Riots 97 Grand - Page 21 - JeepForum.com
post #301 of 633 Old 03-19-2013, 08:12 AM Thread Starter
riot1987
Originally Posted by jeepinbassist View Post
It would be awesome to have it like that, I've seen one zj like that its that 4.0 turbo one. I know I'm gonna have to change it once I lift it cause it will hit the drive shaft.
my muffler hits the ds when I wheel. I need a smaller muffler. Like just a simple round one
Build thread^^
riot1987 is offline
post #302 of 633 Old 03-19-2013, 11:10 AM
jeepinbassist
Get a glasspack. They are only 30 dollars.
jeepinbassist is offline
post #303 of 633 Old 03-19-2013, 12:01 PM
PeteNnewburg
2XX $30 or less. A longer glasspack is quiet, a short one will be louder! I had a 30" on a 300 I6 F150 and you could not hear it running. My 4x4 F150 has 3" pipes and a 12" cherry bomb. It is loud!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #304 of 633 Old 03-19-2013, 02:02 PM
jeepinbassist
I think I'm gonna cut out the center of mine so it's super short so i don't get ticketed for no muffler
post #305 of 633 Old 03-19-2013, 05:15 PM Thread Starter
riot1987
Im thinkin about something along these lines. It can be longer I just cant have anything in that traditional rectangle shape
Build thread^^
riot1987 is offline
post #306 of 633 Old 03-20-2013, 09:39 AM
jeepinbassist
The only problem is they don't have the same offset inlets but it wasn't a problem for me.
post #307 of 633 Old 03-20-2013, 11:16 AM
Showtime3492
Come to the conclusion that I need More lift. Ill need about 2.5" when I get the 35's.
You haven't cut enough out then
Sent from Go home Jeepforum app, you're drunk.
--1998 XJ "Mater"- RIP
2000 XJ--- 4.6 stroker. Saved from the grave- everything swapped or modded. I hate this thing :)
Showtime3492 is offline
post #308 of 633 Old 03-20-2013, 04:43 PM Thread Starter
riot1987
I havent trimmed fenders at all. I trimmed some bull**** in my fender wells but thats it so far
Build thread^^
riot1987 is offline
post #309 of 633 Old 03-21-2013, 07:39 PM Thread Starter
riot1987
STEERING BRACE
I made a steering brace. Its essentially the same thing you get from KOR but, I saved $175 ****ing dollars! It was easy to make. Took a few hours. I cant feel much of a difference yet. I wanna see how it feels wheeling. It seems to take some whine out of the steering box.
Build thread^^
riot1987 is offline
post #310 of 633 Old 03-21-2013, 07:46 PM Thread Starter
riot1987
Ill post some pics of it installed tomorrow. There was a perfect little pocket for it, I didnt have to move anything around
Build thread^^
riot1987 is offline
post #311 of 633 Old 03-22-2013, 01:58 PM
jeepinbassist
STEERING BRACE
You should start selling those just like your a pillar mounts
post #312 of 633 Old 03-23-2013, 07:57 PM Thread Starter
riot1987
My blower motor has been cutting out recently. This morning it wouldnt work for 15 mins till it warmed up. Strange. I gotta see what the **** is wrong with it now
Build thread^^
riot1987 is offline
post #313 of 633 Old 03-25-2013, 08:44 PM
YoureverydayXJ
Volt meter? Check it that way? When its hooked to the throttle body i read that it should steadily pull around 4 volts+/-
I don't remember the reference voltage... Check for even sweep in resistance (with sensor unhooked) as you open and close throttle by hand. If it is jumpy or has an open or anything at a point it is pry bad.
I just ha to replace mine again couple weekends ago.
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline
post #314 of 633 Old 03-25-2013, 08:47 PM
YoureverydayXJ
Had issues with connection on mine. Wiggled it for the longest time, then cut off factory end and put on spade terminals. Eventually still had to replace it.
post #315 of 633 Old 03-26-2013, 06:51 PM Thread Starter
riot1987
Ill look at the controls and see if somethin looks fishy.
Build thread^^
riot1987 is offline
