Rockdrummer93's 2001 XJ build - Page 57 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-31-2014, 04:31 PM   #841
Project1
A new 500$ beater xj will be the last big mod to my xj :-)
Project1 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2014, 11:17 PM   #842
Rockdrummer93
Alright well not much has been going on. Did finish up the HP44 today. Other then the track bar bracket all the welding has been finished. Also through my preload shims on the carrier, pressed the new bearing on and got the carrier in for the last time. Will probably get the axle under the Jeep for the last time tomorrow. Im going to wait till I get everything finished to do the track bar. Because my TnT frame side track bar mount is too far offset Im going to get everything set up and then work that out. May have to buy a new frame mount or if I have the money may just order some front frame stiffeners and do a weld on mount. Still not sure.
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 04-06-2014, 11:05 PM   #843
Rockdrummer93
Ball joints have been ordered! Will still be going to harlan but not in my Jeep. Will be helping out a friend and trailering his up there. Kinda happy it worked out this way because I want to get a look at Harlan before I take my Jeep up there. Plus with all this work going into the Jeep I'd like to take it to Gulches on its first trip. I know that park a lot better and will be able to give it a proper shake down there and be close enough that it won't be that big of a deal if I break it on the first trail god forbid it happen. Now will be planning to make the NAXJA event up at Harlan in July so will be good to get out there this weekend and get a feel for it without actually bashing my Jeep so I know if I need to make any adjustments before July.
Build Thread
Unread 04-07-2014, 07:41 PM   #844
Project1
that axle is lookin awesome
Unread 04-13-2014, 09:38 PM   #845
crockett07
1992 XJ Cherokee
Hey man, do you mind giving me a little more info on the 1 ton steering? You've got my head buzzing about it
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2014, 09:47 PM   #846
Rockdrummer93
Yeah no prob! Its JCR's 1 ton over knuckle set up. Simple to install just can be a pain and can take some time. The knuckles were the easiest to drill and ream. The pitman arm was another story, Drilling and reaming that was probably the hardest part of the install.. Just took a lot of time and ate up an $80 reamer. You will need a over axle track bar set up to make it complete, too keep your angles right. I went with TnT Offroad's track bar system. It was the easiest to get ahold of. Did have to re drill the frame mount to move the track bar up a little bit to get my angle pretty much parallel with the drag link. I also had to extend my steering stops and trim some of the factory axle brackets to clean the bigger linkages. Thats about the only disadvantage to the set up is a lack of turning radius.
Build Thread
Unread 04-13-2014, 10:27 PM   #847
Rockdrummer93
Just got back from Harlan. really glad I didn't rush and take my Jeep. It wouldn't have made it up some of the trails out there. But I am glad I went to get a look at it so I can prepare the Jeep for it. Towed my buddy's 5.9L ZJ up there. The Truck towed great but the transmission I don't think made it. Barely got it home and now even with no load 2nd gear slips pretty bad. So will be taking it to a tranny shop tomorrow to see what my options are. Need to get the Jeep done even more now so I have something else to drive. We'll see what happens and will keep y'all updated.
Build Thread
Unread 04-14-2014, 12:09 AM   #848
Project1
Man looks like a super fun trip
Unread 04-14-2014, 01:22 PM   #849
crockett07
1992 XJ Cherokee
Great info on the jcr steering. How much turning radius did you lose? How's the transition going to the new axle? And do you see it being a problem installing the steering and doing the trac bar a day or so later?
Reason I ask is I'm not setup to do it all in one location. I would have to do the steering in one place an the trac bar elsewhere.
Nice pictures of the trip, when I was considering moving to KY, Harlan was going to be a big perk. Sucks your truck had problems
Unread 04-14-2014, 01:34 PM   #850
Rockdrummer93
Originally Posted by crockett07
Great info on the jcr steering. How much turning radius did you lose? How's the transition going to the new axle? And do you see it being a problem installing the steering and doing the trac bar a day or so later? Reason I ask is I'm not setup to do it all in one location. I would have to do the steering in one place an the trac bar elsewhere. Nice pictures of the trip, when I was considering moving to KY, Harlan was going to be a big perk. Sucks your truck had problems
I didn't loose much but enough to notice.. Parking isn't a real issue just swing it wide. Trail riding some times have to 3 point it but not bad. And the axle swap is still coming along but slowly. Still have a few more things to buy. And yeah I did the same.. Installed the steering ordered the track bar the same day and then had it installed a few days later.. Didn't drive it too much while I was waiting.. But I'm sure it will be fine.. Just make sure your track bar is tight and it should be fine. Yeah I'm at a transmission shop now and they found pieces of metal in the pan so gonna be getting it built soon so the jeep might be postponed a little more. We'll see
Build Thread
Unread 04-14-2014, 01:46 PM   #851
crockett07
1992 XJ Cherokee
Thanks! I'm still researching and weighing my options, but I appreciate the insight. Good luck with the truck, tranny problems are always ****ty
Unread 04-24-2014, 12:50 PM   #852
Rockdrummer93
Got my tie rod fabbed up last weekend. Will try and get the drag link done this weekend. May even get the hubs and tires on and it sitting on it's own weight for once in a few months.. Will see what happens.
Build Thread
Unread 04-24-2014, 01:35 PM   #853
crockett07
1992 XJ Cherokee
Lookin good. Did you get the truck straightened out
Unread 04-24-2014, 01:45 PM   #854
Rockdrummer93
Picking her up tomorrow with a freshly built tranny!
Build Thread
Unread 04-24-2014, 02:14 PM   #855
crockett07
1992 XJ Cherokee
Originally Posted by Rockdrummer93
Picking her up tomorrow with a freshly built tranny! Sent from my iPhone using JeepForum
Woot woot. Back on track!
