Rotted Tub Replacement - JeepForum.com
post #1 of 112 Old 01-21-2014, 08:07 PM Thread Starter
whiskeywiz
The single-car-garage Resto
Sold my 5.0 Mustang
whiskeywiz is offline
post #2 of 112 Old 01-21-2014, 08:09 PM Thread Starter
whiskeywiz
To buy my 89 Wrangler
post #3 of 112 Old 01-21-2014, 08:11 PM Thread Starter
whiskeywiz
The first issue, (besides rot on the underbelly of the tub needing attention), was pointed out to my by a buddy via this photo. Do you see anything wrong here?
post #4 of 112 Old 01-21-2014, 08:16 PM Thread Starter
whiskeywiz
Well if you can't see it, here is a hint. The 4wd did not work because the transfer case was wasted. Look at the slack in that chain! It was wearing into the interior shell! Before taking apart the Tcase, I installed the Positive engagement kit to the front axel. That did not resolve the 4wd issue, but no loss on that upgrade.
post #5 of 112 Old 01-21-2014, 08:19 PM Thread Starter
whiskeywiz
Okay, so I got a Tcase from an overpriced junkyard, threw it in, went out to test the 4wd.
post #6 of 112 Old 01-21-2014, 08:21 PM Thread Starter
whiskeywiz
After testing the 4wd, I realized I needed a "trail buddy".
post #7 of 112 Old 01-21-2014, 08:24 PM Thread Starter
whiskeywiz
So, ran her for a while like that, enjoying the summer. The rot on the tub was the next area of concern. The roll bar mounts were pushing through the floor, driver side floor pan just gone, seat belt mounts gone, etc. So I came across this through a buddy.
post #8 of 112 Old 01-21-2014, 08:31 PM Thread Starter
whiskeywiz
The new tub however, did not come ready for installation. It was, in fact, in a little worse shape than I anticipated
post #9 of 112 Old 01-21-2014, 08:36 PM Thread Starter
whiskeywiz
So, I got me one of these. And I got me one of those. That is a restoration job I did on that press. My neighbor's daughter gave it to me. I didn't need the press for the body work, but will be using it very soon for some frame work.
post #10 of 112 Old 01-21-2014, 08:56 PM Thread Starter
whiskeywiz
And I went to work on the rot. These were the two bad areas, the passenger side floor pan and rocker panel, and the rear wheel well driver side.
post #11 of 112 Old 01-21-2014, 09:03 PM Thread Starter
whiskeywiz
Some of the floor/rocker repair. I made a major boo boo when I cut loose the old rocker panel. The tub dropped, twisted, and tweaked about an inch in each direction when I made the last cut. A little foresight would have come in handy there. I also cut the jamb into the radius on the tub because that's where the new panel ended. I should have cut back the new panel, where the radius was done with, then I would have been working on a straight line. Hopefully somebody learns from my mistakes.
post #12 of 112 Old 01-21-2014, 09:13 PM Thread Starter
whiskeywiz
Man, I went super-slow with merely tack-welds, spaced out, AND immediately cooled them with a blow gun and that damn thing still warped on me! Ah well, i'll just blame it on the trees.
post #13 of 112 Old 01-21-2014, 09:19 PM Thread Starter
whiskeywiz
On to the mess in the back. Made great use of some trash I spotted at the curb on this one.
post #14 of 112 Old 01-21-2014, 09:25 PM
CrazyJeepMan92
Sweet build so far! How do you like the ESAB? I have an ESAB plasma cutter but never tried a welder.
NATEF/ASE Certified
US Marine MOS: Diesel Mechanic
Fabricator/Mechanic Kool Kidz ATV
CrazyJeepMan92 is offline
post #15 of 112 Old 01-21-2014, 11:10 PM Thread Starter
whiskeywiz
The first few pics are replacing the front driver side body mount. The second set is the body mount hidden under a brace that connects with the floorpan and the support beam running from side to side was a body mount which was destroyed. This is how I fabbed one up. Probably could have gone about it in an easier method, but didn't mind the work.
