The red YJ aka (Elmo) - Page 7 - JeepForum.com
 5Likes
post #91 of 174 Old 08-31-2014, 12:39 AM
mike134
what's that behind your tailgate? some sort of wifi hot spot?
mike134 is offline
post #92 of 174 Old 01-11-2015, 08:28 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Hadn't updated in a while. Fnished the tire carrier this past fall. Just got done replacing the valve cover gasket, CCV, and some vacuum hoses that were falling apart. Here are the pics from the tire carrier. Friend made a hinge at work and we welded the square tube up over the course of 4 hours. CB showed up yesterday too, waiting on the antenna and cable so that will be going in within a week or two.
Also, traded in my mustang for a truck finally. Needless to say, there will be much more wheeling this year.
User name on the other forums: JPTHNG
2jeeps1stang is offline
post #93 of 174 Old 01-18-2015, 10:23 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Little preview of the CB overhead console
Planning on finishing this up over the weekend. Also need to do a compression test on the motor. I have a major case of blow by even after replacing the ccv set up. Coming up through the dipstick too. So that will happen soon enough. I've been driving the truck mostly.
post #94 of 174 Old 01-25-2015, 05:15 AM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Was able to get the console mounted with some scrap brackets. Today i will be disassembling it all for finishing and paint. You may notice it hanging "low" I did this for a couple of reasons, clearance for the bikini top as well as appearing flush with the windshield and roll bar when the top is off. In reality, the box does not hang that low. You can turn you head and see who is sitting next to you and getting bounced around on the rocks my head won't hit.
post #95 of 174 Old 01-26-2015, 11:57 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Did more work on the cj5 floor rather than the yj this weekend. However, console is finished for painting throughout the week. Hopefully have it wired up and installed sunday. In the meantime, if anyone is looking for reasonably priced LEDs for their jeep or daily driver headlights/fogs/lightbars check out GTR LEDs. Lifetime warranty dust and water proof. Not to mention easy to install and didn't break the bank. Installed them in the truck tonight afterwork. I have to commend them on the quality. Fogs look yellow in the pic but are more white in person. Headlights are more towards the 6k temp. (More blue). Very happy. Very bright. Reverse lamps are LED as well. Make backing up to the trailer nice n easy at night. Trailer will be the next project before spring
Size:  460.2 KB Name:  image-2060312326.jpg
post #96 of 174 Old 01-27-2015, 07:06 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Great looking Jeep!
I've got some questions about your Monstaliner. How do you like it now that it's been on for about a year? Is it holding up well? Not fading, etc...? How much Monsta did it take to do the outside? How many coats did you do? I think you said you rolled it on, if you did it again would you still roll it or would you spray it? How did you match the interior?
I've been thinking of doing this to my Jeep. I painted it a few years ago with some cheep single stage acrylic and it's starting to show its age. Also, I run a lot of narrow trails with a lot of brush so I think Monsta would hold up better than paint.
-John-
johnboy68 is offline
post #97 of 174 Old 01-27-2015, 09:25 AM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Originally Posted by johnboy68 View Post
Great looking Jeep!
Nice yj. Monstaliner, I have NO regrets. For starters rolling on for me was much easier than spraying. There was less prep in the shop. Just laid down a bunch of cardboard and covered the wheels. See a few posts back. I took plenty of days taping, sanding and prepping the old surface. Wiped it all down with lacquer thinner right before we rolled on the liner. Rolling was a bit hard to get the roller lines to blend but I've painted many times before on drywall with no issues. Figured this would be easy. I did apply one coat. I only used one gallon. Truth be told, it could use a second coat to better texture the body and fill just a couple of small pin hole spots where I can still see primer. It is holding up exceptionally well. I work out by the mills here and it has held up to acid rain, fall out, sun, and the salt. It sat outside almost all summer with no fade in my opinion. I spray it off and use quick detailer/spray wax to keep it shined up. Water beads right off. Holds up to rugged branches on the trail. I do have one chip where I accidentally banged the grinding wheel into it the other day. Little can of red spray paint cleaned that right up. Other than that, I have nothing but good things to say.
post #98 of 174 Old 02-01-2015, 10:16 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Never minded the snow. Cleans up easier than mud.
post #99 of 174 Old 03-03-2015, 09:25 AM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Got the front bumper finished. Purchased the motobilt stubby. We made our own stinger. Eventually a m8000 winch will find its way home on top. Hardest part was bending the tube and making the miter right on the bumper. Very happy with how it turned out. Name:  image-1304188606.jpg
Size:  535.4 KB Name:  image-1665987539.jpg
post #100 of 174 Old 03-04-2015, 05:35 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Where did you get your latch and pivot for your tire carrier?
-John-
post #101 of 174 Old 03-04-2015, 12:15 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Latch is simple gate latch. found it on amazon. I think Tractor Supply Company (TSC) carries them as well. The hinge a buddy machined for me.
post #102 of 174 Old 03-16-2015, 06:00 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Console is done. CB is wrapped up too. Very happy and definitely recommend the cobra29LX
We are heading south this weekend for the IFWDA convention here in Indiana. Ready to go wheeling!
post #103 of 174 Old 04-05-2015, 11:42 AM Thread Starter
2jeeps1stang
1987 YJ Wrangler
After hitting the trails a few weekends ago, I figured some limb risers were necessary to protect the glass and LED pods. I could not justify spending $100 from the catalog so made my own. 3/16 stainless cable, eye bolts, and clips... $20 later it was done.
post #104 of 174 Old 04-05-2015, 07:37 PM
jollymon55
1987 YJ Wrangler
absolutely love your build. i will be looking into some of these mods and stealing some of your ideas. thanks
jollymon55 is offline
post #105 of 174 Old 04-05-2015, 11:57 PM Thread Starter
2jeeps1stang
1987 YJ Wrangler
Thanks. I will post pics from the trip tomorrow from my laptop. Pm me if you have any questions. Bored today, having a beer allowed me the opportunity to make use of a cart we had in the shop.. Wheels my doors around no problem. Name:  image-661298575.jpg
Jeep TJ Wrangler 1997 -2004 ,V-6 Conversion Package , Retaining the Stock Jeep 5?? Travisray91 TJ Wrangler Technical Forum 12 10-05-2011 12:50 PM
Got jeep back from shop, coolant level low, jeep running cold. kainers YJ Wrangler Technical Forum 4 10-30-2010 07:51 PM
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 09:22 PM
whats wrong with my jeep need answer asap (Jeep won't idle after jump start) Wrangler11 TJ Wrangler Technical Forum 24 11-04-2008 04:46 PM
