'rock crawling go-cart' or something - Page 363 - JeepForum.com
 3Likes
post #5431 of 6549 Old 10-02-2013, 01:17 PM
tyvanwie
Light weight baby!
tyvanwie is offline
post #5432 of 6549 Old 10-02-2013, 01:41 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Originally Posted by REDLYNER View Post
I can't see how your TJ is 3660lbs without you or doors (doors are 55lb each). I'm not accusing you of anything, I'm just saying I can't see it. I stripped everything out of mine, went with all aluminum armor, no doors, no top, 1/4 tank of gas and was still at 3990.
Where on earth did you shave another 330lbs? If I have that much weight hidden, I need to know the diet!!! That is insanely light, I bet it feels great whipping it around .
Serious? Cage and axles. Stock ones have to weight less than your spendy ones.
Imped, now I am curious. I will try and do the same since I have the LJ stripped down, alum armor and post rhinoplasty.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #5433 of 6549 Old 10-02-2013, 01:45 PM
MO2500
I can't see how your TJ is 3660lbs without you or doors (doors are 55lb each). I'm not accusing you of anything, I'm just saying I can't see it. I stripped everything out of mine, went with all aluminum armor, no doors, no top, 1/4 tank of gas and was still at 3990. Where on earth did you shave another 330lbs? If I have that much weight hidden, I need to know the diet!!! That is insanely light, I bet it feels great whipping it around .
I thought we were in the 4300s when tech'd at KOH without you or I in it? I might not be remembering that right.
I need to find somebody with a 4 corner scale around here. I'm worried about going over 4400 with my heavy axles. I'm trying to shed as much as I can from the rest of the jeep to keep it down. I'd hate to have to build another cage....
Instagram: @omsmike
MO2500 is offline
post #5434 of 6549 Old 10-02-2013, 01:48 PM
MO2500
Originally Posted by dayriesw
Serious? Cage and axles. Stock ones have to weight less than your spendy ones. Imped, now I am curious. I will try and do the same since I have the LJ stripped down, alum armor and post rhinoplasty.
The fabricated 9" center sections are lighter but the front outers are definitely heavier than the D30 stuff lol. His rear axle is definitely lighter than a D44 though.
Instagram: @omsmike
MO2500 is offline
post #5435 of 6549 Old 10-02-2013, 01:50 PM
JJeeper09
He has plexy glass windows.
JJeeper09 is offline
post #5436 of 6549 Old 10-02-2013, 03:03 PM
REDLYNER
REDLYNER's Avatar
Originally Posted by IEcrawlerTJ01 View Post
Winch. Less cage material. D30 outers instead of f450 stuff. No bumper hoop. Quite a few small things add up quick
I'm aware of the smaller things adding up. I was 3970'ish before I did any cage or axle swaps: IE Rubi 44's and Poison Spyder Cage.
Serious.
See above. And my axles were chosen because they are actually lighter than most setups. But again, see above, I was at 3970'ish with the typical modified TJ stuff.
We were 4330 on a 4 corner scale with the spare tire, 22 gallon fuel cell, highlift jack, door bars (very heavy), doors, window nets, pumper, gps bar, and gps. All of the Ultra4 stuff (including the spare) comes in around 300lbs- which means I daily drive around right at the 4k mark. Which is a HUGE difference from 3660.
Me saying I can't see how you are at 3660 is a knock on me, not on you Imped. I'm missing something here and just can't figure it out. Interested in wheeling in NC ? I need a good walk around of your rig.
Here's a shot of the jeep on the scale at roughly 4020lbs- pre fab 9's or any Ultra4 cage work. Armor is aluminum, and I had my doors on and subwoofer box in at the time. Doors and sub equal about 40 to 50lbs combined which would put me around 3970'ish.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #5437 of 6549 Old 10-02-2013, 08:19 PM
JJeeper09
Post up some good pics dude. I need some motivation
post #5438 of 6549 Old 10-02-2013, 09:08 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
nvrm, that was the subtracted weight of the doors and 180lb male
SEMPER FI
LifeProof is offline
post #5439 of 6549 Old 10-17-2013, 09:51 AM
g-rocc
Imped, I know this is going back a ways for you but when you installed the PSC steering gear did you have any clearance issues or difficulty getting it to mount back up to the frame? We made sure to shorten the steering shaft as PSC said to do but still having some difficulty getting all three bolts to line up.
g-rocc is offline
post #5440 of 6549 Old 10-17-2013, 01:44 PM Thread Starter
Imped
Imped's Avatar
None at all. You sure you have the Saginaw box with the late-model bolt pattern? It should have a spot for a fourth bolt, as well. If you have the correct bolt pattern you could open up the ID of the bolt bosses a hair to see if that gives you enough play to start them all.
OlllllllO
IndyORV
Imped is offline
post #5441 of 6549 Old 10-17-2013, 02:50 PM
g-rocc
Yeah I'm positive the box has the correct bolt pattern because thinking about that kept me up all night last night then I measured it first thing in the morning compared to my old box. I might end up opening up the bosses a little tonight if the fight gets to me enough. Thanks for the insight.
g-rocc is offline
post #5442 of 6549 Old 10-19-2013, 07:50 PM Thread Starter
Imped
Imped's Avatar
The girl joined the party today.
OlllllllO
IndyORV
Imped is offline
post #5443 of 6549 Old 10-19-2013, 07:59 PM
MO2500
Instagram: @omsmike
MO2500 is offline
post #5444 of 6549 Old 10-19-2013, 08:54 PM
kyle_craig
Dang!
kyle_craig is offline
post #5445 of 6549 Old 10-19-2013, 09:15 PM
zigsz71
Awesome! How long before she lets you get your hands on it?
/__l ,[____],_
l-----L -OlllllllO-
()_)__()_)--o()_)
'06 LJ Rubi on 35's and stuff
zigsz71 is offline
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
picture test x99j Jeep Picture Requests 2 10-23-2011 10:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 02:01 PM
test 94-91 Jeep Builds 5 11-04-2008 09:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 04:13 PM
