REFERENCE SHEET
1. MOTOR
1984 Jeep Grand Wagoneer 5.9L 360CI V8 (AMC 360)
A. Fluid: Valvoline 10w30 (5 quarts)
2. FUEL SYSTEM
Hamilton Fuel Injection
360-969-2925
A. Pump: ACDelco ADO-MU1614
Fuel Pump, Electric, Replacement, Chevy/GMC, In-Tank
B. Filter: Summit Racing SUM-230102
Fuel Filter, Inline Mount, Aluminum, Black, 40 Microns, -6 AN Male Inlet/Outlet
C. Hose: Summit Racing SUM-230620
Hose, Braided Stainless Steel, -6 AN, 20 ft. Length
D. Hose: Summit Racing SUM-230606
Hose, Braided Stainless Steel, -6 AN, 6 ft. Length
E. Fitting: Russell RUS-610025 (x6)
Fitting, Hose End, Full Flow, Straight, -6 AN Hose to Female -6 AN, Aluminum, Black
F. Fitting: Russell RUS-610095
Hose End, Full Flow, Swivel, 45 Degree, Female -6 AN Threads, Aluminum, Black
G. Fitting: Russell RUS-648060
Fitting, Straight, AN Flare to Metric, Aluminum, -6 AN to 16mm x 1.5 Male
H. Fitting: Russell RUS-648070
Fitting, Straight, AN Flare to Metric, Aluminum, -6 AN to 14mm x 1.5 O-Ring
I. Fitting: Vibrant VPE-16885
Fitting, Adapter, Straight, -6 AN Male Threads, Aluminum, Black Anodized
J. Fitting: Vibrant VPE-16886
3. TRANSMISSION
TorqueFlite 727
A. Fluid: Valvoline DEX/MERC ATF full synthetic (red bottle)
B. Transmission Pan: Summit Racing SME-1009R
Transmission Pan, Deep, Aluminum, Natural, Finned, Chrysler, Torqueflite 727
C. Vent Fitting: Edelmann EDD-831460
Fitting, Brass, 90 Degree, 3/8 in. Hose Barb, to 1/4 in NPT Male Threads
D. Pump Fitting: Edelmann EDD-221200
Fitting, Pipe Plug, 1/8 in. NPT Male Threads, Square Drive Head, Brass, Natural
E. Line Fitting (Case): Edelmann EDD-846260 (x2)
Fitting, Brass, Straight, 3/8 in. Hose Barb, to 1/8 in NPT Male Threads
F. Line Fitting (Cooler): Derale DER-98200 (x2)
Fittings, Swivel, Straight, Aluminum, Natural, Female -6 AN, Hose Barb 3/8 in.
G. Cooler: Derale DER-13700
Oil Cooler, 11.5 in. x 15.75 in. x 5 in. Cooler, 10 in. Fan, -6 AN Male
H. Fan Thermostat: Derale DER-13021
Fan Control, Thermostatic, 180F Degrees On/165F Degrees Off
I. Line: Derale DER-13017
Hose, Transmission Fluid, Rubber, Black, 3/8 in. I.D., 25 ft. Length
J. Kickdown Cable: Lokar LOK-XKD-2727HT
Kickdown Cable, Braided Stainless Steel, Black, Chrysler, Torqueflite 727
K. Flexplate: Pioneer PIO-FRA118
Flexplate, Steel, AMC, Non-SFI
4. TRANSFER CASE
Dana 300
A. Fluid: Valvoline 80w90 limited slip (white bottle, 2 quarts)
B. Front Output: 1310 non cv yoke
C. Rear Output:
D. Rebuild Kit: Advanced Adapters #400300R
5. DRIVESHAFTS
A. Front:
1. Length: 1.5" DOM .250 wall
2. Slip Yoke: Jeep Cherokee XJ
3. U-Joint: Spicer 5-1310x
B. Rear:
6. AXLES
A. Fluid: Valvoline 80w90 limited slip (white bottle, 3 quarts)
B. Fill Plug: 3/4" allen key
C. Diff Cover Bolts: 3/8" -16 x 1" Fastenal # 1123305
D. U-Joint: Spicer SPL55-3X
7. BRAKES
Front: 1989 Dodge W350 5.9L 359CI L6 Diesel / 4500 lb axle
Rear: 1986 Chevy K20 5.7 350CI V8 / 3/4 ton front calipers
A. Master Cylinder:
B. Booster:
C. Proportioning Valve: Wilwood WIL-260-8419
Brake Proportioning Valve, Knob Adjustment, 1/8 in. NPT, Single Inlet/Outlet, Aluminum, Natural
8. STEERING
A. Length: 1.5" DOM .250 wall
1. Tie Rod:
2. Draglink:
B. Heims:
1. Tie Rod:
2. Draglink:
C. Knuckle Stud: ARP #D60112
9. SUSPENSION
A. Rubicon Express RE-1445
B.
