'rock crawling go-cart' or something - Page 10 - JeepForum.com
 3Likes
post #136 of 6555 Old 04-06-2009, 09:52 AM
CCJ
Originally Posted by imped4now View Post
Yeah man, no worries. The Currie arms are great. They will give you all the wheelbase you need. My front end is actually "stretched" probably 1" forward from stock and the rear is at stock, maybe a hair more now that my uppers have plenty of adjustment.
Discount tire just called and said my tires are done so I'm on my way to pick them up...then I need to run brake lines, hook the axle up, bleed the rears, then I'm on the road. Maybe today, maybe not. We'll see how quick I am.
Good news! Thanks Imped
CCJ is offline
post #137 of 6555 Old 04-06-2009, 12:11 PM Thread Starter
Imped
Imped's Avatar
Picked up the tires (all 5!!) and wheels this morning from Discount and got the front two on....holy **** sweet. I've got a surprising amount of room between the fender and edge of tire--9". Trimming those things off really made a difference. I still need to finish up the rear but have class today so that won't happen. Wednesday is looking like a good candidate for things to finish up.
OlllllllO
IndyORV
Imped is offline
post #138 of 6555 Old 04-07-2009, 09:11 AM Thread Starter
Imped
Imped's Avatar
Got the brake lines ran and the axle in last night. Pinion angle looks perfect and everything lined up fine. However, there were a few issues, naturally. The breather tube threads in the D44 were junked up so I had to run a tap through them and even then, they weren't great, but the breather bolt managed to thread in. After getting the axle in, the shocks were hitting the spring perches because of the pinion angle so I'm going to clearance those later today. That should finish up the axle end of things. The gas tank and new skid need to go in and that will be a PITA to do by myself. I'm still thinking it will get done tomorrow. Pics to come.
EDIT: Rod, thanks for your help last night....hope you had fun drinking Guiness cans and partying with those random 18yo girls.
OlllllllO
IndyORV
Imped is offline
post #139 of 6555 Old 04-07-2009, 10:45 AM
Dmcastino
I'll be home friday and can help with the tank and skid (especially if it includes girls and guinness) if you feel like waiting that long.
Dmcastino is offline
post #140 of 6555 Old 04-07-2009, 11:01 AM Thread Starter
Imped
Imped's Avatar
If it takes that long, then for sure. But, I need to get this thing on the road so I'm gonna work my *** off before work tonight in order to get things done.
OlllllllO
IndyORV
Imped is offline
post #141 of 6555 Old 04-07-2009, 11:12 AM
Dmcastino
Sounds good, keep plugging away man!
post #142 of 6555 Old 04-07-2009, 11:40 AM
gribbles
18yo girls and guinness?? why wasnt I clued in
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #143 of 6555 Old 04-07-2009, 12:35 PM
RockRodHooligan
RockRodHooligan's Avatar
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #144 of 6555 Old 04-07-2009, 08:35 PM Thread Starter
Imped
Imped's Avatar
I got the gas tank and skid fully installed before work tonight (no leaks!!) and am going to try to finish up tonight. The brakes need to be bled and the spring perches need to be trimmed. Then, it's time to tighten things up and take her out for her maiden voyage without vibes. I've got everything else done...front is toed in and tightened up, tires on, spare is on, rear axle is in, gas tank is in, I think I'm getting close....
OlllllllO
IndyORV
Imped is offline
post #145 of 6555 Old 04-07-2009, 09:41 PM
CCJ
Why are you trimming the spring perches? I ask cause, as you know, I too am going:
-currie LCA's
-currie UCA's
-33eng skid
-2.5" RC lift
CCJ is offline
post #146 of 6555 Old 04-07-2009, 09:54 PM
ScottHarr_TJ
2010 WK
I need pictures!
00' TJ-sold
'10 WK
Blue Jeep Club Memeber #132?
ScottHarr_TJ is offline
post #147 of 6555 Old 04-07-2009, 09:56 PM
gribbles
-currie LCA's
-currie UCA's
-33eng skid
-2.5" RC lift
you wont need to, the only reason he did was because of his RK 4 link, the pinion angle rotated the axle upward, which created contact between the rear shocks and the spring perch.
2007 WK CRD
gribbles is offline
post #148 of 6555 Old 04-07-2009, 10:32 PM Thread Starter
Imped
Imped's Avatar
-currie LCA's
-currie UCA's
-33eng skid
-2.5" RC lift
I'm trimming it because the pinion had to be rotated high enough that the shock is now making contact with the spring perches. It's easy man...just a cutoff wheel job....and I have a Rokmen skid, not 33eng.
Originally Posted by ScottHarr_TJ View Post
I need pictures!
Soon grasshopper.
I would have had to trim them regardless of the 4 link....it's because of the high pinion angle, not the rear upper setup.
OlllllllO
IndyORV
Imped is offline
post #149 of 6555 Old 04-08-2009, 07:02 AM
gribbles
Soon grasshopper.
it is because the height of the truss. The 4 link is set up higher than standard uppers would be, they are on a more level plain, which means more rotation from the axle to change the pinion angle. that upper 4 link doesn't have much play in it. tons of guys run tummy tucks and adjustable uppers without having to do what you are doing. In this situation the 4 link (mainly the truss) combined with the TT, is the reason for the extreme angle.
regardless, it is not a difficult task, and is not a big deal for anyone to have to do.
2007 WK CRD
gribbles is offline
post #150 of 6555 Old 04-08-2009, 07:24 AM
CCJ
Ah I see now. TY
Soon grasshopper.
I see. Yea, can't wait for pics man.
CCJ is offline
4 link , back half , bad cell pic's , batman , custom , garage queen , hendrix custom hood , indyorv , killer sa 4 link , ocd , pimpest jeep ever on 35s , rokmen hi lines , suspension calculator , the chit chat thread , the dark knight
picture test x99j Jeep Picture Requests 2 10-23-2011 09:56 PM
So test drove a ZJ and i had to test it out before i closed the deal! check these out xj287 Jeep Picture Requests 12 03-24-2011 01:01 PM
test 94-91 Jeep Builds 5 11-04-2008 08:55 PM
test LOCKED UP Jeep Builds 1 12-11-2003 03:13 PM
