'rock crawling go-cart' or something - Page 358 - JeepForum.com
 3Likes
post #5356 of 6560 Old 08-15-2013, 01:00 PM
Danno6102
All arms are 1.5" solid 7075 aluminum hex bar. MC will be soon building RH/LH threaded aluminum arms out of the same material for TJ's but they'd also like to get into the custom-length business. They're still trying to determine if the material will hold up in LCA applications at lengths greater than factory TJ arms. Since my arms are a few inches over JK length, I figured I'll give them a shot to see if I can bend them. They're a little smallish for lowers so we'll see if I can make them last. If they don't hold up then I'll go another route for the lowers and keep the uppers.
My Savvy lower front arms are 1.5", stock length, & my passenger side is bent a little. Happened shortly after I put them on. I'm guessing you'll find they're way to thin, especially being longer than stock.
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #5357 of 6560 Old 08-15-2013, 01:11 PM Thread Starter
Imped
Imped's Avatar
My guess is it's just a matter of time before I bend a lower link......so when I get there, at least I'll know I can bend them. Then I'll get some built from 2.5" bar.
OlllllllO
IndyORV
Imped is offline
post #5358 of 6560 Old 08-15-2013, 02:07 PM
TanMan99
Thanks for that reply! It will be awhile before I am ready to do any suspension work so hopefully enough R&D will show what works and what does not.
TanMan99 is offline
post #5359 of 6560 Old 08-15-2013, 02:40 PM
gspup
The hex shape should give it more rigidity than the round savvy arms...but you never really know whats gonna hold up after repeated beatings on rocks.
gspup is offline
post #5360 of 6560 Old 08-15-2013, 03:55 PM
Sahara Surfer
Imped, you are running 10" travel Bilstein shocks on your rear outboarded setup with a 2.5" lift (My lift setup)on 35" tires(?). What is the model number/type of your rear shocks?
Sahara Surfer is offline
post #5361 of 6560 Old 08-15-2013, 04:25 PM Thread Starter
Imped
Imped's Avatar
Yes, I believe the hex bar will contribute to a higher yield point than round. How much is up for debate. Regardless, I'm expecting to bend the lowers so it's not gonna be an issue if it happens.
No, 11" travel on a rear frame that's not factory. The mounts are frenched into it.
"Lift height" is somewhere in the 2" range over stock.
37" tires.
OlllllllO
IndyORV
Imped is offline
post #5362 of 6560 Old 08-15-2013, 04:44 PM
IEcrawlerTJ01
Originally Posted by Imped
I'm expecting to bend the lowers so it's not gonna be an issue if it happens..
For someone that preaches, do it right the first time, you really are taking a step backwards.
Please, write me a riddle to the reason of why you're running these arms?
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #5363 of 6560 Old 08-15-2013, 06:28 PM
JJeeper09
Because he uses custom parts and tries new things unlike half this board.. Trying parts is how good parts become proven or not..
JJeeper09 is offline
post #5364 of 6560 Old 08-15-2013, 08:04 PM
aw12345
I have no problem bending 2" x 1/4" wall DOM on my lowers.
Seems to me the hard aluminum arms could do something worse then just bend. Might just want to carry atleast one spare if you feel like playing hard.
Just saying
aw12345 is offline
post #5365 of 6560 Old 08-15-2013, 08:16 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Just saying
Yeah because here in the South there is not a single Rockbouncer that is not running Aliminium arms.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5366 of 6560 Old 08-15-2013, 08:21 PM
MO2500
I bet none of those bouncers are running 1.5" lowers, probably more like 2.5-3.5" lol.
Doesn't matter though, Connor isn't driving an overweight jungle gym or killing hills, 1.5" might be a bit small for longer than stock arms, time will tell.
Instagram: @omsmike
MO2500 is offline
post #5367 of 6560 Old 08-15-2013, 08:22 PM Thread Starter
Imped
Imped's Avatar
This build thread wouldn't be 358 pages long if I stopped after the "first try."
That methodology applies to an entirely different demographic, one that happens to be the vast majority of the Jeep crowd that bolts up an aftermarket part.
If you haven't figured it out yet, I like to try different things myself, regardless of if the concept is 100% sound or not. How can I offer advice on what's right, wrong, good, bad or indifferent if I don't really know? I enjoy experimenting and trying new things, simple as that. I think it should already be obvious that I don't expect the lower links to hold up....but if they do, that's icing on the cake.
As per the usual, if you don't like how I go about things (and I'm well aware you don't) then don't post.
Just saying
Thanks Art, it's already covered.
And as usual, your input is always appreciated.
OlllllllO
IndyORV
Imped is offline
post #5368 of 6560 Old 08-15-2013, 08:27 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I did not read the link size, my bad.
You can't tell me they don't look fun though. Put 600-1000 hp in a swing set and give me the wheel, I will put a smile on your face you can't wash off.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #5369 of 6560 Old 08-15-2013, 08:43 PM
Sahara Surfer
37" tires.
Ok, at one point, didn't you run outboarded 10" travel Bilstein rear shocks with an old man emu lift? I seem to have read that in one of your older posts. Do you remember what model number the Bilstein shocks were?
My TJ-6 Build:
http://www.jeepforum.com/forum/f22/another-tj-6-build-1404548/
post #5370 of 6560 Old 08-15-2013, 08:45 PM
aw12345
Would love to drive one of those tree bouncers up a hill at full throttle atleast once. Should be a blast ping ponging of trees and whatever else is in the way
aw12345 is offline
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
timmytimm3
picture test x99j Jeep Picture Requests 2 10-23-2011 09:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 01:01 PM
test 94-91 Jeep Builds 5 11-04-2008 08:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 03:13 PM
