Riots 97 Grand - Page 22 - JeepForum.com
post #316 of 633 Old 03-26-2013, 06:59 PM Thread Starter
riot1987
Durango Air Hat
I finished my air hat today. Used my stock air tube and it worked great. I cut out the bracing in the hat and trimmed the little tabs in order to angle it to fit. Its tight, but it seems to fit with no issues. I had to cut some bracing out on the hood with a grinder. There are some rough measurements of how much to remove. She has a more aggressive sound and better throttle response. Havent driven it enough to tell any other differences n it yet. Got my air hat for the price of... FREE, delivered to my house by my buddy
Build thread^^
riot1987 is offline
post #317 of 633 Old 03-26-2013, 07:01 PM Thread Starter
riot1987
Good side view of the hat, its sloped kinda backwards.
Build thread^^
riot1987 is offline
post #318 of 633 Old 03-26-2013, 07:10 PM Thread Starter
riot1987
Thats the brace and the grinder I used to cut
Build thread^^
riot1987 is offline
post #319 of 633 Old 04-03-2013, 07:15 PM Thread Starter
riot1987
I pressed all my ball joints and upper CA bushings out today. I used this for the CA bushings. It was super badass!
I cant figure out where to put my pass side axle seal in that HP30.. Im trying to bypass the CAD system
Build thread^^
riot1987 is offline
post #320 of 633 Old 04-08-2013, 10:00 PM
Myusername1674
That last picture with the axle sideways is messin' with my head! hahaha
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #321 of 633 Old 04-09-2013, 04:55 PM
joshsmithers
1994 ZJ
Lovin the spiderman sheets!
joshsmithers is offline
post #322 of 633 Old 04-10-2013, 06:44 AM
Myusername1674
Random question, do you think if you turned the hat around to fqce the other way that you could have kept from cutting the hood??
(in progress)
post #323 of 633 Old 04-10-2013, 07:47 AM Thread Starter
riot1987
It would have def helped but then my inlet tube would have been 180* off, if that makes sense.
Build thread^^
riot1987 is offline
post #324 of 633 Old 04-10-2013, 07:47 AM Thread Starter
riot1987
Classic. Punked em from the nephew
Build thread^^
riot1987 is offline
post #325 of 633 Old 04-12-2013, 03:39 PM
SBiscardi
damn beautiful jeep man thats one hell of a tranformation
SBiscardi is offline
post #326 of 633 Old 04-12-2013, 04:47 PM
Myusername1674
Yeah thatd totally work for me, ive got mine turned around already for how its sep up. So sweet!
(in progress)
post #327 of 633 Old 04-12-2013, 05:49 PM Thread Starter
riot1987
Thanks! I appreciate it. I just ordered my ball joints and upper ca bushings. My front axle is gettin there!
Build thread^^
riot1987 is offline
post #328 of 633 Old 04-12-2013, 05:50 PM Thread Starter
riot1987
Yeah if your intake is routed to the other side that air hat angle would work in your favor by running it to 180*
Build thread^^
riot1987 is offline
post #329 of 633 Old 04-14-2013, 03:47 PM
WhiteOut
WhiteOut's Avatar
No issues with installing the truss without having it mocked up in place?
You just set it on 3 jackstands and adjusted the pinion so it was pointed 13* up?
I'm really leaning to this even though it is $100 more than the IRO I like having a truss, even though it will be overkill, and I can mount Clayton links in the future if I go that way in the future.
WhiteOut is offline
post #330 of 633 Old 04-14-2013, 03:58 PM Thread Starter
riot1987
I got all but my shock mounts tacked into place and dry fit under the jeep to make sure everything was gonna jive. I believe the instructions called for 11* on the pinion angle but I went a tad more. Get one of those angle finders to do so. And if you have adjustable CA's you can (obviously) kinda fudge your pinion angle a bit and then make up for it in your arms, if that makes sense. It was a fun build, that truss was cake to put on. I would suggest modifying the shock brackets so you triangulate them. I didnt cause I was too impatient.
Build thread^^
riot1987 is offline
