Scott and yet another LJ build - JeepForum.com
post #1 of 7 Old 05-24-2012, 05:31 PM Thread Starter
Scottt
Scotts LJ build up
Everyone is doing it, so why not me too?
Plus, it should give me some good documents of my progress over the months and years.
I’m not going to go into great detail, so if you have comments or questions, please post up.
I have been without a Jeep for the last 6 years. Now that my kids are older, it’s time to get another. This one is going to be more family friendly than my last YJ on tons. I need to make it capable, yet fun for the family to get around in. I decided a two door LJ Rubicon would be a good place to start. Plenty of room for the kids, locked up front and back and a 4:1 T-case, perfect. I decided to get an automatic so my wife could enjoy it too.
After shopping around a while, I found this one in Dallas. Three days later it was in my drive. It has a few good items to get me started. From best I can tell, it has a 3.5 RE LA lift, crappy 33’s, a winch, solid rear bumper with a tire carrier and sliders.
This is how it started.
Scottt is offline
post #2 of 7 Old 05-24-2012, 06:04 PM Thread Starter
Scottt
Fist I needed to do a little maintenance on the Jeep. It had a left rear axle seal leak that needed to be fixed. Done.
Then I moved to the next issue, worn out shocks. But along the way someone decided to weld on new lower shock mounts, wtf? So for the time being, I cut the extra mounts off, and trimmed the lower bucket to keep them from rubbing. At some point down the road I will look at outboarding or dealing with them another way, but for now this will work fine. It will be nice to get the right shock back in the rear too. What were they thinking??
I replaced the Rancho 9000's with Doetsch Baja Ryders
Scottt is offline
post #3 of 7 Old 05-24-2012, 06:45 PM Thread Starter
Scottt
Next is a new radio with an ipod plug and new speakers, whoopie, no big thing. 4 new polk 5.25 speakers and a sony xploid deck with the factory sub. It sounds good enough for me. Done
Next comes new shoes. I went with a set of Micky Thompson Radial MTZ's in a 35" The first set took about 2lbs each on the balance. I sent them back, got a second set and they balanced out much better. Each tire took less than 6oz each.
Scottt is offline
post #4 of 7 Old 05-24-2012, 06:57 PM Thread Starter
Scottt
Next I did the locker bypass mod. I bridged the ground wire to the front and rear locker wire behind the dash. I haven't decided if I'm going to wire in a safety toggle switch yet; I don't really see the need for one. Now I can stay locked in four low AND in four high. Cheap and easy.
Now I need to decide what to do with the goofy looking fender flares. I'm thinking about going with a 4" metal cloak overline flats. I don't want to shell out the cash for those, but they sure do look nice. I was thinking about a set of Xenon flat flares too, I'm on the fence with those right now.
I also picked up a set of used 37" BFG KM2's that I got a great deal on. They are going to set in the shop for now, but I have them just incase
I would need to find some new 17" wheels too.
Scottt is offline
post #5 of 7 Old 05-25-2012, 06:11 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Nice. 37s already (almost). There are a lot of picture threads on this forum that show both fender you mention. Welcome back to jeepin!
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #6 of 7 Old 06-07-2012, 06:43 PM Thread Starter
Scottt
Thanks Mike, its good to finally be back.
So I have a few more minor changes over the last week or so.
First I pulled off the oversize Bushwacker fender flares and cut up some stock flares to hold me over a short bit. My front Metal Cloaks are on order and should be here in a couple weeks... but for now
Scottt is offline
post #7 of 7 Old 06-07-2012, 06:58 PM Thread Starter
Scottt
Next, I had a shorty front bumper make local, painted and swapped it out. Looks pretty good if I say so myself.
Scottt is offline
Daddy's power wheel TJ build (Slow build) Ratm Jeep Builds 15 02-04-2014 09:59 PM
JeepWJ26 Build--Johnny Cash Build JeepWJ26 Jeep Builds 31 01-09-2012 11:15 AM
Scott's 1979 CJ7 Build Paperboy326 Jeep Builds 22 04-14-2010 02:56 AM
