'rock crawling go-cart' or something - Page 14 - JeepForum.com
 3Likes
post #196 of 6560 Old 04-15-2009, 03:13 PM Thread Starter
Imped
Imped's Avatar
Well guys, I'm fresh out of ideas. I got the new wheels mounted today and put 8-9ish ounces of air soft beads in there for balancing. The wobble is still there from 45 on up and is especially bad between 50 and 60, then slows down a little after 60 but is still there. I had my alignment checked at Firestone on their digital rack and everything is in spec. I'm totally out of ideas. Again, everything is straight, tight, good to go. Nothing is worn, especially enough to cause my symptons. Add more beads? If anyone has any smart ideas, please tell me. This is getting to be very expensive and time consuming and I can't keep doing it.
OlllllllO
IndyORV
Imped is offline
post #197 of 6560 Old 04-15-2009, 03:25 PM
gribbles
dude.....really? does it feel the exact same?
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #198 of 6560 Old 04-15-2009, 06:28 PM
bgoman
just to clarify....thats a 2.5" suspension and a JKS 1.25" bl and 35's? Any problems with rubbing or flex? Im lookin at the same thing, actually the same tires and body lift lol
bgoman is offline
post #199 of 6560 Old 04-15-2009, 10:13 PM
RockRodHooligan
RockRodHooligan's Avatar
Both imped4now, and gribbles are running approx 2.5"-3" lift, 1" BL, and 35"s.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #200 of 6560 Old 04-15-2009, 10:38 PM
AlTheKillerr
AlTheKillerr's Avatar
damn dude that sucks. hows the steering dampner? i had all sorts of problems then saw that it was leaking real bad and replaced it then everything was fine
Photographer
AlTheKillerr is offline
post #201 of 6560 Old 04-15-2009, 10:54 PM
RockRodHooligan
Steering dampener is brand new.
96 XJ:
***** inches...
post #202 of 6560 Old 04-15-2009, 11:00 PM
AlTheKillerr
what about the tie rod, track bar, drag link? any of them bent up?
Photographer
post #203 of 6560 Old 04-15-2009, 11:14 PM
RockRodHooligan
New tie rod and track bar, drag link is good, new ball joints, control arms, and axle UCA bushings.
96 XJ:
***** inches...
post #204 of 6560 Old 04-15-2009, 11:22 PM
AlTheKillerr
damn. i say add more BBs then
what about a bent axle shaft? ive only seen it on the rear but maybe the front would act the same and wobble. . .
Photographer
post #205 of 6560 Old 04-15-2009, 11:28 PM
RockRodHooligan
Well I guess the BBs finally took, and has greatly reduced the "shimmy" in the steering, He drove it to school and it was doing it, after school he headed over to gribbles place to they his 35's to see if that changed anything. By the time he had gotten there, it had stopped.
96 XJ:
***** inches...
post #206 of 6560 Old 04-15-2009, 11:37 PM
AlTheKillerr
oh. thats interesting. glad it worked out then. my next suggestion was to just get a new jeep
i know my tires arent perfectly balanced and i get a slight shimmy at about ~45 then its gone. gonna take it back to the shop and toss some more weights on it so its gone. the 35" KM2 balanced out better than my 33" A/Ts
Photographer
post #207 of 6560 Old 04-16-2009, 06:49 AM
Bennettj13
There is no "finally took" with BB's. Either they work or they don't. Either you are going fast enough for centrifugal force to push them into the low spots or you aren't. There is nothing more complicated to them than that. It's physics.
Either way, I'm glad the shimmy is gone.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #208 of 6560 Old 04-16-2009, 07:51 AM
Dmcastino
Yeah its just BB's spinning around, its not like they seat themselves in the tires or anything so it must have been something different. But hey, as long as its not doing it anymore, then there is no problem! Hopefully everything just needed to settle in a little bit, I mean Connor, you did replace or even redesign just about every piece of suspension in the Jeep, it might need a little time to break in .
Dmcastino is offline
post #209 of 6560 Old 04-16-2009, 08:21 AM
gribbles
just bump stop accordingly I love my set up, perfect for the trails I run
2007 WK CRD
gribbles is offline
post #210 of 6560 Old 04-16-2009, 08:25 AM
RockRodHooligan
I'm just repeating what Connor said.
96 XJ:
***** inches...
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
blysccr
picture test x99j Jeep Picture Requests 2 10-23-2011 09:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 01:01 PM
test 94-91 Jeep Builds 5 11-04-2008 08:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 03:13 PM
