Rockdrummer93's 2001 XJ build - Page 60 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 05-11-2014, 08:35 PM   #886
Project1
Sorry to post every day lol but I got to check :-) ... Lookin bad nasty :-)
You must be stoked, it's getting close :-)
Project1 is offline   Reply With Quote Quick reply to this message
Unread 05-14-2014, 09:04 PM   #887
Rockdrummer93
Well still waiting on the rear axle to come back from the shop. After a lot of talk it was decided that my little mini truss wasn't going to be strong enough to cut it off and started over.. Went with half inch this time and boxed it in a little. This one is a lot more solid then the other. Finished it up today. Hopefully tomorrow can it back under the Jeep and shock mounts welded on.
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
OffroadSC
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 05-14-2014, 10:26 PM   #888
Project1
man lookin better every day
Unread 05-15-2014, 07:09 AM   #889
Rockdrummer93
Thanks!
Build Thread
OffroadSC
Unread 05-15-2014, 08:34 AM   #890
crockett07
1992 XJ Cherokee
Ah man you're getting so close! You have much more patience for getting things finished than I do
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 05-15-2014, 08:36 AM   #891
Luke95
Check your oil pan clearance with my 44 ****s tight.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 05-17-2014, 06:10 PM   #892
Rockdrummer93
Well the time has come! Finally rolled it out of the shop on all for tires today. Still has some little odds and ends to work out but its pretty much finished! Started yesterday finishing up the front and getting it under and all the bolts in and tight also worked out the shock mounts. Turned it around and got the rear ready to go in late last night and finally get her under this morning. Mounted the rear calibers on the wrong side and can't get a good brake pedal so tonight will be getting that worked out. Also missing a rear spindle jam nut. Other then that she looks alright. Hopefully if I can get all these odds and ends worked out this week we'll be off to Gulches and we'll all see what she can do!
Build Thread
OffroadSC
Unread 05-17-2014, 06:59 PM   #893
crockett07
1992 XJ Cherokee
Righteous!
Unread 05-17-2014, 07:15 PM   #894
Luke95
Go warns for the lock outs
Unread 05-17-2014, 07:16 PM   #895
Rockdrummer93
I will most likely but for now it will be the factory Ford ones
Build Thread
OffroadSC
Unread 05-17-2014, 09:24 PM   #896
MOBBiN
MOBBiN's Avatar
Wide!
What front coils are you running?
2001 Silverstone Metallic Classic/Limited XJ
April 2014 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 05-17-2014, 09:25 PM   #897
Rockdrummer93
Originally Posted by MOBBiN
Wide! What front coils are you running?
4.5" RC with 1.5" spacers
Build Thread
OffroadSC
Unread 05-17-2014, 10:31 PM   #898
Project1
F'n wiggle wiggle wiggle wiggle wiggle wiggle wiggle
Your stance looks awesome ... Beast mode :-) ... That's what I want mine to look like :-) ..
Stoked man, a lot of work but totally awesome :-)
Unread 05-17-2014, 10:36 PM   #899
Project1
So sick, your jeep as a whole is super nice
Unread 05-18-2014, 07:43 AM   #900
Luke95
Get wheelin.
