Ring and Pinion help!!! - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Ring and Pinion help!!!
Savvy/Currie Aluminum Control ArmsRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 08-31-2014, 12:24 PM   #1
redcjhornet84
1984 CJ8
I Just picked up a wide track Dana 44 to swap in to the rear of my 1984 Cj8 Scrambler as a replacement for my turd of an AMC 20, The D44 has 3.07 R&P and the Dana 30 I'm keeping up front (For the time being) has a Nasty 2.73 R&P!
I've never swapped gears, I have decided on Yukon Gears 4.11 R&P. so really I need to know what else I need to purchase to do the complete swap!!!
Will I need new spider gears for the D30? A new carrier? Im putting a yukon Grizzly locker in the Rear D44 with the 4.11s I need help with some advice on how to do it and what else to buy!
Any help is appreciated!!
1984 Cj-8 Scramber with 2006 4.0
4" Lift
33" Tires
Poison spyder BFH front bumper with Brawler Bar
Metalcloak Overline Front fenders
redcjhornet84 is offline   Reply With Quote Quick reply to this message
Unread 08-31-2014, 01:05 PM   #2
222Doc
222Doc's Avatar
with that many questions about setting up gears( and not even the hardest part). I have a feeling that you should have it done. Buy the time you gather the specialty tools and the knowledge to do it right the first time. It may save you money in the long run. Do it wrong and you will buying much of what you need all over again.
You can do it , you will need to learn how and buy the tools. i really do not think anyone here is going to do a step by step. since there is a wealth of this on line.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 08-31-2014, 01:16 PM   #3
redcjhornet84
1984 CJ8
I don't need a step by step so much, what with all the threads I've been reading, I just can't seem to find info on required parts/tools
