RubiRed -Armored, LCOG, TumTuk'd, and Daily Driven (Pictorial) - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > RubiRed -Armored, LCOG, TumTuk'd, and Daily Driven (Pictorial)
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 11-04-2011, 11:04 PM   #1
julietkilo
I wasnt going to do a build thread but I have hundreds of pictures that I figured I would at least post up. Its Jeep porn as my wife calls it. A little about me. I am a bonified 4x4 nut. I am on my 3rd Wrangler, second Rubicon, and Solid Axle swapped a newer Bronco with E Lockers, trying to make if feel like a Jeep. Ended up selling it and buying another Rubicon. Love working on my vehicles. And I love my tools tools tools. I have a 180 Mig Welder, large assortment of tools, 4 Jack stands, air tools air tools air tools! My family and I are military, I love this forum, and of course love Jeeps.
Here is where I am currently:
315/75R16 Maxxis Bighorn MT on Moabs with Spidertrax spacers
BDS {3" Springs, Rear sway bar Links)
Doetsch Tech Shocks {DT3000)
ROKMEN {JJ Adj. Upper/Lower CA, Gas tank Lift/skid)
JKS {Track Bars, CV Bracket, Quicker Discos, MML, 1"BL)
Procomp 2000 Steering Stab
Coast HD 1350 Double Cardan
Novak NP241OR 4WD Cable
UCF TumTuk
ToysbyTroy Winch STINGER
Rampage Recovery Rear/Tire Carrier
Stealth Alpine Audio System/500wRMS Kicker L5 Sub
Burned on Clayton Rear outboard shock mounts.
Rear back up lights installed into the rear bumper recesses
Here is the short term:
Front Upper and Lower Control arms (rears are done for the CV and tumtuk)
JKS front track bar
Bump stop correction
And for the Long term:
4.88 or 5.13 gears, overhaul kits, installed by me
Outter axle seals since Jeeps screwed that up with plastic dust covers and inner axle seals (when needed, good for now)
Rockers Guards (sell rubicon rockers)
Corners and Front Fenders
Winch
Done
Currently Stance : By the numbers ---- Mod ---- Description
CLEARANCE
17" ---- Tummy Tuck ---- UCF ground clearance
17" ---- Gas Tank Skid ---- ROKMEN ground clearance
11" ---- Axle Clearance Front ---- From the lowest point (diff)
10.5 ---- Axle Clearance Rear ---- From the lowest point (diff)
73" ---- Overall vehicle height ---- @ the top of the windshield
34.5" ---- Height Tires ---- Maxxis Bighorn MT
12.5" ---- Width Tires ---- Maxxis Bighorn MT
3.75" ---- Backspacing ---- Spidertrax 1.25" Hub Centric on Moab 16x8
5" ---- Top Tire to Fender Clearance ---- Stock (Metal Cloak, TNT, other)
3" ---- Lift ---- BDS
1" ---- Motor Mount Lift/Body Lift ---- JKS
SHOCKS (Doetsch Tech DT3000)
4" ---- Front shock piston showing ---- Bump stop limited
6" ---- Front piston droop ---- Shock limited
10" ---- Front Travel ---- Untested
2.25" ---- Rear shock piston showing ---- Bump stop limited
7.75" ---- Rear shock piston droop ---- Shock limited
10" ---- Rear Travel ---- Untested
? ---- Ramp Score ---- Untested
94" ---- Wheelbase ---- Stock, Rokmen Upper Lower Arms
OTHER
? ---- Operating Weight ---- Bumpers, skids, vehicle, full tank, winch, driver
12.4 ---- Hwy/cty MPG ---- on 33's with exact speedo, 35's untested
73,xxx ---- Mileage ---- Feb 2012
13,000 ---- Price Paid ---- Feb 2011
Current Stance: By the Pictures
[SIZE="1"][COLOR="Red"][B]2003 Flame Red Rubicon [/B][/COLOR][URL="http://www.jeepforum.com/forum/f22/rubired-armored-lcog-tumtukd-daily-driven-pictorial-1285548/"]RubiRed Build Thread[/URL]
tummytukd on 35's
Air Force Loadmaster/Air Force Jeep Club [B]#12[/B]
[B][URL="http://www.jeepforum.com/forum/f7/i-am-petersens-4wheel-off-road-magazine-pics-526488/"]Me in Petersons 4-Wheel Off-Road Magazine[/URL]
[/B][/SIZE]
julietkilo is offline   Reply With Quote Quick reply to this message
Unread 11-04-2011, 11:05 PM   #2
julietkilo
Rear Armor Recovery Tire Carrier
Other
2" shock extensions for 2" more drop
More to come, just pressed for time tonight.
tummytukd on 35's
[/B][/SIZE]
Unread 11-05-2011, 06:26 AM   #3
kashoggio
Good job all quality items
2004 TJ RUBICON~ [COLOR="Lime"]LIME GREEN[/COLOR]
[FONT="Century Gothic"][COLOR="DarkRed"]"Some desire is necessary to keep life in motion."[/COLOR][/FONT]
[URL="http://www.jeepforum.com/forum/f22/2004-tj-rubicon-skittles-build-1152944/"][SIZE="4"][FONT="Showcard Gothic"][COLOR="Lime"]MY JEEP BUILD [/COLOR][/FONT][/SIZE][/URL]
[url="http://www.jeepforum.com/forum/f33/?uid=226258"]ITEMS FOR SALE [/url]
[url="http://www.jeepforum.com/forum/groups/polish-jeepers/"][COLOR="Red"][SIZE="5"]POLISH JEEPERS CLUB[/SIZE][/COLOR] [/url]
kashoggio is offline   Reply With Quote Quick reply to this message
Unread 11-05-2011, 09:07 AM   #4
julietkilo
Thanks Kash, still a ways to go.
Control Arm Beef
ROKMEN left CURRIE right (uppers)
ROKMEN (lowers) 1.75"!
Tracking Fix
Tummy Tuk
Gas Tank
Drive Shaft 1350 Double Cardan
Tucked the Rubicon air pumps above the driver side frame, isolated with rubber stand-offs
Front Armor Recovery
tummytukd on 35's
[/B][/SIZE]
Unread 11-05-2011, 10:36 PM   #5
julietkilo
Installed the back up lights on the same fuse as the reverse lights, these lights call for a 15 amp fuse but I have them on the same circuit as the 10 amp and it didnt blow. I dont think the lights are drawing a full 110 watts per set, should be around 10 amps if 10x12=120 watts. Soldered all connections so they dont rust or corrode free.
tummytukd on 35's
[/B][/SIZE]
Unread 11-05-2011, 11:06 PM   #6
julietkilo
Installed 2 amps in ole Rubi RED. Sony XM-1S and Alpine KTP-445.
Full write up here. http://www.jeepforum.com/forum/f20/i...-pics-1285867/
tummytukd on 35's
[/B][/SIZE]
Unread 11-06-2011, 10:33 AM   #7
midnight_f150
Nice job on the Jeep. You take great picture looking forward to the ROKMEN rockers install picture.
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2011, 02:02 PM   #8
julietkilo
Thanks, I hope to do the Sliders sooner than later but you would be surprised how well the stock rockers do.
tummytukd on 35's
[/B][/SIZE]
Unread 11-06-2011, 02:09 PM   #9
julietkilo
DB Drive k112d4 in a ported .75 cu ft (1 cu ft total with port) ported. Very loud and I got it at a pawn shop for 50 bucks. Just needed to use my pneumatic nailer to fix it up, sealed with new caulk and recarpeted it. Vioala, super cheap and very good quality sound for cheap. It fits perfectly between the baby seat mounts on the back floor and can be removed for extra storage. The amp is out of the way so I can just unhook two wires and take it out for cargo. I figured the air space for 40Hz tuning. It hits hard enough to move my eyes in their sockets. Weird feeling and it doesnt distort with the 500 watts RMS, sub is only rated for 300 RMS. For 50 bucks this sub is incredible.
tummytukd on 35's
[/B][/SIZE]
Unread 11-06-2011, 03:19 PM   #10
Rubado
Did you use the UCF low-pro mount for the TT?
Rubado is offline   Reply With Quote Quick reply to this message
Unread 11-06-2011, 03:37 PM   #11
myclejay
Neat.
myclejay is offline   Reply With Quote Quick reply to this message
Unread 11-06-2011, 03:42 PM   #12
julietkilo
no, in my opinion and experience poly bushings on motor or transmission mounts makes the vehicle shake horibbly especially with a CV double Cardan driveshaft. To keep a nice ride I kept the stock rubber trans mount. I did have to dent the body in one area above the front output on the Tcase, otherwise no issues, I also used an acetilyne torch to modify and heat the exhaust pipe to bring it down to stock location and cut and welded the mount to make the catalytic work on our rigs.
Cut the UCF for my exhuast to fit better
Then heated the pipe with a torch here to bend it down into place.
Cut and ground down trans/catalytic mount and moved it down 1 inch.
Cut and smoothed the UCF for my exhaust muffler, things are a bit different in the rubi since the transfer case is a bit bigger.
Here you can see the catalytic sits in its new location with the modified mount and all is well. This took a few days of working on it off and on after work. Be prepared to take the time and make it right. I rewelded this thing twice, once at 2 inch overlap and finally at 1 inch overlap.
Even with a 1 inch body lift and the UCF tummy tuck with the "extra clearance", 2 1/2" skid I still hit the body, you will need to dent the body below the driver seat hidden under a reinforcement panel, it doesnt mess with the cab at all but under the jeep there is a bit of a dent, no biggie, just used a pry bar.
tummytukd on 35's
[/B][/SIZE]
Unread 11-06-2011, 03:56 PM   #13
julietkilo
Updated post above with information pertaining to the photos.
Originally Posted by myclejay View Post
Neat.
thanks.
tummytukd on 35's
[/B][/SIZE]
Unread 11-08-2011, 08:30 AM   #14
julietkilo
Blew my subwoofer yesterday, gonna go with an Kicker L5 or L7 after doing some research on the best match to my Amp vs, space behind the seat.
tummytukd on 35's
[/B][/SIZE]
Unread 11-08-2011, 08:51 AM   #15
KevKaos
Subscribed to your thread. There's a lot of good information here. Thanks for sharing.
[SIZE="4"]KevKaos[/SIZE]
[SIZE="4"]Honey Badger Wheelin'[/SIZE]
[FONT="Arial Black"][SIZE="5"][COLOR="Red"]RED JEEP CLUB # 621[/COLOR][/SIZE][/FONT]
It's not much, but check out my build thread;
[url]http://www.jeepforum.com/forum/f22/kevkaoss-05-red-rubicon-build-thread-1170741/[/url]
[QUOTE=krashnpa;12397572] I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.[/QUOTE]
[QUOTE=squazz;13612008]so I use my original nuts?[/QUOTE]
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline   Reply With Quote Quick reply to this message
