Rockdrummer93's 2001 XJ build - Page 37 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO TeraFlex JK 2/4 Door 2.5" Lift Kit!! DEALS AT ROCKRID
Unread 01-10-2013, 05:30 AM   #541
Rockdrummer93
Originally Posted by Project1 View Post
good build tread too, I started on page 1, loved the pics
Thanks again. Much appreciated!
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 01-27-2013, 08:38 AM   #542
Rockdrummer93
Stumbled upon a hp44 out of a 73 f100 with weld on wedges. Will probably be sitting in the garage for while but we'll see.
Build Thread
Unread 01-28-2013, 06:02 AM   #543
Project1
nice axles
Project1 is offline   Reply With Quote Quick reply to this message
Unread 01-28-2013, 06:03 AM   #544
Project1
bet your stoked to get those : )
Unread 01-28-2013, 08:11 AM   #545
Rockdrummer93
yeah I am! I still can't decided whether to shorten it to match the rear, re tube the rear to match the HP44 or rebuild the D60.. I rather go with whats cheapest. Ideally Id rebuild the D60 but the problem with that is since its a 16 spline axle, Id have to dump a ton more money into it to get 35 spline.
Build Thread
Unread 01-28-2013, 11:40 AM   #546
Project1
man i got back and forth on that a lot. Wider is realllllllly nice, but so much I find my self just fitting between stuff, and squeezing by things, If I was much wider I wouldn't find a lot of places I want to go.... so man tough call but both have good benefits.
Unread 01-28-2013, 02:33 PM   #547
Rockdrummer93
Stopped and talked to the guys at foothills 4x4 today. They said that re tubing my rear 44 wouldn't be worth the money and trouble. They could narrow my HP44 for like $250. or they could sell me a matching width rear 44 they had laying around and I could just swap the guts out of my 44 into it and match it with the HP44. I'll have to buy parts for the HP44 regardless. Its not like Id be going extremely wide only like 1-2" on each side, but if Im going to go through the hassle of another axle swap I might as well go wider for the added benefit. Im still not extremely sure though.. I'll probably just start ordering parts and see where Im at when Im ready to build.
Build Thread
Unread 01-28-2013, 06:15 PM   #548
Project1
Yea .... Grab the new 44 and go wider for sure .... Damn that's going to be really nice ... Can't wait to see
Unread 01-28-2013, 06:24 PM   #549
Rockdrummer93
Yeah should be.. now that I have the front housing.. Im going to try and have them done by or at the beginning of the summer. So we will see. First I need to get some frame stiffeners on, that will be the first. Then will start gathering parts for the HP44. Will probably not be going all out to start with. Just ordering the bare of what I need to get it under the jeep, Shafts, gears, brackets, knuckles and outer assemblies.
Build Thread
Unread 01-28-2013, 06:43 PM   #550
Xjoutsider
I narrowed my 44 to j truck width which is 65 wrms to wrms goes good with my late model Isuzu 44 which is 63.
Xjoutsider is offline   Reply With Quote Quick reply to this message
Unread 01-28-2013, 06:51 PM   #551
Rockdrummer93
Yeah its still all up in the air. The way Im looking at it now is if the 4x4 shop still has that matching width 44 when Im ready to swap and I have the money I'll get it. if not I will just narrow it my HP44. Id like it to be a little wider but its not at the top of my list.
Build Thread
Unread 01-31-2013, 06:15 PM   #552
SCchillipepper
Damn i stop checking your thread and you go pick up some big boy axles. HPd44 looks sweet, wider is better unless you go crazy. If you stay with 35's a sixty might not be necessary but it would be ready if you go to 37's.
1998 TJ 35's Metalcloak Front Fenders 3" Currie Springs 4.88 Spartan Rear D44 front HPD30 under construction.
[URL="http://www.jeepforum.com/forum/f22/lake-murry-build-1144006/index12.html"]My Build Thread[/URL]
SCchillipepper is offline   Reply With Quote Quick reply to this message
Unread 01-31-2013, 06:26 PM   #553
Rockdrummer93
Man where have you been?! Yeah Im not using the D60 anymore.. Atleast not that one. Its a 16 spline and from what Ive heard it will cost me more then I want to spend to convert it to 30 or 35 spline.. Ive been told that a beefy set of 44s will handle 37s with easy. Especially the way I drive. In all honesty Im still not sure what Im doing.. Im just going to wait till have enough money saved up and just go from there. Plus I found out today that I'm going to have to break open my T-case because its leaking and I noticed some play output shaft. So i need to figure out what that is.. Now go and update your build thread! I know you've done more then whats on there now! We got a Uwharrie trip planned early April. Be ready!!
Build Thread
Unread 02-03-2013, 11:09 AM   #554
Project1
a lot of people run 37's and good 44's with good luck .. and their lighter than the 60 so not a bad bet ... however the 60 has much stronger components steering wise... so if you want to go hydro... that's something to think about before you start building... it cost a lot of $$$$$ to build the 44 for hydro
Unread 02-03-2013, 12:53 PM   #555
Rockdrummer93
I probably won't be going full hydro. Have been thinking about hydro assist but thats about it. I hope to have something figured out by time summer starts. Would be great to have the axle(s) redone before the coal creek/windrock trip Im trying to get planned this summer. I have a few things in the works that might get me enough cash to get it done, but nothing for sure yet. We will just have to see.. Y'all will be the first to know when I start.
Build Thread
