'rock crawling go-cart' or something - Page 298 - JeepForum.com
 3Likes
post #4456 of 6550 Old 12-19-2012, 01:30 PM
Bennettj13
Easier than tearing the transfer case apart... Pull the front shaft and drive in 4wd, see if the noise changes.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #4457 of 6550 Old 12-19-2012, 02:26 PM Thread Starter
Imped
Imped's Avatar
off topic but had a question when looking at your custom rear frame. Did you completely remove the evap canister in the passenger side wheel well? Or is it just modified and tucked up in there.
The canister hasn't been there for a long time. It was bypassed. The remaining assembly is tucked under the tub behind the axle.
I did that already a long time ago. If I remember right, there was no change but I should do it again just to refresh my memory. That completely removes the axle from being a possibility if that's the case. If it's the t-case input bearing or the trans output bearing it doesn't matter if I'm in 2 or 4wd, they're getting loaded either way. And I've got to pull my t-case anyway so it's not a big deal.
OlllllllO
IndyORV
Imped is online now
post #4458 of 6550 Old 12-19-2012, 04:39 PM
Bennettj13
Nm, I misread.
post #4459 of 6550 Old 12-19-2012, 04:59 PM
aparke4
just read through a lot of this thread- the end result is awesome. I am moving in a similar direction with my Tj- nice work!
aparke4 is offline
post #4460 of 6550 Old 12-19-2012, 11:13 PM
clintrivera
I had a whine like that. Turned out to be a loose pinon. Replaced the pinon bearings and all is good again.
clintrivera is offline
post #4461 of 6550 Old 12-20-2012, 07:05 AM Thread Starter
Imped
Imped's Avatar
Pinion is fine and as far as I can tell, so are the bearings. This whine has existed since before that 44 went in. I'm planning on pulling the rear shaft and going for a short spin tomorrow to remove the rear axle from the picture.
OlllllllO
IndyORV
Imped is online now
post #4462 of 6550 Old 12-20-2012, 09:06 AM
jermeyg
Yeah more than likely its your input bearing on the transfer case. It's not that hard to change out. Just make sure and get the right size bearing and a good quality one!
jermeyg is offline
post #4463 of 6550 Old 12-20-2012, 09:27 AM
clintrivera
The easy way to find out is the put the Jeep on jack stands and have someone put it in gear while you are underneath poking around (carefully) with a mechanic's stethoscope (or or a long screwdriver to your ear) to find where the noise is coming from. The drive shafts are going to transmit the sound all over the place, so where it sounds like it's coming from isn't necessarily where it is coming from. My bad rear pinion bearing sounded for sure like it was coming from the transmission.
post #4464 of 6550 Old 12-20-2012, 09:38 AM Thread Starter
Imped
Imped's Avatar
I'm just gonna use my buddy's front case half for free. He upgraded to a 241 so he's got a nice, clean 231 just sitting there. That bearing is $80 alone.
Did that last year. I literally couldn't tell where it was coming from and God knows I tried. I laid under there forever trying to determine where the noise was originating but I couldn't come up with a proven spot for the life of me.
I do remember it was silent with the tranny in gear and t-case in neutral. I could only get the noise under load. I don't remember other specifics so I need to do it again.
OlllllllO
IndyORV
Imped is online now
post #4465 of 6550 Old 12-20-2012, 09:47 AM
clintrivera
Did you use a mechanics stethoscope? If it's an input or output bearing, you can put the end of it very close to the bearing and hear exactly what's going on. Sometimes a screwdriver to the ear doesn't work great, plus the stethoscope blocks out all the "radiated" noise and just focuses on what the end is touching.
post #4466 of 6550 Old 12-20-2012, 09:52 AM
Sundowner
That's what was happening with the few bad pinion bearings and R/P noises that I've been a party to; that driveshaft acted like a tuning fork and the noises were coming from weird places based on...well, I don't know. The only thing that seemed common was that they didn't seem like they were coming from the rear end.
Did that last year. I literally couldn't tell where it was coming from and God knows I tried. I laid under there forever trying to determine where the noise was originating but I couldn't come up with a proven spot for the life of me. I do remember it was silent with the tranny in gear and t-case in neutral. I could only get the noise under load. I don't remember other specifics so I need to do it again.
I'll be interested to see what you come up with. If you've done all of these diagnostics already, then I would doubt the rear end as well.
Sundowner is offline
post #4467 of 6550 Old 12-21-2012, 07:46 AM Thread Starter
Imped
Imped's Avatar
Started to get some snow last night.
OlllllllO
IndyORV
Imped is online now
post #4468 of 6550 Old 12-21-2012, 11:41 AM
REDLYNER
REDLYNER's Avatar
Cool shot! The rig is looking good
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #4469 of 6550 Old 12-21-2012, 03:23 PM
WeldedUp
Thanks for the washer reservoir find. Mine works great!
As far as confessions go, I've been stalking your thread for a while now.
Love it.
WeldedUp is offline
post #4470 of 6550 Old 12-21-2012, 04:54 PM
Silver_Sport
Love it.
x2. Awesome Jeep!
robbybobby: duh bro- momentium.....i have my own special technique- haul Mother F-ng balls at the hill till i am standing alone at the gawd danged top......
Silver_Sport is offline
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
picture test x99j Jeep Picture Requests 2 10-23-2011 10:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 02:01 PM
test 94-91 Jeep Builds 5 11-04-2008 09:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 04:13 PM
