'rock crawling go-cart' or something - Page 219 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 'rock crawling go-cart' or something
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 03-15-2012, 02:56 PM   #3271
Bennettj13
I'm a big meanie head
Bennettj13's Avatar
Sackless. I knew I should have just welded those tubes on for you the other night. You weren't "debating" anything. Bastard.
::SELLING HALF OF MY JEEP::
http://www.jeepforum.com/forum/f33/?uid=152304
Bennettj13 is offline   Reply With Quote
Unread 03-15-2012, 03:15 PM   #3272
Imped
Balls
Imped's Avatar
Not true....was considering it.
Now go be a short, angry bastard in someone else's thread *****. :flipoff:
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 03-15-2012, 10:50 PM   #3273
idskot
Originally Posted by Bennettj13 View Post
There is no "finally took" with BB's. Either they work or they don't. Either you are going fast enough for centrifugal force to push them into the low spots or you aren't. There is nothing more complicated to them than that. It's physics.
Either way, I'm glad the shimmy is gone.
Love this thread...
But it's not centrifugal. It's centripetal.
idskot is offline   Reply With Quote
Unread 03-15-2012, 11:38 PM   #3274
Bennettj13
Bennettj13's Avatar
Connor, I'll be short and angry where ever I please until I find the one ring to rule them all. I still say you were just entertaining me while I was over there so you wouldn't have to hear it as bad. Either way, it'll look alright. You better flap those booger welds though. I was going to make these ones pretty for you this time. You can weld where no one will see. Until you know what you are doing, and it looks good, stop it. lol It'll flap out. Just don't let your OCD get overzealous or your **** will end up with flat spots like mine. I had to stop because I wouldn't have had any tube left.
Originally Posted by idskot View Post
Love this thread...
Quite the opposite bud. Centripetal: i.e. "center-seeking" IIRC
I was wrong once before... I divorced her though. It is early though.
Unread 03-15-2012, 11:45 PM   #3275
idskot
In my physics class, we've defined anything tethered to a central point with angular velocity centripetal.
Unread 03-16-2012, 12:20 AM   #3276
JJeeper09
Welds look okay. When I get a set I'll make them perfect so I have the option of not flapping them. But either way I will probably flap them
[URL="http://www.jeepforum.com/forum/f22/project-do-right-1147962/"][B]Rubicon Build[/B][/URL]
JJeeper09 is online now   Reply With Quote
Unread 03-16-2012, 01:03 AM   #3277
2000GrayTJ
Pretty sure you guys are both right, the centripetal force is exerted by the tire while the centrifugal force would be by the BB's , correct me if I'm wrong by any means. I'd even go as far as to say neither and say it's the angular momentum that "works" on the beads
Been following this build for a while, just re-read the first page and I must say Imped you have done things right. Not too many people have a 2" BB and 31's with rocker guards...just goes to show you are about simplicity and making do with what you have. Around here we have much stricter laws regarding tire coverage (and for a good reason, without mudflaps the roads would be downright hazardous) but I really like where you're going with the build. I only wish I could get the ~18 mpg you claim lol I'm getting <= 12 (mind you in the winter) with a <10k 4.0/AX-15/4.56/33x10.5's, gonna move up to 34" trXus and see what happens as the BFG's only measure about 31.5". Either way great work dude I'm stayin' tuned
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline   Reply With Quote
Unread 03-16-2012, 05:58 AM   #3278
Hendrix
TJ Truck?
Hendrix's Avatar
If it makes you feel any better, I took my time and welded mine nice and pretty with a MIG. Still ground them down and filled them. I gots about 15 years of welding EXP. And they still did not satisfy me enough to leave them alone.
Mine turned out awesome ground down a smoothed. Secret to knocking down just the weld is using a stone on the tops of the weld first attacking only the weld. Then flap the weld and smooth it into the tube. The way the top plate on the ROKMEN fenders is made you should have had enough valley to keep the weld in between the tube and top plate.
Rock on Garth....
Hendrix is offline   Reply With Quote
Unread 03-16-2012, 06:30 AM   #3279
Zjones1994
OneDayWheeler
Originally Posted by Hendrix
Rock on Garth....
Waynes world, waynes world, party time excellent!
1998 Chili Pepper Red Jeep
Check out my build!
http://www.jeepforum.com/forum/f22/t...build-1347318/
Zjones1994 is online now   Reply With Quote
Unread 03-16-2012, 06:45 AM   #3280
Imped
Balls
Imped's Avatar
OK, you bastards. I haven't taken a physics class in 4 years and I still remember this crap, at least I think so--centripetal force and centrifugal force are just equal and opposite reactions. The centripetal force is the force acting in the direction of the acceleration along the radius towards the center of the tire/wheel. The centrifugal force is the reaction to that.....it's the force moving away from the center of the tire along the radius. You can't have one without the other and the beads wouldn't stay put without that--Newton's 1st. Nobody's right, nobody's wrong, now shut up.
Thanks for the compliments Gray.
James, you should know by now that I don't care for people doing things for me but I do appreciate your input. If you want to come over and provide constructive criticism while I weld up the other one, that's cool and very welcomed. You know I want to learn as much as possible.....but I'm welding them. I bought the welder to do that and I looked forward to assembling these. If the first bead I ran looked like junk, I would've stopped. It didn't so I continued. I'm a noob at welding but you've got to remember that I've spent hours behind Marty's machine. The welds came out looking twice as good as the other set (that I didn't weld, mind you)......I'm not unhappy, I will be flapping regardless of how nice they look this time around.
OlllllllO
Float Test Build
IndyORV
Unread 03-16-2012, 07:46 AM   #3281
Bennettj13
Bennettj13's Avatar
I just want them to look good for you bud. You know I'm just poking at you. And my offer still stands on actually teaching you to weld. Hours behind a machine mean nothing. Hours of proper instruction are everything. I take that back. With enough hours behind a machine, working different metal thicknesses you can learn to produce quality welds through trial and error. With a few hours of actual instruction and a some practice, you can exponentially reduce the number required to get the same results. I've done it. I know.
Unread 03-16-2012, 08:29 AM   #3282
idskot
You're right
Unread 03-16-2012, 09:07 AM   #3283
Redcrazzy
Good job welding. It's gonna look good when it's done man.
[COLOR="Red"][SIZE="3"]RED HULK BUILD--->[/SIZE][/COLOR][SIZE="2"][URL="http://www.jeepforum.com/forum/f22/red-hulk-build-1343871/"]http://www.jeepforum.com/forum/f22/red-hulk-build-1343871/[/URL][/SIZE]
I need mo money
[SIZE="5"][B][COLOR="Red"]RED JEEP CLUB #757[/COLOR][/B][/SIZE]
[SIZE="5"][B][U][COLOR="Blue"]SUPPORT[COLOR="White"] OUR[COLOR="Red"] TROOPS[/COLOR][/COLOR][/COLOR][/U][/B][/SIZE]
[QUOTE=Monster747;13003951]I am running 37" with 3.07 gearing no issue on highway and excellent offroad.[/QUOTE]
Redcrazzy is offline   Reply With Quote
Unread 03-16-2012, 10:12 AM   #3284
BamaJeepman21
I don't check in on this thread for 2 months and I come in here and see, stretch, physics ****, something about fenders...
Looks good man. A long ways back I thought you didn't want to stretch it? It's been awhile since I've poked in here.
Build thread. Check it. http://www.jeepforum.com/forum/f22/bamajeepman21s-build-thread-1289905/
Do you even lift bro? http://www.jeepforum.com/forum/f374/ - Jack
BamaJeepman21 is offline   Reply With Quote
Unread 03-16-2012, 11:36 AM   #3285
Imped
Balls
Imped's Avatar
LOL.....dafuq. Now that's funny.
Yeah, it's a subject I've been going left and right on for a long time now. A couple obstacles finally sent me over the edge and I knew if I didn't just do something, I'd never do it. So I committed, cut up a couple things. and here I am. Hopefully I can turn my vision into reality.
OlllllllO
Float Test Build
IndyORV
