It's just another TJ build thread... - Page 7 - JeepForum.com
post #91 of 254 Old 08-21-2011, 11:20 PM
jclauson
sweeeet gotta love the aussie!
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline
post #92 of 254 Old 08-21-2011, 11:24 PM
SuperRliBerty
2008 KK Liberty
Brian, looks sweet man
what oil you put in the diffs?
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #93 of 254 Old 08-21-2011, 11:26 PM Thread Starter
Brian86992
85W140 and it's completely silent
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #94 of 254 Old 08-21-2011, 11:28 PM Thread Starter
Brian86992
I put together a little list of tricks I wish I had known that would have saved me time... maybe someone will come across them in a search and it'll help them out.
  • The diff cover may not want to come off, tap it with a heavy hammer (I used a sledge) and it'll come free like nothing.
  • To remove the carrier put a 5/8" box wrench on one of the ring gear bolts and turn the drive shaft with a big adjustable wrench at the U joint. That will pry the wrench against the housing and it should come free.
  • Getting the roll pin (I think that's what it's called) out was a major PITA for me, make sure you have the correct size punch; 3/16th
  • If it isn't clear in your instructions (it wasn't in mine) when you install the Aussie put in driver and passenger side shaft connections (the end pieces) with their thrust washers first then the other 4 pieces slide in two by two (spacers inside already and the pins in the deeper, open holes. You will slide them to the other side to install the spring after everything is in).
  • Getting the carrier back in is somewhat tricky, make sure everything is lined up correctly then if it still won't seat use a 1 x 1 "shaft" of wood and a hammer (like a large punch) to coax it.
  • I used 85W140 oil per recommendation of 4x4explor.com and it's completely silent I can't hear a thing when driving in circles.
post #95 of 254 Old 08-21-2011, 11:39 PM
SuperRliBerty
2008 KK Liberty
Great write up! what brand oil you use? mobil1 or coastal? Also are you gonna change the front diff?
2008 Sport Liberty
post #96 of 254 Old 08-22-2011, 08:17 AM Thread Starter
Brian86992
That was the front diff Oil is Valvoline.
My rear already has a Detroit True-Trac in it and it's oil was changed about 4k miles ago.
I'm headed to the store now for engine oil, going to change that and find out why my headlights won't turn off high beam once the highs are switched on
post #97 of 254 Old 08-22-2011, 09:35 AM
SuperRliBerty
2008 KK Liberty
lol..... brain fart
while you at the auto store, look at haynes TJ wrangler electrical manual, I am thinking it is a failed relay or the switch.
2008 Sport Liberty
post #98 of 254 Old 08-22-2011, 09:40 AM
SuperRliBerty
2008 KK Liberty
lol..... brain fart
2008 Sport Liberty
post #99 of 254 Old 08-22-2011, 10:15 AM Thread Starter
Brian86992
lol..... brain fart
I actually have one of those in a cabinet somewhere... I never use it the internet proves to be a better source 90% of the time. I found what it was anyways. In order to have parking lights I wired the LED by pinching the positive and negative leads into the connection between my stock headlight connection and the male end that goes to the HID harness... turns out that was jumping the connection and causing the high beams to stay on even when they're off on the dash. Lesson learned...
post #100 of 254 Old 08-22-2011, 10:35 AM
SuperRliBerty
2008 KK Liberty
oh... ok. you unknowingly "bypassed" the switch...
2008 Sport Liberty
post #101 of 254 Old 08-22-2011, 11:42 AM
jmcd13
really sweet build. Its given me some great ideas for my YJ. I was wondering, are you going to go back and black out the rear corner guards or just leave them the way they are?
jmcd13 is offline
post #102 of 254 Old 08-22-2011, 08:06 PM
redrubicon11
what were all those antennas for
redrubicon11 is offline
post #103 of 254 Old 08-22-2011, 09:33 PM
north50
Holy sheet, the jeep is looking sick. Nice work and have fun up at school, we'll have to go wheelin when you get back. Thanks for the heads up on the Aussie Locker install as well.
north50 is offline
post #104 of 254 Old 08-23-2011, 08:49 AM Thread Starter
Brian86992
Thanks I may go back later but right now I'm enjoying the two tone with the aluminum corners and parts of the Metalcloaks
They are all just CB antennas but I took all but one off since then.
My brother goes to school in Greenville
No problem let me know if you have any questions installing it I usually respond to PMs on here real quick
I changed the oil yesterday (big deal right? ) Mobil 1 full synthetic 10w30 then installed a little LED panel that finally came in the mail for the dome light
It's worlds brighter than the stock bulb and total cost: $2
post #105 of 254 Old 08-24-2011, 09:29 AM
djflyy
Looks good my friend! Are you going to get flares for the MetalCloaks in the future? I've been playing with the idea of tube fenders since I'm kind of bored with the stock ones. I had originally thought the MCE plastic flattys now that they have the flared version ($350) but now that I've seen the TNT flared ones I'm kind of thinking that direction. Or maybe just build my own Anyway, sweet build. Now that you've spent all your graduation money on the Jeep, any plans for it's future?
djflyy is offline
Build Thread Agent620 Jeep Builds 32 06-06-2013 11:29 AM
My new XJ build thread. Element96x Jeep Builds 85 03-28-2011 09:32 AM
My not really a build thread build thread.. CapeCodGuy Jeep Builds 3 08-04-2010 05:15 PM
My Build Thread - '05 TJ 05rockymtn Jeep Builds 12 10-29-2009 02:26 PM
