Riots 97 Grand - Page 3 - JeepForum.com
post #31 of 633 Old 11-29-2012, 05:24 PM Thread Starter
riot1987
Originally Posted by nygiants View Post
looks good man
Thank you man. I appreciate that. Its a constant work in progress.
I got the FEVER baby!!!
Build thread^^
riot1987 is offline
post #32 of 633 Old 11-29-2012, 07:03 PM
Showtime3492
Originally Posted by riot1987 View Post
If I coud use my stock ZJ 5 spokes id be so stoked! Ive heard they wont clear.. Ill look more into it though
It looks like the 99-03 had smaller caliper options and can be used on a 15 inch wheel but prob depends on backspacing
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #33 of 633 Old 11-29-2012, 09:23 PM
Freestyle713
1994 ZJ
I think its only with the akebono calipers you need 16" wheels. The other calipers I think you should be fine. Don't quote me on that, though. I would research it first.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #34 of 633 Old 11-29-2012, 11:46 PM Thread Starter
riot1987
Thats true. Akebono are the better calipers though. Im not sure about the difference in size but I know Akebonos NEED a 16" wheel. Got my parts list today from Kolak.
WJ Knuckles, Akebono calipers (found on later modles)
JKS spacers and steering linkage
Ill probably get new rotors from nick as well
Build thread^^
riot1987 is offline
post #35 of 633 Old 11-29-2012, 11:47 PM Thread Starter
riot1987
Yeah the later model WJ's have a better-and apparently bigger- caliper
Build thread^^
riot1987 is offline
post #36 of 633 Old 11-30-2012, 10:42 AM
Showtime3492
FOr me though i will take a slightly less caliper to keep my 15 inch wheels which are like brand new lol and still get the one ton steering set up.. That would be awesome
post #37 of 633 Old 11-30-2012, 11:30 AM Thread Starter
riot1987
Ive heard those other calipers are hard on rotors and can cause them to warp and wear badly. But yeah dude, if I cant find a cheap set of wheels then I might do that too. I like my stock 15's ..I dont wanna get rid of them..
Build thread^^
riot1987 is offline
post #38 of 633 Old 11-30-2012, 11:56 AM
clintrivera
3.75 Backspaced steel wheels work with the late WJ calipers with some grinding and NO stick on weights on the inside.
clintrivera is offline
post #39 of 633 Old 11-30-2012, 12:48 PM
Showtime3492
Good to know!
post #40 of 633 Old 11-30-2012, 01:29 PM Thread Starter
riot1987
Im gonna try to go get my knuckles and calipers today from the yard... wish me luck!
Build thread^^
riot1987 is offline
post #41 of 633 Old 11-30-2012, 01:33 PM
Showtime3492
What did you find about using the wj factory tie rod and drag link
post #42 of 633 Old 11-30-2012, 01:39 PM Thread Starter
riot1987
Called and looked online. No one has the WJ's im lookin for. Bullocks.
Build thread^^
riot1987 is offline
post #43 of 633 Old 11-30-2012, 01:43 PM Thread Starter
riot1987
The WJ tie rod is a fair amount longer than a ZJ, from what I was told it wont work. Im not 100% sure about being able to use the draglink though.
JKS makes a tie rod (and draglink) that compensates the difference in length for the swap. Ill probably end up with that.
Build thread^^
riot1987 is offline
post #44 of 633 Old 12-08-2012, 07:05 PM Thread Starter
riot1987
I painted the "vents" behind the rear glass. I dig it
Just primed 'em and hit them with some shake and spray bed liner
Build thread^^
riot1987 is offline
post #45 of 633 Old 12-08-2012, 07:07 PM Thread Starter
riot1987
I welded on plates to the factory "front" skid that goes behind the radiator
Build thread^^
riot1987 is offline
