Reviving a 1990 Sahara YJ :D - Page 4 - JeepForum.com
post #46 of 91 Old 10-13-2013, 11:49 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by Meepz View Post
Yep, new fuel. Also, I don't have the filter attached to the carb at the moment. Does that make much difference?
I'll try that, thanks.
I would NEVER run a fuel line from an old gas tank into a carb!! One spec of crud gets into the carb and that spec of crap will drive you nuts.
Just for the heck of it tap the side of the carb a few times with the butt end of a screwdriver handle. Your floats may be stuck closed so you are not getting any fuel.
And all carbs need to be adjusted when installed
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #47 of 91 Old 10-13-2013, 02:50 PM
Xplorer
I still say it's fuel related.
Xplorer is offline
post #48 of 91 Old 10-13-2013, 03:17 PM Thread Starter
Meepz
It stays running with the carb choke open. Once closed, it dies. Is that a symptom of a fuel problem?
Meepz is offline
post #49 of 91 Old 10-13-2013, 03:27 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
It is supposed to run with the choke in the (mostly) open position.
post #50 of 91 Old 10-13-2013, 03:30 PM Thread Starter
Meepz
I see. But after pressing the gas, it closes and dies.
Meepz is offline
post #51 of 91 Old 10-13-2013, 03:33 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Read post #43 there is no magical wand to wave over this carb you have to check all the settings.
post #52 of 91 Old 10-13-2013, 03:37 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Youtube; carter bbd adjustments 1 example of the info there
post #53 of 91 Old 10-13-2013, 08:17 PM Thread Starter
Meepz
Video Link: http://www.youtube.com/watch?v=XFGf1kXlnLs
When he revved it, the choke stayed open. When I rev mine, it closes.
Edit: Watched his other carb video and the choke only closed a tab bit after revving it. Mine closes all the way and dies. Also, I noticed his opens up slowly. Mine does not. Not sure if this is helpful info or not.
Meepz is offline
post #54 of 91 Old 10-13-2013, 08:26 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Isn't your choke pull of vacuum operated? Check that their is vacuum and that the pull off works when you apply vacuum.
There are a bunch more videos available on Youtube. Like I stated earlier you need to start at the beginning with the carburetor adjustments.
post #55 of 91 Old 10-13-2013, 08:31 PM Thread Starter
Meepz
I'll start a new headache in the morning and try it out. :P
Meepz is offline
post #56 of 91 Old 10-14-2013, 01:46 PM
Xplorer
Mades it run out of air when the choke closes which is why it's stalling out. Somethings not right with that choke.
Xplorer is offline
post #57 of 91 Old 10-14-2013, 02:14 PM Thread Starter
Meepz
Agreed.
Post #7 might help you before you swap out the carb.
http://www.jeepforum.com/forum/f8/ca...ttings-929120/
How can I tune the carb with a vacuum gauge if the jeep doesn't run?
Meepz is offline
post #58 of 91 Old 10-14-2013, 02:30 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Agreed.
Someone probably messed with the fuel and air adjusting screws. You have to start at a certain point and work from there. Re-read what I posted earlier the thread I found here in JF telling you how to do that. In most cases to fine tune the carb a vacuum gauge is used.
Again....post #7
post #59 of 91 Old 10-14-2013, 02:59 PM Thread Starter
Meepz
Again....post #7
Guess I'll go out and get a vacuum gauge.
Meepz is offline
post #60 of 91 Old 10-14-2013, 05:53 PM
jenglish421
To me it sounds like your choke thermostat isn't working or the vacuum isn't connected right or maybe even a vacuum leak
jenglish421 is offline
