Rockdrummer93's 2001 XJ build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-26-2010, 05:43 PM   #16
Rockdrummer93
11/4/2010: Bought some of AJs Offroad Super Rockrails. Coated them with spray on bed liner for a non-slip finish. These things are very solid and tough, I highly recommend them.
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 11-26-2010, 05:44 PM   #17
Rockdrummer93
Originally Posted by jeg57 View Post
I like that flashlight mount. nice build so far.
Thanks
Build Thread
Unread 11-26-2010, 05:45 PM   #18
Rockdrummer93
11/9/2010: Front inner fender work. Did the cut-n-fold to the inner fender. I was reading a forum and saw that some one used a pool noodle to block off water and mud from getting to the door then into the cab. So I did it. Just used a normal pool noodle, cut it in half, shaved it down a little, stuffed in the fender then used Great Stuff insulation foam to fill in the gaps and hold it in. After that I undercoated them with Rust-Oleum Professional rubberized undercoating.
Build Thread
Unread 11-26-2010, 05:47 PM   #19
Rockdrummer93
11/12/2010: Finished my homemade sway bar disconnects. I would have bought them and will most likely end up buying better ones, but i didn't not want to waste the money on sway bar links that stop at 3 inches of lift when I am planning to go bigger. Just bought some hitch pins from Lowes, had to use a pitman arm puller to get the studs out but after that it went pretty easy. On the top just drilled a hole through a stuck a hitch pin in and it worked fine.
Build Thread
Unread 11-26-2010, 05:48 PM   #20
Rockdrummer93
11/20/2010: Made a Hi-Lift rack mount today. I think it was pretty innovative. I took the old U-bolts from when I added a the rear block. Bought a piece of 3/16"x2"x3' steel strip from Lowes, cut it down to the measured lengths, drilled a half inch holes. Started to paint them when I ran out of black paint (thats why two of the plates are white). Then put them on.
Build Thread
Unread 11-26-2010, 05:51 PM   #21
Rockdrummer93
The BMW Trails
3/6/2010
Build Thread
Unread 11-26-2010, 05:54 PM   #22
94Wrangler4L
Nice write up but can I see what screws you used to mount the CB?
94Wrangler4L is offline   Reply With Quote Quick reply to this message
Unread 11-26-2010, 06:01 PM   #23
Rockdrummer93
I used these ^^ from wal-mart. I had to open up the holes, cut the bolt down a little, take the visors off and shove my hand in between the head liner and the roof to open them up. after i tightened them, its fairly solid. It shakes a little on the trail, and moves with the headliner so as long as i don't pull on it, it isn't going anywhere
Build Thread
Unread 11-26-2010, 06:03 PM   #24
Rockdrummer93
The BMW Trails
4/3/2010
Build Thread
Unread 11-26-2010, 06:10 PM   #25
Rockdrummer93
Gulches ORV
6/19/2010
Build Thread
Unread 11-26-2010, 06:12 PM   #26
Rockdrummer93
this is everything I have done to it thus far. Everything past this post is up to date
Build Thread
Unread 11-28-2010, 10:48 AM   #27
Rockdrummer93
Put an ammo box in today, it was an early Christmas present from my dad.
Build Thread
Unread 12-01-2010, 01:01 PM   #28
Rockdrummer93
Went wheeling in the mountains not to long ago...
Build Thread
Unread 12-01-2010, 07:53 PM   #29
LiftedJeep90
1990 XJ Cherokee
Thats a sick XJ man props
LiftedJeep90 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2010, 08:46 PM   #30
Rockdrummer93
Thanks man
Build Thread
