Riots 97 Grand - Page 23 - JeepForum.com
post #331 of 633 Old 04-14-2013, 04:12 PM Thread Starter
riot1987
Some pics of this weekend
Build thread^^
riot1987 is offline
post #332 of 633 Old 04-14-2013, 04:15 PM Thread Starter
riot1987
Got to use the lights too. Not much hood glare at all. They worked well.
Build thread^^
riot1987 is offline
post #333 of 633 Old 04-14-2013, 04:17 PM Thread Starter
riot1987
That last pic was the first time I was able to get the front tire off the ground since I installed my lift lol! I can take about an inch of bumpstop out in the rear if I wanted to which would give me a bit more droop
Build thread^^
riot1987 is offline
post #334 of 633 Old 04-14-2013, 05:14 PM Thread Starter
riot1987
I believe EVERY ball joint in this pig is bad. I cant wait to get all my new parts. Its gonna drive so much better. Im beginning to get a loud clunk in the front front something. I think my steering linkage is hitting my axle right under my sway bar link pin. Along with numerous other clunks from other ****
Build thread^^
riot1987 is offline
post #335 of 633 Old 04-14-2013, 05:41 PM
PeteNnewburg
x2! LOL I was digging around the front end and found every control arm bushing is dry rotted, in the rear not only are they dry rotted but a couple of the control arms have flakey rust areas. I ordered all eight control arms, new axle and track bar bushings. Just replacing the front sway bar bushings made a difference!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #336 of 633 Old 04-21-2013, 08:33 PM Thread Starter
riot1987
Put some mesh in behind the grill. It looks pretty schweet.
Build thread^^
riot1987 is offline
post #337 of 633 Old 05-15-2013, 01:22 PM Thread Starter
riot1987
Got my plasma cutter. I see trimmed fenders and possibly a new front bumper in my future...
Build thread^^
riot1987 is offline
post #338 of 633 Old 05-15-2013, 05:48 PM
jeepinbassist
If I ever take a trip to Colorado I would buy the old bumper off you
jeepinbassist is offline
post #339 of 633 Old 05-15-2013, 10:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
Sweet, thats gonna be a **** ton of fun.
kg6mov is online now
post #340 of 633 Old 05-16-2013, 06:49 PM Thread Starter
riot1987
Welded on my Track Bar bracket up front. It was making a terrible noise. Installed my rear sway, when I go over big dips fast it rubs my drive shaft. Sucks. Im gonna see what I can do to fix that later. I just take it slow for now
Build thread^^
riot1987 is offline
post #341 of 633 Old 05-20-2013, 06:10 PM
Dtperrell
Steps
I used 2x2'' square for all of these and some plate to mount them to the body. I cut two angles @ 22 degrees on each end in order to make them toe in a total of 45 degrees.
I know you said you used 2x2" square for them but is that steel or..?
Dtperrell is offline
post #342 of 633 Old 05-20-2013, 06:23 PM
Dtperrell
Where did you get the mesh?
post #343 of 633 Old 05-20-2013, 06:24 PM Thread Starter
riot1987
Yeah dude, there is a steel yard down the road from me that I pick up scrap from for way cheaper than new. Its just some plain ol steel, nothin fancy. Get thicker walled stuff if its available and itll hold up well
Build thread^^
riot1987 is offline
post #344 of 633 Old 05-20-2013, 06:25 PM Thread Starter
riot1987
Home Depot. You get a giant roll in the home and garden section. You could do like 12 grills with the amount of material they give you on those rolls
Build thread^^
riot1987 is offline
post #345 of 633 Old 05-20-2013, 06:28 PM
Dtperrell
My ZJ has the little 242 in it. Will all that steel plus my steel brush guard weigh it down too much? Im a little nervous about welding a bunch of steel on the side for my l6 to lug around
