Second chance xj - JeepForum.com
post #1 of 11 Old 01-15-2016, 06:35 PM Thread Starter
liftedlongarmzj
Second chance xj
This is my second xj bought a 4 door first but always wanted a 2 door found this 96 xj 2 door 5 speed clean with no rust but had a blown head gasket and is two wheel drive so the work begins replaced cylinder head and gasket now running good rounded up a hp30 for the front with 3.55 gears and a 231 t-case also acquired a set of 33x12.5r15 waiting on the 4.5 rc lift kit to show up
liftedlongarmzj is offline
post #2 of 11 Old 01-19-2016, 07:20 PM Thread Starter
liftedlongarmzj
Slow progress with Ohio winter weather rc 4.5 lift kit showed up today hopefully I will get a break in the weather to put it on and I'm picking up the front bumper Saturday
post #3 of 11 Old 01-20-2016, 02:14 PM
lucious
Nice a friend did a similar build and it turned out awesome. started with a stock 2wd auto xj and when finished had a 4wd manual xj with a 6in lift and 33's
lucious is offline
post #4 of 11 Old 01-20-2016, 05:35 PM Thread Starter
liftedlongarmzj
Thanks. It's hard to find a 4wd xj that's not all rusted out here in Ohio I would rather do the work converting it to 4wd than rust repair
post #5 of 11 Old 01-20-2016, 07:50 PM
b16gsr
sounds like the start of a nice rig
1998 Jeep Cherokee 4X4 2 door
b16gsr is offline
post #6 of 11 Old 01-21-2016, 12:17 AM
JeremyatKOR
WWW.KRAWLOFF-ROAD.COM
JeremyatKOR's Avatar
That is a really clean XJ. I really enjoyed my buddy's Jeep. They are great vehicles.
Jeremy
Sent from my XT1254 using Tapatalk
Want It? We Got It!!
JeremyatKOR is offline
post #7 of 11 Old 01-21-2016, 05:18 PM
ForeverMackin29
1995 XJ Cherokee
I couldn't agree with you more! I have a 2 door XJ 4x4 and have spent many many many hours cutting out rust. I am now in the middle of replacing the rear cargo pan. If ever you get hung up on your 2WD to 4WD conversion, just take a look at my build thread and it will instantly make you feel better haha! Excited to see where you take this build
ForeverMackin29 is offline
post #8 of 11 Old 01-24-2016, 01:17 PM Thread Starter
liftedlongarmzj
I appreciate all comments starting to clean up my axles and I found rust on my front axle near the shock mount my question is can I cut it out and do away with it or does it serve a purpose there is a spot were the coil spring sits I will fix
IMG_20160124_130716347.jpg   IMG_20160124_130724850_HDR.jpg   IMG_20160124_130732168_HDR.jpg
post #9 of 11 Old 02-20-2016, 11:34 AM Thread Starter
liftedlongarmzj
It's been awhile since my last post after finding a lot of rust on the axles I was going to use I decided to go full-size axles Dana 44 Dana 60 with 4.10 gears after some research ordered all the brackets to make it happen should have all the welding done this weekend and I can finally see it lifted still have alot of work to do but getting there
post #10 of 11 Old 05-14-2016, 04:52 PM Thread Starter
liftedlongarmzj
Finally progress axles cleaned and ready to go get the new brackets welded on
post #11 of 11 Old 05-17-2016, 09:07 PM Thread Starter
liftedlongarmzj
More progress rear leaf springs are built lift shackles installed just picked up the rear axle from the shop with the new brackets welded on now I can get it cleaned up and painted hopefully get it installed with the front axle this weekend
