Rockdrummer93's 2001 XJ build - Page 48 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 09-22-2013, 08:29 AM   #706
Rockdrummer93
Originally Posted by Vonguido
Off topic but is that some ammo in that wood case I spy behind that transfer case lol. Loving the build by the way man. Keep up the solid work.
Thanks man! Yeah it's an old mortar case I believe.. Use it to hold my straps and what not
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2013, 03:38 PM   #707
Rockdrummer93
Frame plates came in today! Just a matter of time now for when I pull her in the garage and start tearing her down.. Was getting some transmission fits today. Wouldn't shift out of first, but after playing with a scanner for a little bit got it fixed but I don't know for how long.. I guess we'll see
Build Thread
Unread 09-30-2013, 06:49 PM   #708
Rockdrummer93
Pulled the Jeep in the garage this evening and starting tearing it down.. Going to work on it a little bit here and there through the week and most of the day on the weekend.. There is a Durhamtown trip coming up at the end of october I'm going to try and have it ready for but we'll see..
Only going to be able to get 1.5" out of it instead of the 2" I had thought..
Build Thread
Unread 10-01-2013, 07:22 PM   #709
Rockdrummer93
Got a little more done with the XJ today.. Since I noticed I couldn't get more then 1.5" of stretch out of the leaf perches I have. I ordered a set of ruff stuff 2+ perches, which will give me 1-3" of stretch off the bat. So pulled the axle today so when they come in I can have them installed. Also started with the rear lower cut and fold. Was only able to get one side semi done. Ran out of cut off wheels and need some rivets to finish.
Build Thread
Unread 10-08-2013, 12:19 PM   #710
Rockdrummer93
New brackets came in yesterday. These things are extremely beefy and I'm quite pleased with them.. Dropped the axle off yesterday as well to have them installed.. should have it back today and possibly back under the jeep by tonight..
Fit in the back of the TJ
Build Thread
Unread 10-08-2013, 04:58 PM   #711
crockett07
1992 XJ Cherokee
Those brackets do look beefy! I would think that the way they're built would put more leverage on the springs, causing axle wrap. I'm no engineer by any means though, I'd keep an eye on that
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 06:46 PM   #712
Rockdrummer93
Yeah I've taken that into consideration.. I called ruffstuff before I ordered them and talked to one of their reps. From what he said there were no known issues with axle wrap. They are 8" long, longer then the leaf pads I had on there by at least 4" so I'm sure I won't have a problem. But we'll see
Build Thread
Unread 10-09-2013, 07:47 PM   #713
Rockdrummer93
Got the axle back today and back under the Jeep. Haven't got everything hooked back up yet just enough to sit it on its own weight to get an idea of where the tires sit so I can start cutting.. Going to be taking my half inch block out since these brackets sit a good bit higher then the old ones. My only issue is that RuffStuff didn't do a very good job tapping the plates.. I had to spend about an hour re-tapping and cleaning up the threads. Luckily enough for me my old boss had a 5/8 18 tap he let me borrow, I would have hated to actually have to buy one that big.. Other then that Im pleased with these leaf brackets so far.. Won't do a full review till she's all finished and Im driving it again..
Teaser pic
Build Thread
Unread 10-11-2013, 02:36 PM   #714
Rockdrummer93
Well started cutting today.. Almost done with the passenger side. Just need to get a filler piece and re attach everything good.. Then will start on the driver side, I got a feeling that side will be a little more work with the filler neck being over there and all but we'll see. Im going to clean the up a little but not going to put too much effort into it because my armor will cover it all up anyway..
Build Thread
Unread 10-12-2013, 02:52 AM   #715
MOBBiN
Mall Crawler Level 3
MOBBiN's Avatar
Looks good! I like the rear wheel wheels opened up like that. How do the u bolts work with the new mounts not being over the center of the axle?
Build Thread
April 2014 & 2015 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 10-12-2013, 06:56 AM   #716
Rockdrummer93
There are no U-Bolts now. Just bolts into a plate on the leaf perch.
Build Thread
Unread 10-12-2013, 07:12 AM   #717
Rockdrummer93
Got a lot of the welding done last night. All thats left on the passenger side is to burn the shock hoop in and armor. Will start on the driver side sometime today. Going to make a cardboard template of my armor today as well so I can take it to the fab shop to have that cut. Found out yesterday my taillight housings won't ship out till next thursday... Hopefully going to have it drivable again by mid to the end of next week. Was able to get enough out of my driveshaft to get it to my buddy's shop last night to do the welding. Will most likely be pulling it out and taking to carolina driveline to get lengthened.
Build Thread
Unread 10-12-2013, 08:36 PM   #718
Rockdrummer93
Got the driver side done today.. Was a lot harder then the right side with the filler neck being there. Pretty much finished with the whole thing just a few bits and bobs to get done. Going to clean it up and seal all the holes up tmm and then monday or tuesday have my armor made and my driveshaft extended.
Build Thread
Unread 10-13-2013, 10:40 PM   #719
Rockdrummer93
Got it back on all fours today. Going to make the armor template tomorrow morning and take it over to the fab shop so they can get started. Still needs a little bit of working to get perfect. So far the verdict is still out on if it turned out to my standards or not.. Won't really know that till I get the armor on and it lowered a bit. Here are the only pics from today...
Build Thread
Unread 10-14-2013, 05:13 AM   #720
crockett07
1992 XJ Cherokee
I like it! Looking forward to seeing it cleaned up
