Riots 97 Grand - Page 20 - JeepForum.com
post #286 of 633 Old 03-14-2013, 06:51 PM Thread Starter
riot1987
Tightened up my extremely loose pitman arm and all my jam nuts along with fixing the broken studs on my hood vents. I used QuickSteel. It bonded hard as **** and seems to hold really well. Got it at the auto parts store. Its like putty then gets uber hard
Build thread^^
riot1987 is offline
post #287 of 633 Old 03-14-2013, 06:52 PM Thread Starter
riot1987
Originally Posted by tyvanwie View Post
Coils on the coils...
Sent from my iForum using JeepPhone
Didnt we talk about this before..? Along with the double hinged ultra flexy CA's..?
Build thread^^
riot1987 is offline
post #288 of 633 Old 03-14-2013, 06:54 PM
nickpequignot
Originally Posted by riot1987
Thats cool man. Is it old, weathered chain? Thatd look awesome
Old *** rusty chain I got out of the shop at work. My uncles sand blasting it s o i can weld and paint it. Possibly the same color of my rims
nickpequignot is offline
post #289 of 633 Old 03-14-2013, 06:56 PM
tyvanwie
Yes lmao
tyvanwie is offline
post #290 of 633 Old 03-14-2013, 06:59 PM Thread Starter
riot1987
Sandblast it to smooth it out and clear coat it. Itd look cool all rusty and ****
Build thread^^
riot1987 is offline
post #291 of 633 Old 03-15-2013, 11:16 AM
jeepinbassist
Originally Posted by riot1987 View Post
Cut the tailpipe off too. It was hittin on **** and rattling so it was removed. From what I read on state laws here in CO its legal. It sounds really good now Im happy with it!
I did that to my 4.0 cause i got bored. Then i found a y pipe and made it come out both sides. It sounds great without it but i bet yours sounds better cause of the bigger engine.
jeepinbassist is offline
post #292 of 633 Old 03-15-2013, 11:47 AM
nickpequignot
My 4.0 the exhaust is cut right after the cat. And it sounds like a bigger motor. I'm having a shop make a pipe exit on the right side some time next week
post #293 of 633 Old 03-15-2013, 11:56 AM
jeepinbassist
That's how i cut mine off and then got 2 1/2 od pipe and had it come out the right until i found the y pipe. I like it cause it's loud out both sides.
post #294 of 633 Old 03-17-2013, 10:24 AM Thread Starter
riot1987
Engine light has been coming on and off. I pulled some codes and I think my TPS is bad. Gonna have the parts store test it and see if they bring up the same thing. Its been stuttering lately when I step on it so Im thinking its prolly bad.
Build thread^^
riot1987 is offline
post #295 of 633 Old 03-17-2013, 10:26 AM Thread Starter
riot1987
Ha, word. I want a true double pipe exhaust but there aint enough room under there and I dont wanna spend the time/money to do it
Build thread^^
riot1987 is offline
post #296 of 633 Old 03-17-2013, 10:28 AM
Isaac5108
Parts store can't do any better then you can. CEL codes show you symptoms, it doesn't necessarily mean that that part is bad.
Isaac5108
Isaac5108 is offline
post #297 of 633 Old 03-17-2013, 10:39 AM Thread Starter
riot1987
Volt meter? Check it that way? When its hooked to the throttle body i read that it should steadily pull around 4 volts+/-
Build thread^^
riot1987 is offline
post #298 of 633 Old 03-17-2013, 10:54 AM
Isaac5108
I would clean the piss you of your throttle body. Take the IAC out and clean it well. The TPS is trying to compensate for something else not working properly
Isaac5108
post #299 of 633 Old 03-17-2013, 11:19 AM Thread Starter
riot1987
I should look at it. Ill see whats goin on with it soon
Build thread^^
riot1987 is offline
post #300 of 633 Old 03-17-2013, 09:18 PM
jeepinbassist
It would be awesome to have it like that, I've seen one zj like that its that 4.0 turbo one. I know I'm gonna have to change it once I lift it cause it will hit the drive shaft.
