'rock crawling go-cart' or something - Page 367 - JeepForum.com
 4Likes
post #5491 of 6576 Old 10-28-2013, 04:49 PM Thread Starter
Imped
Imped's Avatar
Did your jeep have an aftermarket head unit when you bought it? The center studs also secure the anti-theft bracket for the stock radio. Someone may have removed the anti-theft bracket and failed to re-install the nuts.
Yes it did. That explains that.
It's amazing how much tighter the dash is now. I can push on it and it no longer budges. Lately, it's been the little things like that.
OlllllllO
IndyORV
Imped is offline
post #5492 of 6576 Old 10-28-2013, 06:24 PM
elclipo
I have a squeak like that but is not the bracket nuts. Mine are all there
It seems that it is the AC lines as they cross the firewall but am not 100% sure yet.
Semper Fi
elclipo is offline
post #5493 of 6576 Old 10-28-2013, 07:10 PM
aw12345
Check the nuts that hold the heaterbox to the firewall, there are atleast 5 or 6 of them. The lines go through a big foam/ rubber piece, doubt that makes noise
aw12345 is offline
post #5494 of 6576 Old 10-29-2013, 05:15 AM
Danno6102
Originally Posted by aw12345 View Post
Front fender out of a singe steel tube clad with aluminum skin isn't a terribly bad idea and easy to repair when mangled
Nice to know Art & I are on the same page.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #5495 of 6576 Old 10-29-2013, 06:11 AM
elclipo
Thanks for the tip. Will be looking at that today
Semper Fi
elclipo is offline
post #5496 of 6576 Old 10-29-2013, 11:30 AM
G Beasley
I'm not too worried about the hood and fenders right now. When I'm bored with nothing else to do, maybe I'll change it up.
On another note, I've been going through and really cleaning this thing up recently--cutting what I didn't like off the cage, cleaning up the fuel cell plumbing, adjusting the brake booster pushrod to take all of the slack out of the pedal, sealing up the soft top seams, etc. Adding to that, I've always had an intermittent dash squeak and it's driven me nuts for a long time. I finally decided to get down to business today and I found the source--apparently, the factory decided not to put nuts on 2 of the 4 upper dash retention studs. If you pull the defrost vent strip off you'll see M6 x 1.0 studs across the width of the tub that secure the main dash structure. The two outer studs had nuts but they were loose and the two inner studs were nutless. I picked up some M6 x 1.0 nylock nuts and some washers and torqued it all down. Tight, movement and squeak free dash.
Happy day.
I am going to check that this afternoon to see if thats where my squeak is coming from . Thanks for posting this .
G Beasley is offline
post #5497 of 6576 Old 10-30-2013, 04:12 PM Thread Starter
Imped
Imped's Avatar
I'm looking into new shocks. I'd like to stick with 11" travel in the ~17/28 compressed/extended length range.
I'm looking at Bilstein 5165's, which are perfect length-wise....and actually would provide me 11.6" total travel. The only problem is that they're only available in 255/70 valving, which I think will be a bit too heavy for my rear end.
I'm also looking into Fox 2.0 smooth body remote res's. On Poly Perf, there are no valving details.
Any input? Light rear end, standard front end.
OlllllllO
IndyORV
Imped is offline
post #5498 of 6576 Old 10-30-2013, 04:29 PM
kyle_craig
My current 255/70 are too heavy for my rear end. Have you considered some 11" 5125s with 170/60 valving?
kyle_craig is offline
post #5499 of 6576 Old 10-30-2013, 04:31 PM
JJeeper09
I believe he has those now? I'm not positive though. That is what I would like..
JJeeper09 is offline
post #5500 of 6576 Old 10-30-2013, 04:41 PM Thread Starter
Imped
Imped's Avatar
Yep, that's what I run in the rear right now. I run the heavier valving in the front. They're OK but I know it could be better.
I'd like to experiment with something else.
Anyone know what kind of valving the Fox IFP remote res's come with from Poly?
OlllllllO
IndyORV
Imped is offline
post #5501 of 6576 Old 10-30-2013, 05:40 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by Imped
Yep, that's what I run in the rear right now. I run the heavier valving in the front. They're OK but I know it could be better. I'd like to experiment with something else. Anyone know what kind of valving the Fox IFP remote res's come with from Poly?
Mine are 40/60 what ever that converts to. The more I drive it the more I like it.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5502 of 6576 Old 10-30-2013, 06:06 PM
MO2500
Fox's default valving is 40/60 if not specified otherwise. You can order them with any valving you would like though.
If you want to get serious about the shocks, order Fox 2.0s and ship them to Wayne and let him valve them based on your specs. Better if he actually tuned with you but I bet he can get you valved better over the phone than choosing any factory available valving from fox.
Instagram: @omsmike
MO2500 is offline
post #5503 of 6576 Old 10-30-2013, 06:19 PM
JJeeper09
I'll take those shocks when you ditch them
post #5504 of 6576 Old 10-30-2013, 07:10 PM Thread Starter
Imped
Imped's Avatar
OK, good deal. I plan on talking to Wayne but I doubt I'll do it immediately. I'd like to run them as long as they're in the ball park then get them tuned later on so that I can compare the differences.
James, you've got them once I'm done with them. 255/70 front, 170/60 rear, both 11" travel.
OlllllllO
IndyORV
Imped is offline
post #5505 of 6576 Old 10-30-2013, 07:15 PM
JJeeper09
OK, good deal. I plan on talking to Wayne but I doubt I'll do it immediately. I'd like to run them as long as they're in the ball park then get them tuned later on so that I can compare the differences. James, you've got them once I'm done with them. 255/70 front, 170/60 rear, both 11" travel.
Just the rears, I'll swap the twelves to the front. I think they will be better there.
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
picture test x99j Jeep Picture Requests 2 10-23-2011 09:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 01:01 PM
test 94-91 Jeep Builds 5 11-04-2008 08:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 03:13 PM
