'rock crawling go-cart' or something - Page 212 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 'rock crawling go-cart' or something
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 03-07-2012, 02:12 PM   #3166
TJRHD
Wish I was closer, I would like to have those sliders.
Don't look at my work too close or too long..
My thread redo
http://www.jeepforum.com/forum/f22/yes-i-know-im-wrong-side-crazy-thread-redux-1484068/
TJRHD is offline   Reply With Quote
Unread 03-07-2012, 02:39 PM   #3167
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Her ya go broski, some vids of you from Saturday...
Green trail rock peak (along with our ridiculous dialog lol)...
Rock garden...
Easy step up on orange trail...
Red trail double step up rock wall...
A "less agressive" wall at the quarry...
IndyORV
B2CARPEN is offline   Reply With Quote
Unread 03-07-2012, 02:43 PM   #3168
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Here's me hopping and bouncing my way up that wall, at least my magnaflow sounds puuuurty
IndyORV
Unread 03-07-2012, 02:55 PM   #3169
battybluecb
**** my life! Over the last two weeks I just read through your thread. Nice jeep. I love how you actually wheel it. Keep rocking out my friend.
Cheers
My Build [url]http://www.jeepforum.com/forum/f22/my-04-rubis-1287969/[/url]
battybluecb is offline   Reply With Quote
Unread 03-07-2012, 04:08 PM   #3170
MO2500
Fabramicator
MO2500's Avatar
I need to be able to fully utilize 12" travel shocks.
I need to get this figured out too. Except my 12" travel shocks are 3.5" OD.
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Unread 03-07-2012, 04:46 PM   #3171
Imped
Imped's Avatar
But you won't have issues with springs unseating.
Now that I'm redoing the frame, I can set the distance between the coil mounts to whatever I want, to an extent. I'll probably set them up for 3 or 4" Currie coils and run those with 12" Bilsteins...set up for 6/6. Boom, equal travel at all corners and no unseating. At least that's the plan.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 03-07-2012, 06:00 PM   #3172
aw12345
It may have crossed my mind to get the AR behind the axle
To be honest I haven't even put too much thought or concern in the rear AR yet because I need to get the rest of the suspension figured out first. I'll add the AR last.
I'm sure it will be bad*** whatever you end up doing.
With coilovers it's easier to run the AR in front of the axle
Tinkertoy built thread
http://www.jeepforum.com/forum/f22/lil-bit-tinkering-aka-tinker-toc-1194198/
aw12345 is offline   Reply With Quote
Unread 03-07-2012, 09:05 PM   #3173
MO2500
Fabramicator
MO2500's Avatar
That's were mine will probably end up. It would be cool to run it through the rear crossmember if using separate coils and shocks though.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 03-07-2012, 09:17 PM   #3174
EugeneTheTJ
Keep Chopping
EugeneTheTJ's Avatar
PM me a price on those currie lowers and if you feel like it those rokmen corners while you are at it
EugeneTheTJ is offline   Reply With Quote
Unread 03-08-2012, 07:26 PM   #3175
Imped
Imped's Avatar
OK guys, I could use some ideas for rear corner cut ideas. I've probably looked at 1,000 rigs today and feel like there's stuff I haven't seen. Radius? Flare-shaped cutout? Something else? I'll only have one chance and I'd like to love the cut I make.
OlllllllO
Float Test Build
IndyORV
Unread 03-08-2012, 07:37 PM   #3176
MO2500
Fabramicator
MO2500's Avatar
I'm doing a radius cut on mine. I'm basically just going to move the axle to bump and use the center point of the axle flange to trace a line and cut. I'll hopefully have my armor on and cut before the end of the month (whole jeep done by then for that matter hopefully) so you can see how that option looks.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 03-08-2012, 07:37 PM   #3177
dwbrown
You could do Metalcloaks stretch fenders? I think you can do 4 inches of stretch and still have flares. Just an idea.
USAF
dwbrown is offline   Reply With Quote
Unread 03-08-2012, 07:39 PM   #3178
dwbrown
What exhaust system/muffler dealio are you running? It sounds reeeal purdy.
USAF
Unread 03-08-2012, 07:40 PM   #3179
MO2500
Fabramicator
MO2500's Avatar
I don't think he wants flares, hence the decision to sell his Rokmen hi-lines with flare and get some without.
My Jeep Build
Useful tech links:
Driveline 101
TJ Specs
-Mike-
Unread 03-08-2012, 07:42 PM   #3180
dwbrown
I completely missed that part.
USAF
