'rock crawling go-cart' or something - Page 8 - JeepForum.com
 4Likes
post #106 of 6576 Old 04-01-2009, 10:25 AM Thread Starter
Imped
Imped's Avatar
Just got the call that some large tires are in my garage. Unfortunately I'll be on campus all day. This is torture.
OlllllllO
IndyORV
Imped is offline
post #107 of 6576 Old 04-01-2009, 08:05 PM
jackbauersmom
updates??????
i'm so tired of being tired, sure as night will follow day, most things i worry about, never happen anyway
-petty
jackbauersmom is offline
post #108 of 6576 Old 04-01-2009, 11:12 PM
Dmcastino
I just talked to him, he didn't have time to get the tires mounted today and apparently he broke bolts in the rear swaybar and in the yoke. So he will have to deal with getting those out tomorrow and go get the tires mounted. Man those stupid little hang ups are so frustrating when youre so close to the end of a build!
Dmcastino is offline
post #109 of 6576 Old 04-01-2009, 11:37 PM Thread Starter
Imped
Imped's Avatar
Dave's right...tonight sucked balls. While installing my driveshaft, I broke one of the small nuts off INSIDE of the yoke. Since I was getting ready to head over to my buddy Brian's to weld on the RK upper control arm frame mount supports, I couldn't let that stop me...so I drove over there in front wheel drive--on Dave's ^^ 27" stock tires--with 4.88s. Needless to say, first gear feels like 4 low. So, we spent all this time getting the nut out and not a quick weld job. The jeep will stay parked there for tonight and I'll mess with it tomorrow. I'll be going to get the tires mounted and balanced tomorrow morning and go to pick up a tap in order to clean out the rear sway bar nuts and yoke threads. With that done, everything will be ready to go. I still have to drop the gas tank and drill out a couple new holes to reinforce the bumper, so hopefully I can move fast tomorrow.
OlllllllO
IndyORV
Imped is offline
post #110 of 6576 Old 04-02-2009, 12:04 AM
jackbauersmom
i have an extra set of rear frame tie ins for the bumper. if you want they are yours.
-petty
post #111 of 6576 Old 04-02-2009, 07:49 AM
RockRodHooligan
RockRodHooligan's Avatar
So I just got a call from him, he's at the tire shop getting the tires mounted, and was informed by the shop that 2 of the tires are 35x12.5r18's, and the other 3 are what he ordered, 35x12.5r15's.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #112 of 6576 Old 04-02-2009, 10:42 AM
Dmcastino
More updates, the correct tires are being shipped from a Discount Tire in Minnesota to Noblesville. DONT GIVE UP HOPE CONNOR! YOU ARE SO CLOSE!
post #113 of 6576 Old 04-02-2009, 11:23 AM
gribbles
can't go wheelin tomorrow though....bummer
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #114 of 6576 Old 04-02-2009, 11:31 AM Thread Starter
Imped
Imped's Avatar
Thanks for filling in the blanks mike....so yeah, I get to discount and while we are unloading the tires, the manager says "this one is for an 18 inch wheel, and so is this one." I say, "WHAT??". So we called around for about 20 minutes before he finally got ahold of a discount in Minnesota with 4 of them....I'm getting two. I have yet to hear from Casanova but he owes me some cash and free Fedex shipping tags.
OlllllllO
IndyORV
Imped is offline
post #115 of 6576 Old 04-02-2009, 01:22 PM Thread Starter
Imped
Imped's Avatar
Alright, Casanova will take care of things. He is sending fedex to pick up the tires and replenishing my credit card with the price of the two tires.
OlllllllO
IndyORV
Imped is offline
post #116 of 6576 Old 04-02-2009, 04:00 PM
gribbles
thats good bro, you'll be missed tomorrow
2007 WK CRD
gribbles is offline
post #117 of 6576 Old 04-02-2009, 04:17 PM
CCJ
Impede, I spoke to some "sources" .... Needless to say I can't get my hands on ANY J-arm JJ's. I has failed. Currie has stopped production.
Glad your almost done with the build though bro.
CCJ is offline
post #118 of 6576 Old 04-02-2009, 06:13 PM
bandit455
then just go with the regular arms like imped and the others do!
bandit455 is offline
post #119 of 6576 Old 04-02-2009, 06:23 PM Thread Starter
Imped
Imped's Avatar
Just go with the regular arms man...after getting about 10 minutes behind the wheel today, they rock.
SUMMARY OF TODAY: Today went both very well and bad. After the tire ordeal, which is all taken care of, I got the garage all cleaned out and powerwashed. I bought a tap and cleaned out the yoke and rear sway bar nut threads...worked like a charm. Bolts threaded right in without drama. Got everything tightened up, got the RK frame supports welded in (thanks Brian, you rock man), and took her for a drive. Here comes the bad news--I got the worst case of vibes I could have ever expected. I knew my pinion angle wasn't ideal but it's REALLY not ideal...and in case you're wondering what the pinion angle on a 2.5" lift, tummy tuck, SYE, and pig D44 is, mine is about 30 degrees!!! Very steep and the D44 forces me to use a short driveshaft (16 3/16"). My uppers are maxed out and I'm not willing to shorten the lowers anymore. I want wheelbase and I want this thing done right. So, after analyzing the problem, the only solution Brian and I could come up with is to cut off the truss and re-weld it at the opposite of the pinion angle so that when the axle yoke is pointing at the output shaft, the truss is then sitting square to the horizontal. This will allow plenty of adjustment in the uppers and allow me to run an adequate wheelbase. This really bummed me out but after thinking about it, there is no way I CAN'T do this...so tomorrow I will plug in the Ipod and earplugs and go to town for the 3ish hour journey to free up the truss. I'm wanting to get it welded back on Saturday or Sunday and be ready to go by the time the other two tires show up on Monday or Tuesday. I really hope this is the last bump in the road for this build. I've never been so physically and mentally exhaused....and I miss driving the jeep and wheeling more than words can express. Anyway, during my short vibe-filled drive (smoothed out at 50ish mph), this thing was a CHAMP. The ride is nothing short of amazing--quiet, no clunking or noise from the johnny joints, smooth and VERY tight....it feels like a European sports sedan. The suspension reacts to changes very quickly because of the no-slack design of the control arms. Minimal body roll even when turning hard....and according to Brian, the antisquat is enough that the rear end doesn't squat on acceleration but rather, it lifts a bit. Not sure how I feel about that but I'll give it a try. And with 4.88s and 27s, it's a peppy little beast. Even when going over the train tracks, over the curb into my driveway, and taking turns, I heard no metal to metal contact or sound of any kind....SUPER TIGHT. I'm very impressed. So, this really motivates me to get everything done right, including the rear axle. Wish me luck fellas, I have a long weekend ahead of me.
OlllllllO
IndyORV
Imped is offline
post #120 of 6576 Old 04-03-2009, 04:53 AM
winter117a
I shall drink to your success!
(No really, I am. I'm drinking a Sprite right now and just said "I wish Imped luck on his build this weekend!" while at work. I'm awesome. )
winter117a is offline
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
picture test x99j Jeep Picture Requests 2 10-23-2011 09:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 01:01 PM
test 94-91 Jeep Builds 5 11-04-2008 08:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 03:13 PM
