That's just all wrong. - JeepForum.com
post #1 of 52 Old 02-16-2010, 06:43 PM Thread Starter
never monday
Well the new junk is coming along. Mostly thanks to dumpster diving, horse trading, freebies, and favors that can't be discussed.
I started with this
It was put together decently for a general purpose trail rig. Super 35 with a Detroit, True track up front. 4.88's & 35's, a beefier belly and tank skids. Not bad, just not my taste.
What is my taste is it's a 2.5, 5spd with a tub that's "experienced"
First trip out I spun the rear driveshaft out of it.
well getting off the trail with a truetrack in front and no rear drive sux.
Out came the LP30, and the build began.....
My philosophy is build as minimally as I think I need, but to the W.E. Rock rules for Modifed Stock class. WE Rock rules I'm shooting to have the rig weigh 2600 lbs when it's done.
A friend did a 30 to 44 swap in the front of his JK UNL. I happily removed the 30 from his garage
The JK isn't much of an upgrade from any other HP30. It uses the same crappy 2.5" x .250 wall tubes. It's just their a few inches longer on a JK set up.
So
2.5" ID sch 40 HREW pipe ($1 a pound scrap) and a plasma cutter
test fit
Left is the new sleeved tube, right is the stock tube in all it's whimpy nakedness.
Now the front tubes are 2.9" x .450 wall
short side plugged and seam welded
long side seam welded
Johnny Joint's set.
waiting on the lower brackets, track bar mounts. The mounts came in. We haven't had a chance to get them done an make progress.
I got a chance to fondle the new Reid JK knuckles. They have made some seriously nice pieces. Lots of reinforcement where it's needed. I just don't think the steering changes will be of benefit to justify using them. I'm going to make a tie rod and draglink using heim joints. The way Reid moved the mounts up for the stock tie rod will cause my contraption to bind.
THE SUPER 35 IS LEAVING THE RIG
thought you'd never hear me say that did ya?
well, one of those little advantages to the JK30 is 5.13 gears. I fully intend to take advantage of this
This is the start of the rear.
It's a 1979 F250, 3" x .500 wall leaf spring high pinion 44. (what's the name of my build?)
This is another one of those trade junk for junk prizes. It's been laying around for a year or so....so.....why not cut it up and make a rear.
After surgery it will be a centered rear, semi float HP44 with 30 spline Rubicon shafts at TJ width.
After having an Atlas and a STaK in the old rig. The 231 in this gutless wonder wasn't going to cut it for me.
Sold the 231 and the front LP30, bought a used 300 with a 4:1 kit and clocking ring. I found a used 21 spline input from a CalRocks guy for next to nothing. Yeah, I'll get pics when I get around to it.
Gotta give a thanks to Blaine and Gerald at Savvy
hopefully they'll get the belly skid done soon. I kinda need it to hang everything back up in there.
more to come later....got a few more dumpsters to hit this week
never monday is offline
post #2 of 52 Old 02-16-2010, 07:22 PM
Pacifier
That's a sweet starting point.
Pacifier is offline
post #3 of 52 Old 02-16-2010, 07:23 PM
jackel18
jackel18's Avatar
Looks good, can't wait to see more
jackel18 is offline
post #4 of 52 Old 02-17-2010, 08:20 AM
BarneyJEEP
My kind of build....sa's? Or don't know yet?
BarneyJEEP is offline
post #5 of 52 Old 02-17-2010, 08:58 AM Thread Starter
never monday
Short arm front with 12" or so of travel. 4link single tri long arm rear. Also somewhere around 12" of travel.
post #6 of 52 Old 02-17-2010, 04:10 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Pat,
That front axle is nice. I'm going to do the same to mine. Keep it up!
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #7 of 52 Old 02-18-2010, 04:57 PM
UTWeezul
Looks good! Can't wait to see how this rig turns out!
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #8 of 52 Old 02-18-2010, 05:33 PM
Bennettj13
Nice nice bro. But you mentioned not using the JK steering setup? Shoot me a PM when you get it figured out. When are you going to finish so you can come up here and wheel? Or so that I can come down there and wheel?
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #9 of 52 Old 02-18-2010, 05:35 PM Thread Starter
never monday
I'm using all the JK attachment points. Just using heims and and over the top tie rod. If I can get it past the diff.
I hope to wheel this summer.
post #10 of 52 Old 02-18-2010, 05:38 PM
theducksguts
Wow, never though you would part with the S35. This should be a good re-build.
Check out my
theducksguts is offline
post #11 of 52 Old 02-18-2010, 05:39 PM
Bennettj13
Without bending it, I doubt you'll get past the diff. You almost have to move it out like ORO did. Aside from that, I assume you are building your own draglink as well? If so, are you going over or under? Clearances get kinda tight in there if you are pushing 1-ton ends (unless you were planning on heims again).
Well ****, I forgot you've got the Reid knuckles. Did you measure to see how much farther (if any) they stick out at the tie rod mount than the stock JK knuckles?
post #12 of 52 Old 02-18-2010, 05:41 PM Thread Starter
never monday
all heims. On top of everything, drag link and tie rod.
I don't have Reids. They are a friends for his JK. I just got to fondle them
post #13 of 52 Old 02-18-2010, 05:52 PM
LuckRider
LuckRider's Avatar
Looking good there NM. I can't wait to see that axle truss. I wonder how long you are going to have to wait to slip that 300 under there
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #14 of 52 Old 02-18-2010, 05:54 PM
Bennettj13
Well good luck with that tie rod then. If you get a chance, try to get that measurement for me? Pretty please?
post #15 of 52 Old 02-20-2010, 01:20 PM Thread Starter
never monday
played around with the 300 some today
swapped inputs, pulled the clocking ring off. started to pull it down to change the shifter set up.
time for a new clocking ring
plenty of depth, maybe too much....
I was on my way to Walmart when I made a wrong turn... 'drack Jeep Builds 14 08-15-2002 05:10 PM
