Rockdrummer93's 2001 XJ build - Page 8 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 41987-1995 Jeep Wrangler Mirror Manual Folding Pair1987-1989 Jeep Wrangler Brake Pad & Rotor Kit Semi-Met
Unread 03-28-2011, 09:51 AM   #106
Rockdrummer93
Originally Posted by Paraleyes View Post
Nice! Hey man, would you measure how tall that sits when sitting flat on a bench. Maybe sit a level across it to measure how far it will extrude from the face of the mounting surface for me? My JCR steering kit puts my track bar super close to my diff cover. When I'm cranked all the way to the right, it almost touches the stock cover. I also like how the fill plug is slightly slanted upwards from what I can tell.
here ya go! Almost 2 3/4"
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2011, 09:54 AM   #107
Rockdrummer93
Started painting the diff cover last night!!
Primer:
PR4 Flame Red:
Build Thread
Unread 03-28-2011, 04:25 PM   #108
Paraleyes
I hope that's just the artificial light of the camera flash. Almost looks pink. haha Thanks for measuring that for me! Looks like the Poison Spyder cover is the exact same thing with a different logo. And 2 3/4" as well. I'll order this one since JF has a vendor here selling them.
http://www.jeepforum.com/forum/f43/g...parts-1172677/
One thing though, I don't suppose you would make that same measurement for me on the stock cover after you get it off? I tried to get an accurate measurement the other day I was welding underneath my bumper, but it can be a PITA for me gimping around under there. So, if you don't mind? I'd rather get a more precise measurement with it sitting on a bench. Please and thank you!
[B][URL="http://www.jeepforum.com/forum/f11/cut-fold-rear-lower-quarter-panels-right-way-1007865/#post9237914"][FONT="Verdana"][SIZE="2"]Cut And Fold Rear Lower Quarter Panels - The Right Way![/SIZE][/FONT][/URL]
[URL="http://www.jeepforum.com/forum/f22/my-2000-xj-build-fully-armored-fully-capable-979162/#post8964962"][SIZE="2"][FONT="Verdana"]My 2000 XJ Build[/FONT][/SIZE][/URL][/B]
Paraleyes is offline   Reply With Quote Quick reply to this message
Unread 03-28-2011, 05:39 PM   #109
Rockdrummer93
No problem man! yeah I took the picture with a cell phone in bad light. It looks better and more red in person. I'll get a better picture when its done. Yeah sure I'll do that for you.. Just give me another day, probably have it up for you tomorrow.
Build Thread
Unread 03-28-2011, 05:53 PM   #110
Rockdrummer93
Got the rear lights mounted and the wiring ran through the roof. Still waiting the switches so I can actually hook them up!
Build Thread
Unread 03-28-2011, 07:14 PM   #111
Paraleyes
Thanks!
Unread 03-31-2011, 06:27 PM   #112
Rockdrummer93
I know its not a measurement but this is all I had time to get, hope it helps..
Build Thread
Unread 04-01-2011, 07:40 AM   #113
Paraleyes
Helps a lot. Good idea doing that. Thanks man!
Unread 04-01-2011, 05:46 PM   #114
Rockdrummer93
No Problem!
Build Thread
Unread 04-01-2011, 06:30 PM   #115
Rockdrummer93
Got my new lights hooked up today.. Since I already have pictures of the light mounted I wont add more.. However I would like to show off my wiring, I am quite proud of it. I moved all the relays to the firewall and lined them up as neat as a could.. I also added a relay for my switches, this one was kind of an experiment for me. I liked how my previous switches were powered by the ignition wire so that I could only run the lights with the Jeep being on. Now I knew that I couldn't just keep splicing into that cable without worry about drawing too much power from it so I decided to relay it as a switch. So now all 4 switches are powered directly from the battery while keeping the ability to only turn on the lights while the Jeep is on..
Build Thread
Unread 04-03-2011, 08:32 PM   #116
Rockdrummer93
Ok.. Bought a Rough Country RS9500 winch the other day. So far its been awesome. I'm really satisfied for only $300. One thing that pissed me off about installing it was that the solenoid box was a little over sized for my bumper and the way the winch is mounted inside the bumper. So I had to make some brackets for the solenoid box. I bought a piece a aluminum bent it up, drilled some holes and bolted it up. Unfortunately I also had to cut into the grille a little, cut more then I would have liked but I'm getting used to it. I actually got to really use it like a day after I got it installed and working. My friend called me up and needed me to use my winch to pull this guy out cause it was too slick for his truck to get traction so I went and the winch performed the way it should have and pulled a 98 TJ deadweight out of the mud hole with ease.
The Brackets
The Grille
And the finished product.
Oh and my bender! Well at least I found another use for it my bumper
Build Thread
Unread 04-04-2011, 02:26 AM   #117
Paraleyes
*****en!
Unread 04-04-2011, 05:06 PM   #118
Gearhead231
nice engineering!
Cherokee Creto-This is my cherokee... there are many like it but this one is mine, I will love my cheroke form the day of ownership untill the day it dies, I promise to modd it and beat it after said mods... i promise to treat all other cherokee owners as family even though they are complete strangers.... and promise to jeep on forever
Gearhead231 is offline   Reply With Quote Quick reply to this message
Unread 04-04-2011, 06:43 PM   #119
Rockdrummer93
Originally Posted by Gearhead231 View Post
nice engineering!
thanks man!
Build Thread
Unread 04-05-2011, 06:54 AM   #120
njg2982
What spray on bed liner did you use?
2000 Jeep Cherokee I6 4.0L - Stock for Now...
njg2982 is offline   Reply With Quote Quick reply to this message
