Rockdrummer93's 2001 XJ build - Page 17 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Rockdrummer93's 2001 XJ build
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 08-14-2011, 10:15 AM   #241
Jeepman27
Originally Posted by Rockdrummer93 View Post
Who's sexy TJ is that? ^
2001 TJ, 3" Susp, 35's, Trimmed Fenders, Tire Carrier, CJ Tailgate
[URL="http://www.jeepforum.com/forum/f22/2001-tj-safe-1305760/#post12741531"]The Build Thread.[/URL]
___________________________________________
[U][B][SIZE="3"]STOLEN:[/SIZE][/B][/U] 1998 TJ, 2.5" Susp, 1" Bl, 33 KM2's, Tube Fenders, Belly Up, Winch, Stinger, LED Tail Lights, Frameless Top
[URL="http://www.jeepforum.com/forum/f22/jeepman27s-98-tj-daily-driver-1177276/"]The Stolen Jeep Thread.[/URL]
Slow, Slow, Slow.. 89 MJ, 31 Wrangler MT's
[URL="http://www.jeepforum.com/forum/f22/89-comanche-garbage-can-1259303/"]Comanche Build thread.[/URL]
Jeepman27 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2011, 10:23 AM   #242
JerzeyBoyWJ
2003 WJ
xj is looking good man... were you at a 2 inch before?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 08-14-2011, 10:33 AM   #243
njfreekshow
I had the same problem with the alignment pin on mine cause I had to buy a longer ones for my lift blocks.. so I ended up having to open up the hole a little but on the leaf perch till the leafs sat down the way they should.. as for the u-bolts my lift came with 2 sets.. but I ended up using the ones I had cause they were basically brand new and longer then the ones that came with the lift.
drilling the perch seems to be the best idea, but i think i might use the stock U bolts and plate until i make or buy new ones. my lift has been a headache for me and then make matters worse my wife's TJ has no working brakes lol
99 XJ Sport with a 3.5" Rusty's Suspension lift on 31x10.5 Pro Comp MTs
08 WK Laredo 3.7L
njfreekshow is offline   Reply With Quote Quick reply to this message
Unread 08-14-2011, 11:24 AM   #244
Rockdrummer93
I dont know.. I guess so even though I could have sworn it was 3"
Yeah that sucks.. but yeah the stock u-bolts should be fine for the time being.. good luck with it
'01 XJ, HP44, D60, 106" WB & 37" Blues
2014 Cherokee Of The YEAR
Build Thread
OffroadSC
Rockdrummer93 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2011, 12:22 PM   #245
cherokeej
Did you run Daniel trail at Uwharrie
Hang on, I want to try something
Build Thread: http://www.jeepforum.com/forum/f22/blue-genie-1110176/
cherokeej is offline   Reply With Quote Quick reply to this message
Unread 08-14-2011, 12:43 PM   #246
Rockdrummer93
I did not.. At the time I wasnt really in the mood for tearing anything up so I parked and road with my dad. I will next time though
Build Thread
OffroadSC
Unread 08-18-2011, 08:32 AM   #247
Blue00XJ
Looks great man.
"I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it." - "A Few Good Men"
'00 XJ 6.5" Rusty's short arm, full 6.5" leaf with 1.5" Shakles, 1" T-case drop, Custom rear shaft, Nate's Front/Rear bumpers, Hella 500 lights, Rusty's HD tie rod conversion, Steering box brace, Drilled/Slotted roters up front, 33" BFG T/A KO
Blue00XJ is offline   Reply With Quote Quick reply to this message
Unread 08-18-2011, 05:05 PM   #248
Rockdrummer93
Originally Posted by Blue00XJ View Post
Looks great man.
Thanks!
Build Thread
OffroadSC
Unread 08-18-2011, 06:47 PM   #249
redrubicon11
just need mine in the picture of all three of us
redrubicon11 is offline   Reply With Quote Quick reply to this message
Unread 08-18-2011, 06:56 PM   #250
Rockdrummer93
you mean this one?
Build Thread
OffroadSC
Unread 08-19-2011, 09:30 PM   #251
Rockdrummer93
well been trying to recover from the lift.. tried my dad's 33s on for size while he is out of town.. started to hear some sound in the rear axle shortly after the lift was installed.. pulled the cover to see what would fall out and nothing did.. confused me a little but I'll figure it out.. I did however found another good use for the rock lights when working in the dark
Oh and a little something I was working on at work last week
Build Thread
OffroadSC
Unread 08-20-2011, 08:27 PM   #252
Rockdrummer93
While I had the cover off I decided to paint it to match the front one. I am still confused about my axle. I am starting to think it might be a pinion bearing. I really hope not, but if so I will probably not be fixing it and just upgrading to a 44 or 8.8 or pulling another 8.25 from my local you-pick-it lot and throwing it under. Really hope I can find a XJ 44 sometime soon but with my luck I doubt it.
Messing around a little
Build Thread
OffroadSC
Unread 08-21-2011, 01:53 PM   #253
BlakeDGKleavitt
1997 XJ Cherokee
Gulches ORV
6/19/2010
Where did u get the skid plate and how much?
BlakeDGKleavitt is offline   Reply With Quote Quick reply to this message
Unread 08-21-2011, 03:18 PM   #254
Rockdrummer93
The front skid? I got it at a junk yard for like $15.
Build Thread
OffroadSC
Unread 08-21-2011, 04:39 PM   #255
redrubicon11
you mean this one?
thats it and hope you get your problems fixed man
