RX Recon YJ - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > RX Recon YJ
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-30-2015, 09:04 AM   #1
ReconExpedition
Junior Member
RX Recon YJ
Hi all!
I bought this 1995 YJ 2011 and back then it was pretty stock. Been rebuilding and modifying it ever since. Joined JF to expand my knowledge and to get input regarding the upcoming mods.
I decided to start racing in Sweden Offroad Challenge 1 year ago and thatīs when I decided to replace the leafs and go with links. The main rule in these competitions is that the rig has to be street legal.
The specs today is:
- 2.5L+AX5+NP231 w. SYE
- Dana 44 front and Ford 8.8 rear
- Front susp. 3-link w panhard and Metalcloak springs, FOA shocks & bumps
- Maxxis creepy crawler 38s
- Flat belly
- High cut fenders
- Warn 8274 front winch
Some pics of the rig:
The mods Iīm doing the following weeks are 4-link rear and move the gas tank up in the trunk to stretch the rear. I want as much input and feedback as possible, so write whatever you feel to!
You can see more pics of our team Recon on Instagram and Facebook @ReconExpedition
Best regards Robin
Team Recon
Sweden
Best regards Robin
ReconExpedition on Instagram and Facebook!
ReconExpedition is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 09:17 AM   #2
HKFTW
Thats a bad *** YJ man. I like it.
HKFTW is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 12:03 PM   #3
ReconExpedition
Junior Member
Thanks! It will get even better with rear linked suspension
Best regards Robin
Unread 07-06-2015, 11:14 AM   #4
AZdEvilYJ
RIP Anticanman
AZdEvilYJ's Avatar
Been following you and watching your build on instagram, great to see you moved your build here!!
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
http://www.jeepforum.com/forum/f22/a...nally-1575209/
AZdEvilYJ is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 05:26 AM   #5
ReconExpedition
Junior Member
Hi! Nice to see your thread too! How is the v8 swap going?
/Robin
Best regards Robin
Unread 08-03-2015, 06:10 AM   #6
ReconExpedition
Junior Member
I have begun with the rear 4-link conversion. I have used 3 weeks of my vacation but I didnt finish. Its a couple days work left, but I think its gonna rock.
Summit Machines large flexjoints. Love them!
Rancho RS9000XL shocks with 14" stroke, FOA 2.5" bump stops with 4" travel, Summit Machine flexjoints and Chassis Unlimited 1.25" weld on threads.
I have stretched the rear 8" and therefore I re-located the fuel tank in the trunk.
Cleaned the 8.8 from mounts.
Fabing the truss.
Figuring out where the upper frame mounts should be.
Checking clearence.
Fabed a crossmember with the lower frame mounts.
Love the laser!
Grinding the mounts to get the correct angle and checking clearence for the flexjoints.
Things getting ligned up and ready to be burned in.
The new crossmember welded to the frame.
Flexjoints, bunges, jam nuts, weld threads and links.
Welding the threads to the flexjonts.
Links mocked up.
Fabing the upper mounts.
Best regards Robin
Unread 08-03-2015, 06:14 AM   #7
ReconExpedition
Junior Member
Cut the links.
Got help from Mahlin Advanced Mechanics with his lathe to pressfit the bunges.
Welded the threaded bunges into the links.
Got some help from my cousin and my girlfriend.
Reinforced the frame.
Put the axle under the jeep with the coils standing on it.
Notched the frame to clear the shocks.
Fabed shock towers.
Fabed bump stop cans.
Welded the cans to the frame.
Checking clearence. Fully compressed.
Fully drooped.
New crossmember and a frame for the fuel tank.
New fuel filling position.
The floor will line up with the wheelhousings. I will build a hatch in the floor where the winch rope (will replace the wire) will get up and have a fairlead in the roof cage.
There will be a plate covering the hole and a hatch above the winch.
As it looks right now. There are still things to do, but the chassis getting ready for paint!
Best regards Robin
Unread 08-03-2015, 10:59 AM   #8
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I like the idea of the deck lid a lot. Looks good.
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 11:04 AM   #9
ReconExpedition
Junior Member
Thanks!
Best regards Robin
Unread 08-10-2015, 02:01 AM   #10
ReconExpedition
Junior Member
Time for an update!
Everything is fully welded. Time to remove everything, wirrebrush, base coat and top coat.
Ford 8.8 and links.
Some weld pics.
Flexjoints ready for paint.
Wirebrush.
Ready for base coat.
Protection!
Top coat.
Base coated rear axle.
Done.
Mounted the wheels.
Mounting the flexjoints.
Links.
Fairlead that will be mounted above the rear winch in the cage.
Gave the coils some fresh paint.
Top coated frame.
Top coated and mounted the fuel tank.
Team Recon having a coffee break
Brake and fuel lines mounted to the frame.
Then we mounted the rear axle, links, bump stops, shocks, drive shaft and so on. Time to drive out of the tent and bleed the brakes.
My co-driver posing.
We took a shorter test ride and it felt very tight and handled great. We have video from the test drive on our Facebook account, ReconExpedition. Go and check it out!
Next up is to fab a new exhaust system and do the sheet metal work in the rear.
//Robin
Best regards Robin
Unread 08-17-2015, 02:57 AM   #11
ReconExpedition
Junior Member
Time for an update again.
Exhaust system is finished.
Reinforced the pnahard mount on the axle.
A little flextest with the CurrieEnterprises AntiRock connected. Need a bigger rock!
Then I washed the rig inside and outside and installed rear fenders.
It is 2 weeks to the Sweden Offroad race and we still have alot of details to finish. But it runs great and we are loaded for this race!
Best regards Robin
Unread 08-24-2015, 04:05 AM   #12
ReconExpedition
Junior Member
Where is the response? There must be something you think looks wrong??
An update from the past week.
My rig outside of Offroad Worx shop waiting for the inspection guy. Step 1 of 3 to make it street legal.
On the lift.
The inspection went very well. No problem at all, soon the rig will be street legal again. I drove 3 hours on pavement after the inspection. It handles well. I got a little dead play in the steering wheel. I'll adjust the screw on the steering box 1/8 turn and see if it helps. All links, uniballs and such are really tight. But I can see a little play on the axle that the pitman arm is mounted on...
Picked up my GF and we drove to the pizza place. Pizza-crawler?
Installed a new winch rope, 100 ft.
No beer, sorry. But a really ice cold pimms! It was really hot this weekend!
I installed a power steering cooler I got from Offroad Worx. Thanks!
Sleeved the tie rod.
Skidslopes on the skidplate to protect the flexjoints from direct impacts.
High lift mount in the rear. I used hood pins for fast and easy access.
Recon is now race-ready! Next weekend itīs time for our first offroad challenge for this season. Its a 12h non-stop race and it will be interesting to evaluate everything.
/Robin
Team Recon
Best regards Robin
Unread 08-24-2015, 03:54 PM   #13
lucious
beautiful. props.
lucious is offline   Reply With Quote Quick reply to this message
Unread 08-24-2015, 09:34 PM   #14
AZdEvilYJ
RIP Anticanman
AZdEvilYJ's Avatar
Awesome work!
'95 YJ 2.5L
My Build Thread
Unread 08-31-2015, 06:22 AM   #15
ReconExpedition
Junior Member
Status from this weekends Sweden Offroad challenge-competition in Stockholm, Sweden.
It began really good for us. We had a good flow and everthing worked great. Both the team and the rig. But after 6 hours of racing (half time) we bent the drag link. I knew this was a weak spot on the rig and I have planned to buy a ram-assist... Now I just have to!
We took the drag link to the depot to cut and weld it but in the same time my co-driver got ill and sick. So we had to end the race. Really sad but nothing we could do about it. Its race day in the end of September, we will reload and get back til then!
We ended up on 8th place of 12 rigs.
But Im very pleased how the rig performed. The extended wheelbase (103") is a huge advantage from before and the Creepy Crawlers works good as heel in this kind of terrain. Rocks, mud and so on. And the CurrieEnterprises Anti Rock... I just love it! It saved us a couple of times from roll overs but still gives us all the flex we need!
Pictures of us I found from people on Facebook from the race.
In this test, the Anti Rock sway bar was worth every buck. The rig after us didnīt have any sway bar and rolled over, smashed the rig and had to quit the race.
Bent draglink!
Hit the highway on our way home, no trailer queens!
/Team Recon
Best regards Robin
