Riots 97 Grand - Page 24 - JeepForum.com
post #346 of 631 Old 05-20-2013, 07:36 PM
kg6mov
Hears the voices
kg6mov's Avatar
The 4.slow will wheel fine with full armor (bumpers, sliders, skids).
Not gona win any drag races, but it rolls.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ 5.9 - Junked
kg6mov is offline
post #347 of 631 Old 05-21-2013, 12:28 AM Thread Starter
riot1987
Originally Posted by Dtperrell View Post
My ZJ has the little 242 in it. Will all that steel plus my steel brush guard weigh it down too much? Im a little nervous about welding a bunch of steel on the side for my l6 to lug around
No man, it wont haul *** but itll do fine wheeling. Id look into a D44 in the rear if your getting into haggard ****. Re geared itll do great. I rocked an 4.0 for years and still would have it if it didnt get totaled.
http://www.jeepforum.com/forum/f22/riots-97-grand-1436100/
Build thread^^
riot1987 is offline
post #348 of 631 Old 05-21-2013, 05:07 AM
Dtperrell
Im no mechanic and i wont try to be. So how much do you think it would cost to have it regeared? Should i pick up a "D44" in the scrapyard or look for something new?
2008 JK on 35's
Dtperrell is offline
post #349 of 631 Old 05-21-2013, 06:51 AM Thread Starter
riot1987
yeah, you can pull one from a yard no problem. Just make sure it matches your current gearing. Gears can be a pita to set up, there is a guy in Denver that will do gears for $100 per axle. Thats considerably cheaper than what a shop would charge
Build thread^^
riot1987 is offline
post #350 of 631 Old 05-21-2013, 07:39 AM
Dtperrell
How can I make sure it matches? Would it need to come out of another similar ZJ?
post #351 of 631 Old 05-21-2013, 08:24 AM
nickpequignot
Any d44a that you get out of a zj will come out of a 96-98 with a v8 and will have 3.73 gears. It is most likely that you have 3.55s in your 4.0 unless it has tow prep or tow package. It is fairly easy to check your gear ratio. You will need to get a buddy to help, mark a spot on the drive shaft. Jack the rear of the jeep up,block the front wheels and put the trans in neutral. Have a buddy rotate the tire 1 full rotation. If the drive shaft rotates about 3.5 rotations you have 3.55s and if its about 3 3/4 rotations you have 3.73 gears.
nickpequignot is offline
post #352 of 631 Old 05-21-2013, 08:33 AM
Dtperrell
I will do this pretty soon, thanks. If I have 3.55s and I want to swap to 3.73 would I need to change the front end as well since I have all time 4 wheel drive?
post #353 of 631 Old 05-21-2013, 08:34 AM
tyvanwie
Yes.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #354 of 631 Old 05-21-2013, 08:49 AM
BenHoleton
Or just have Chrysler send a build sheet. It'll be on there
BenHoleton is online now
post #355 of 631 Old 05-21-2013, 11:07 AM
YoureverydayXJ
Also, ignore all that joker stuff about put a mark here or it 'should' come with this.. If you want to know a gear ratio for sure pull the diff covers and look. If you don't already know, you should probably do it just to change the fluid.
'00 XJ not quite there..
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline
post #356 of 631 Old 05-21-2013, 11:08 AM
YoureverydayXJ
Not trying to totally hijack your thread riotman, Jeep looks good!
post #357 of 631 Old 05-21-2013, 06:08 PM Thread Starter
riot1987
Haha, GET OUT!
Just playin, thanks yo
Build thread^^
riot1987 is offline
post #358 of 631 Old 05-21-2013, 06:12 PM Thread Starter
riot1987
Deepest you can go is 4.86 on that front axle. Find out what tire size you plan on running and go from there. I wouldnt put money into a D35 personally. D44's lack aftermarket support but its a considerately stronger axle.
Build thread^^
riot1987 is offline
post #359 of 631 Old 05-21-2013, 06:18 PM
Dtperrell
Ive decided to just run my stock tire size and get a BB lift and hopefully tweak your side step design and build my own if you don't mind
2008 JK on 35's
post #360 of 631 Old 05-21-2013, 06:26 PM Thread Starter
riot1987
Dude, id just keep that 35 an re gear it and your front if you want some more power to the wheels. That D35 will hold up fine for the wheeling it sounds like youll be doing.
You cant take the step design. IT ALL MINE :sinisterlaugh:
Yeah man thats why I started the thread so people could get something from it.
...Youll never build a bigger piece of **** than my rig though
Build thread^^
riot1987 is offline
