Riots 97 Grand - Page 5 - JeepForum.com
post #61 of 633 Old 12-09-2012, 09:00 PM Thread Starter
riot1987
Not sure when they started.. I pulled mine from an 88 XJ. Most people pull em from XJ's too I believe. ..At least for a ZJ swap
Build thread^^
riot1987 is offline
post #62 of 633 Old 12-09-2012, 09:08 PM
8pitcher
8pitcher's Avatar
Ah ok. So I got a lp30 prolly
8pitcher is offline
post #63 of 633 Old 12-09-2012, 09:25 PM Thread Starter
riot1987
I would assume so. Im not too sure what cj's had. I know its a 30 and most likely a LP
Build thread^^
riot1987 is offline
post #64 of 633 Old 12-09-2012, 09:29 PM
Showtime3492
Negative. You have a high pin30
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #65 of 633 Old 12-09-2012, 09:39 PM
8pitcher
8pitcher's Avatar
How do you know?
8pitcher is offline
post #66 of 633 Old 12-09-2012, 09:42 PM Thread Starter
riot1987
Just look at your pumpkin. Its easy to tell
Build thread^^
riot1987 is offline
post #67 of 633 Old 12-09-2012, 09:42 PM
8pitcher
8pitcher's Avatar
Eh it is cold and dark outside maybe later.
8pitcher is offline
post #68 of 633 Old 12-12-2012, 08:37 PM Thread Starter
riot1987
Just for TRENT!!!! MothaB
Build thread^^
riot1987 is offline
post #69 of 633 Old 12-14-2012, 08:32 PM
Football47
Nice job....seems like everyone here has a garage and is a master welder -_- ... I definitely need one of my friends to teach me. Really nice work, and nice fabrications!
Football47 is offline
post #70 of 633 Old 12-15-2012, 02:59 PM Thread Starter
riot1987
Right on man, thanks! I do all my work in a little cramped garage at my old mans place. I used a hand grinder and an old band saw for all my cuts. We have an old 220 Lincoln 155 wire fees welder that has put in WORK. I love that little bastard! Im no master welder but have been welding **** since I was a wee chap.. Its not too hard, some good tips, steady hands, and practice and you can make some really awesome stuff. Its saved me SO much money being able to make my own stuff.
Thanks again for checkin out the build and for the complement man.
Build thread^^
riot1987 is offline
post #71 of 633 Old 12-17-2012, 03:08 PM
Showtime3492
I got some good measurements for wj steering/brakes also in case you wanted to do a budget set up. Uses a narrowed wj tie rod and drag link. If you want em let me know
post #72 of 633 Old 12-17-2012, 08:22 PM Thread Starter
riot1987
Put me in coach. WJ drags are quite a bit heavier than stock ZJ's right? Ill prolly buy my Tie rod but If I can use a WJ DL thatd be awesome. Send me whatchu got man im all ears.
Thanks chief
Build thread^^
riot1987 is offline
post #73 of 633 Old 12-17-2012, 08:34 PM Thread Starter
riot1987
Sway Bar
I FINALLY got my Addco sway from Kolak. Not his fault it so long though. Took about 45 mins to install. Got the grease-able bushings as well. I dont really think they are necessary as the sway comes with with bushings and links for the install. But, everything went well and im happy with it.
Build thread^^
riot1987 is offline
post #74 of 633 Old 12-17-2012, 08:36 PM Thread Starter
riot1987
Heres the old compared to the new one. Definitely beefier than stock.
Build thread^^
riot1987 is offline
post #75 of 633 Old 12-17-2012, 08:38 PM Thread Starter
riot1987
Front skid
Here is another pic of that front skid I posted earlier, just a better picture of it. I just plated the bottom of it.
Build thread^^
riot1987 is offline
