SH00T3R's Build - Page 12 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > SH00T3R's Build
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-04-2013, 07:47 PM   #166
SH00T3R
1987 YJ Wrangler
Originally Posted by skyj View Post
The motor mounts along wont hold it up in the back you will need something to support it.
Support the motor itself? I was thinking about just the motor without the transmission and install the tranny after I get my flywheel and clutch.
Im probably just getting ahead of myself and extremely impatient.
[URL=http://www.jeepforum.com/forum/f22/sh00t3rs-build-1572370/][COLOR="DarkRed"][SIZE="4"][FONT="Verdana"][B]SH00T3R's BUILD[/B][/FONT][/SIZE][/COLOR][/URL]
[url=http://www.exiledoffroad.com][B][SIZE="4"][FONT="Verdana"][B]EXILED OFFROAD[/B][/FONT][/SIZE][/B][/url]
”When you want to succeed as bad as you want to breathe, then you’ll be successful.”
SH00T3R is offline   Reply With Quote Quick reply to this message
Unread 12-04-2013, 08:11 PM   #167
skyj
Its a pain to install the trans with the motor already in there. Im with ya there on being impatient I cant stand it but dont want to pull the 4.2 until I have just a few more things.
build thread: http://www.jeepforum.com/forum/f22/skyj-eccentric-build-1467426/ '90 YJ 5.2 magnum MPI, AX15, NP231 SYE, Dana 30 4.56 open/ 8.8 4.56 detriot locker. 1" shackles
skyj is online now   Reply With Quote Quick reply to this message
Unread 12-05-2013, 01:26 PM   #168
94jeepman
2005 WK
I'd how you mounted you motor bit I left enough room between the motor and fire wall so tyranny install would be easier. Then I mounted the motor and got all the wiring done before I installed the tranny
[CENTER] [URL="http://www.jeepforum.com/forum/f67/just-another-build-thread-1845953/"][SIZE="5"][COLOR="BLUE"][B][U]The WK Build[/U][/B][/COLOR][/SIZE][/URL][/CENTER]
[CENTER][B]KHAKI MEMBER #59[/B][/CENTER]
[CENTER][URL="http://www.jeepforum.com/forum/f22/my-yj-build-1810273/"][SIZE="5"][COLOR="Red"][B][U]YJ Build[/U][/B][/COLOR][/SIZE][/URL][/CENTER]
[B]The WK mods[/B]: SC flashpaq 3870, flow master super 40, 3.5" X Factor leveling kit, 33" M/T baja claws, 17" pro comp wheels, one 12 inch subwoofer, rugged ridge tailight gaurds, rola rack with 18" extension
94jeepman is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 02:03 PM   #169
bmgadg
If you put the motor in without a trans you'll have to prop up the back with a jack stand and some wood. I would wait and put the whole drivetrain in at once if I were you. It'll be easier that way.
My v8 YJ Build Thread
bmgadg is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 05:29 PM   #170
The_Goob
Hell on Wheels
The_Goob's Avatar
the 1 time I ever pulled and installed a motor we unbolted the tranny and left it in the truck. worst decision ever. for whatever reason, it was a nightmare to realign them and I garbled the torque converter threads. granted I was 16 and doing in a backyard without proper tools and guidance. if you have an extra set of hands and proper lifts and whatnot I imagine its doable.
Waiting for parts does suck, Ive got 2 in the mail and several more to buy still.
The_Goob is online now   Reply With Quote Quick reply to this message
Unread 12-09-2013, 09:10 PM   #171
SH00T3R
1987 YJ Wrangler
HAHA yeah the backyard stuff gets hard. So you guys have convinced me to wait. I have a Flywheel on the way and I'm ordering a clutch hopefully this week.
Now the question is.. I see there are options for 10.5" or an 11" clutch. Im unsure on which one to order. Morparfreak advised me to go with the 11" but the 10.5" is cheeper. I think they should both bolt up to the flywheel.
Suggestions, GO!
Unread 12-10-2013, 11:53 AM   #172
pineda22
Suggestions, GO!
what is recommended for the flywheel? if you canchoose between the 10.5" or the 11" i really dont know that you would notice the .5" difference as far as driving but one could make the arguement the you would have more surface area with the 11" making it last slightly longer its been a while since ive done a clutch in anything small haha however we just switched from cheap clutches to ceramic ones here at work for our semi trucks (14" clutches haha) and altho pricy well worth the extra $ as far as wear and heat displacement the cremaic is the way to go for shure! i say get what you can afford now especally since clutches are something youll end up replacing sooner or later anyway maybe talk to someone running a simular setup and see how they like or hate it and go from that
[COLOR="Yellow"]/l[/COLOR] ,[____],
l---L [COLOR="DarkOrange"]-[/COLOR]OlllllllO[COLOR="darkorange"]-
[/COLOR][COLOR="Silver"]()[/COLOR]_)-[COLOR="Silver"]()[/COLOR]_)-[COLOR="Yellow"]o[/COLOR]-)_)
If it dont fit.....force it. if it breaks.....it needed replaced anyway
pineda22 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 05:02 PM   #173
SH00T3R
1987 YJ Wrangler
Well guys!!! Got a christmas present early from my wife, My flywheel!
Unread 12-11-2013, 05:42 PM   #174
The_Goob
Hell on Wheels
The_Goob's Avatar
Nice score.
This thread needs more SHOOTER
Unread 12-11-2013, 05:48 PM   #175
SH00T3R
1987 YJ Wrangler
My clutch is on its way from Nevada so it should be here in a couple days and I can begin putting everything together. I was able to do what I wanted and got a new clutch and flywheel for the new engine. Going to be sweet!!
EDIT:
I Got my clutch today and ended up with the wrong kit… I got a 23 spline when I need the 10 spline. I was so excited to start assembling everything and hit this speed bump.
I drove across town to get a pilot bearing thinking id get it put together tonight. ARG!
Unread 12-13-2013, 08:14 PM   #176
SH00T3R
1987 YJ Wrangler
Well I finally got my JF stickers on. I guess sticker, I have 2 more but I haven't decided where I want em. Thanks Anticanman!
And another side note, Iv been running. ALOT! 5 miles in 45 min. Could have gotten it in 40min but was kinda feeling under the weather today.
Unread 12-13-2013, 11:52 PM   #177
wjidaho
Well I finally got my JF stickers on. I guess sticker, I have 2 more but I haven't decided where I want em. Thanks Anticanman! And another side note, Iv been running. ALOT! 5 miles in 45 min. Could have gotten it in 40min but was kinda feeling under the weather today.
Haha me too tonight
[SIZE="4"][url=http://www.exiledoffroad.com]EXILED OFFROAD[/url][/SIZE]
My build thread
[url]http://www.jeepforum.com/forum/f22/wjidahos-expedition-build-1904282/[/url]
wjidaho is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 05:22 PM   #178
SH00T3R
1987 YJ Wrangler
Well I received the wrong clutch again on monday. I talked with Summits customer service and the said they will call me the following day with more information. No call… I called them again today and got things sorted out. I have another (3rd) on the way and it should be here on tuesday. I still think its the wrong one again but i'll give it a try if they say so. I told them what I want and what I need so we shall see.
I don't think Ill order from them again.
Unread 12-20-2013, 05:36 PM   #179
skyj
Damn!! I hope they get it sorted out for ya. I have yet to bolt mine all together to see if it all fits. Soon, soon. Got to get my 4.2 pulled so I can get it sold.
Unread 12-26-2013, 02:30 PM   #180
SH00T3R
1987 YJ Wrangler
I Finally got the right clutch kit on tuesday and got the monster in this morning. I Dont have it wired or anything yet as I still have allot of parts to gather up but its crazy to have an engine back in the Jeep. The best part of it is that my wife helped me out.
Some parts I still need to gather.
-Fuel pump with lines (I know where one is at I just gotta pick it up)
-Headers
Heres some pics.
Its weird to see the Jeep bear the weight of the engine without the hoist.
