unread 09-20-2013, 11:52 AM   #90
skyj
Correct here is the cherokee bracket.
