11-08-2010, 04:58 PM
#166
thanks...i added some perforated 1/4 inch hole 1/8 inch steel to the bottom and curved it up for a place for the tag on the stinger.will have pics tomorrow.
also found out the rims i got are correct thankfully..the guy took a 170mm spacer and drilled it out to kinda work for a 8 on 6.5 bolt pattern..well imho it didnt work and explains why he couldnt drive over 40 on the hwy lol..
so i will be needing 2- 8 on 6.5 2 inch spacers in the future..
11-09-2010, 05:29 PM
#167
11-09-2010, 05:32 PM
#168
Looks really Snazzy!
11-09-2010, 05:40 PM
#169
D*** son! Looks nice
11-09-2010, 06:23 PM
#170
Awesome job Johnny!
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
http://www.canddautocenter.com/
11-09-2010, 06:52 PM
#171
looks good man.. good to is another fabricator on here...you wont regret the rear tire carrier.. i made one for mine and it helps against trees .... keep up the good work..
97 TJ, custom long arm, custom tri link rear, 44 front-9in rear, Detroit and Yukon lockers, 4:88s, 37" bfg's ,tube fenders and crusher corners, process never ends...
[url]http://www.jeepforum.com/forum/f22/evolutions-97-tj-1061890/[/url]
11-09-2010, 07:50 PM
#172
Fabramicator
The perforated steel ads a nice touch to an already great looking tire carrier  That rear end looks great
11-16-2010, 08:49 AM
#173
11-23-2010, 04:40 AM
#174
just ordered a rubicon express deep sump tranny pan kit,,daystar 1 inch motor mounts to replace my homemade mounts,since my fan has been hittin the shroud on full flex..i figure the mounts must be the cause,hope im right?
also a autometer tranny temp gauge with bung to weld in the new tranny pan
2 more days to be miserable for the day..then 2 weeks till our club ride cookout,,cant wait
11-24-2010, 03:36 AM
#175
hey johnny, can you give me the link where the details are for the cook out
Rusty
Satellite Bch, FL
11-24-2010, 05:16 AM
#176
I sent you a pm on EPJC. Did you not get it?
11-24-2010, 05:59 AM
#177
no link rusty..same ole meeting spot at the stop sign lol..
jkl,do i need to bring any food ? i can bring my own drinks but wont have room for a cooler or trash since my jeep will be full
11-25-2010, 08:23 AM
#178
well yesterdayi woke up and decided to replace a less than a yr old spicer u-joint,,after further inspection the unit hub bearing was a lil worse than it was a yr ago so i had to replace it also..what a night mare
i loaned out my breaker bar so had to compromise..i broke 2 1/2 inch ratchets and 1 click style torque wrench trying to remove the hub nut,that i put on myself a yr ago..so then i welded all 3 tools seperatly back together and broke them again..finally welded the 36mm socket on a pipe and got it off..so my 2 hr job turned into like 4 lol..but its done with new joint and hub bearing installed..
hopeing the deep tranny pan and gauge and motor mounts show up by next week too..
also when taking apart i noticed 2 of my tac welded caps broke loose and were spinning in the yoke..so i peened them on the inside of the yoke and tac welded the new one also..now i see the need for this much more than i thought before..good thing to do on a turdy5 i read
11-25-2010, 07:09 PM
#179
Originally Posted by johnny9
jkl,do i need to bring any food ? (
Bring your own drinks, I'll handle the food
12-01-2010, 08:38 PM
#180
new daystar m.mounts yesterday, and tranny pan and gauge came today.i ordered a cheaper rubicon express since i hate skyjacker junk anymore,but they were back ordered so they gave me the skyjunker for the same price at like 100 bucks,so cant complain..i know the dealer has them cheaper but to much hassle.
now to decide if i should use a available service port in the tranny to install the gauge,or weld a bung in the pan..service port sounds much easyer to me
just need time to install some of the stuff i been saving ..almost got some 38.5,s today but it fell thru again..
hurry up next weekend
