Rockdrummer93's 2001 XJ build - Page 41 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineCHASSIS SAVERô Labor Day 2 for 1 Sale!!!JKS Flex Connect in Actions!
Unread 03-16-2013, 07:31 AM   #601
Project1
Originally Posted by Rockdrummer93 View Post
Bolt on? Ive got to weld these on lol
First you hold them in place then put the bolts in where your cross member would bolt to .. that holds it in place. Then in the rear you floor jack it up until its in the right position, then weld in. Ill see if I can find a pic.
Project1 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2013, 07:34 AM   #602
Project1
not the best pic.. but look at were the cross member bolts go and you can see the bolts in there.. Then the stiffener bends where there are the two relief cuts .. so keep jacking it up until it fits perfect.
2nd pic is from EricXJ's rig
Unread 03-16-2013, 07:35 AM   #603
Rockdrummer93
I understand what your saying.. Yeah cant wait to get them on next weekend. Though I am a little Jeeped out right now after a two day axle swap on my buddy's TJ
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2013, 07:39 AM   #604
Project1
oh yea .. axle swapin sucks lol ... Yea I stocked to see yours on,and see how you say they feel. I need to redo my roof rack and then a few motor things ... then its stiffener and slider time.
Unread 03-21-2013, 07:48 PM   #605
Rockdrummer93
Well started on the Jeep today.. Not too happy right now. I went to Advance auto parts to get a tranny mount. Well they did have one for an 2001 so I got one for 97-99 thinking "oh they didn't change anything" well apparently I was wrong! the mount bolted up to the tranny but the crossmember studs were off set. The old tranny mount was shot so I cant put it back on. Going to Napa tomorrow to see if they have one. Then stripping the frame and welding on the stiffeners.
Build Thread
Unread 03-22-2013, 07:33 PM   #606
Rockdrummer93
Well thats a wrap on another day of work. Not completely finished. Got the passenger side pretty much done, just need to grind and paint the driver side. Still waiting on a tranny mount, went to Napa this morning they had one but wouldn't be there till the next morning so I'll get that then.
Build Thread
Unread 03-23-2013, 05:40 AM   #607
Project1
Man you made that look purdy .. REALLY clean work .. nice job man
Unread 03-23-2013, 05:59 AM   #608
Rockdrummer93
Thanks man! I'll get and post some better pictures sometime today.
Build Thread
Unread 03-23-2013, 07:01 AM   #609
MOBBiN
Web Wheeler Level 2
MOBBiN's Avatar
Do the stiffeners go around the all 3 sides of the frame rail? or just the outside and bottom of the frame rail?
Build Thread
April 2014 & 2015 COTM
MOBBiN is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 07:17 AM   #610
Rockdrummer93
Just the outside and the bottom. It would be possible to put them on the inside on the passenger side of the Jeep but in order to do it on the driver side you would have to pull the brake, fuel and vacuum lines away enough to clean and weld.
Build Thread
Unread 03-23-2013, 07:29 AM   #611
crockett07
1992 XJ Cherokee
All three sides really aren't necessary either. Just the bottom and the one side is a huge improvement from what I hear
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 07:30 AM   #612
Rockdrummer93
Yeah same. I cant wait to get it back together and see how she rides.
Build Thread
Unread 03-23-2013, 07:33 AM   #613
Project1
So.. how does it drive different .. what do you think?
Unread 03-23-2013, 07:36 AM   #614
Rockdrummer93
Will let ya know probably by the end of the day. went and picked up my tranny mount this morning. Only 10 bucks too, cant beat that!
Build Thread
Unread 03-23-2013, 07:42 AM   #615
MOBBiN
Web Wheeler Level 2
MOBBiN's Avatar
Right on, that's what i figured. I wanted to ask someone with first hand experience.
Build Thread
