Rockdrummer93's 2001 XJ build - Page 40 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!Save 17.76% for the 4th of july with ruffstuff specialties
Unread 02-27-2013, 05:53 PM   #586
Rockdrummer93
Originally Posted by biggn235
We are bringing two point-and-shoot cameras, one can also record in HD. I'm going to check out either a Flip or a Playsport camcorder from my university library too. I'm definitely going to be making some videos haha. If my girlfriend comes I'll have a dedicated camera person haha.
Awesome!
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 04:34 PM   #587
Rockdrummer93
Daystar shock stops came in today. Glad I was still able to find a set. Spent about an hour to get them on because I was too stubborn to buy the little tool. truth is you don't need it unless your doing a lot of them.
Build Thread
Unread 03-01-2013, 10:10 AM   #588
Rockdrummer93
Got the shocks installed today. I noticed that my front mounted shock (right side) has less up travel then the rear mounted shock (left side). after some investigation I noticed that when the high clearance shock mounts where installed they were mounted flat with the pinion and with the pinion rocked back the rear mounted one is lower then the front. Went by foothills and talked to the guy there and he said he could roll the front one down a little or just install TJ style shock mounts. Im just going to let them figure it out next week and while they have it just have him fix the breather nipple as well.
Build Thread
Unread 03-02-2013, 06:25 AM   #589
Project1
those are an awesome idea... love em
Project1 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2013, 07:47 AM   #590
Rockdrummer93
Thanks!
Build Thread
Unread 03-06-2013, 02:58 PM   #591
Rockdrummer93
Took the Jeep to Foothills 4x4 today to get the shock mount moved. While they had it they moved the breather nipple. I also broke down and ordered the frame stiffeners, went with H.D. Engineering. Going to try and install them the week after next, though we'll see.
Build Thread
Unread 03-06-2013, 07:31 PM   #592
onesmartdonkey
Hey buddy! Nice Jeep!
onesmartdonkey is offline   Reply With Quote Quick reply to this message
Unread 03-06-2013, 07:56 PM   #593
Rockdrummer93
Well thanks Jordan!
Build Thread
Unread 03-12-2013, 01:26 PM   #594
Rockdrummer93
Frame stiffeners came in today. Will probably get to them next week. Hopefully will have them on and ready for Uwharrie.
Build Thread
Unread 03-14-2013, 06:51 AM   #595
Project1
stiffener is nice! looking forward to seeing how you like it once it's on.
Unread 03-14-2013, 07:27 AM   #596
Rockdrummer93
Yeah I can't wait to get them on.. I am a little nervous about it but that will get dealt with when I actually go to install them.
Build Thread
Unread 03-14-2013, 10:28 AM   #597
Project1
I know .. I need to get some sooner than later, before I do a slider. Its just getting all that undercoating off that sounds like a huge pain in the @$$. Have to keep us posted on how this goes. I think when I do mine, I'm going to drill a few holes and bolt them in first and bolt them in, with some big washers on the inside to help distribute the weight. Then weld the rest, so it will be bolted though and welded, which will also make it easier for install. I'm going to go with the same stiffener as you.
Unread 03-14-2013, 10:37 AM   #598
crockett07
1992 XJ Cherokee
If you have a simple floor jack it will save you a lot of time and effort then drilling holes and bolting it on
crockett07 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2013, 02:31 PM   #599
Project1
I think you have to use one.. You have to bolt them in then jack it up until they are bent to fit nice and and tight .. then weld them in
Unread 03-14-2013, 07:58 PM   #600
Rockdrummer93
Bolt on? Ive got to weld these on lol
Build Thread
