Quantcast The Pumpkinator's Build Thread - Page 64 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > The Pumpkinator's Build Thread
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 11-17-2009, 03:53 PM   #946
spyder6
Just violated my Parole
spyder6's Avatar
there is, i think james hasnt done anything yet though because the hose isnt long enough and he needs to raise his gas tank for it to work
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 11-17-2009, 04:32 PM   #947
LuckRider
LuckRider's Avatar
Wow James, 4500lbs, that is beastly. I think mine is somewhere around 3500lb.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Old 11-17-2009, 04:33 PM   #948
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
Spyder is partially right, the cut out in the corner guard is for a CJ/YJ filler bezel, and the TJ fill tube doesn't fit quite right up to the CJ/YJ bezel, and the tube needs to be modified so it can work. The tank does need to be raised however to make room for the rear stretch, the gas tank skid almost hits on the rear dif.
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 11-17-2009, 04:39 PM   #949
RockRodHooligan
Under Construction
1989 MJ Comanche
2005 Jeep Wrangler Sport Utility Specs, Engine Performance & Other Car Specifications - Motor Trend Magazine
2005 Jeep Wrangler Sport Utility Exterior & Aerodynamics Standard Features
- Weights: gross vehicle weight rating (lbs) 4,449, curb weight (lbs) 3,538, gross trailer weight braked (lbs) 2,000 and max payload (lbs) 800
All in all, considering every thing that went on, it's not too bad. I think he said his TNT order was something like 700+lbs alone. Keep in mind, that gross weight is for stock suspension, axles, tires, brakes... wonder what it would be now?
Penis inches...
Old 11-17-2009, 04:49 PM   #950
Osmosiz
1995 XJ Cherokee
WOW, youve come a long way. great job man!
99 XJ Sport - 3" lift, 31 BFG At's -DD
94 XJ Sport - 5" Lift, Locked on Swampers and beaten
I Just dropped in to see what condition my condition was in...
Osmosiz is offline   Reply With Quote
Old 11-17-2009, 05:02 PM   #951
Bennettj13
I'm a big meanie head
Bennettj13's Avatar
OK well, here's some pics. For you JK guys, or anyone wanting to swap JK axles under your beast, here is what I've learned...
On the back side of the diff, there is a plug. It's useless to anyone but the JK's. It's a sensor for the dash to tell you when your locker is locked. It's a small plunger that pushes outwards against the locking plate. What happens when people who are not familiar with the newer D44's install gears is that they don't get that plunger set right with the locking ring. So you have the plunger hitting the ring, which puts enough pressure on the plate to lock the axle.
Demon plug unscrewed
Diff opened (I wouldn't have had to, but I was putting the Riddler on anyways)
This is what it's supposed to look like.
This is what it looked like.
And inside the diff...
My solution...
And the Riddler cover back on
Technically, I didn't even need to open the diff. I could have pulled the plug, cut it, and stuck it back in just fine. I was putting the Riddler on there though, and figured what the hell, might as well look.
Tru-Turn pics are next.
::SELLING::
Bennettj13 is online now   Reply With Quote
Old 11-17-2009, 05:06 PM   #952
murzi3000
that's one sick jeep.
Back in '82, I used to be able to throw a pigskin a quarter mile.
murzi3000 is offline   Reply With Quote
Old 11-17-2009, 05:13 PM   #953
RVA_TJ06
How much did the Treks long arm plus the stretch run you?
Finally paid off...
RVA_TJ06 is offline   Reply With Quote
Old 11-17-2009, 05:40 PM   #954
Bennettj13
Bennettj13's Avatar
The Off Road Only Tru-Turn is a new product for JK's to get back to a straight tie rod, and get more/better diff clearance. I specifically needed this because I refused to set my steering stop so much that I'd have to make a right turn across 4 lanes. Aside from that, I couldn't come close to full lock without getting all up into the diff... and I didn't even have my Riddler cover on. So, I needed to do something about that.
Rod at TNT suggested I talk to Steve at ORO about this new system due to my issues. I was previously running the TNT tie rod with one-ton ends. The Tru-Turn runs Spicer ends off of a 3/4 ton van (think UPS truck). I was immediately impressed with the Chro-Mo tie rod. It's nice and heavy looks like it's going to get the job done. I was also impressed with the thickness of the "hub" as ORO calls it, I just keep calling it a bracket, but anyways, it's thick, and doesn't look like it's going to fail. On to the pics.
This is the bracket that bolts through the knuckle and keeps everything in place.
Inside the stock Moabs, there is a groove, I don't know, nor do I care what it is there for, but it's a pain in the ***. Read below to find out why.
On the stock JK Moabs, because of the ungodly backspacing, you will need to trim one of the nubs off of the tie rod ends. The little square nub thing looks like it would almost fit in that groove shown above. It will not. Grind it off. You aren't going to hurt anything.
Thems tight quarters right thar!
I thought I ground enough off... I was wrong. Look ma, self clearancing wheels! That little groove came in handy. It's just a hair too shallow.
In the end, I got just what I wanted, and got the clearance I needed and the ability to run one of the thickest aftermarket diff covers on the planet. I didn't have to adjust my steering stops, and am now good to go, minus a little paint. I am a happy boy.
Diff clearance!
And have you EVER seen prettier steering geometry. The correct answer is no.
::SELLING::
Old 11-17-2009, 05:44 PM   #955
Bennettj13
Bennettj13's Avatar
Thanks much.
Thank you as well.
I bought so much stuff, I honestly don't remember. I will say this though, BUY IN BULK! lol The more you buy, the better deal they can get you.
::SELLING::
Old 11-17-2009, 07:44 PM   #956
flatlander757
Now in the 937
flatlander757's Avatar
I saw your TJ in the "most built DD" thread and I've gotta say it is really impressive to me... It makes me want to get another TJ and start over again to make a smaller monster
I'll have to bookmark this and read through the whole thing some time.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Old 11-17-2009, 07:49 PM   #957
Redarcher89
Redarcher89's Avatar
bulk is the way to go. James, do you know if they are going to make those Pitbulls in 37x13.50 or not. I can't find them on therir site.
Redarcher89 is offline   Reply With Quote
Old 11-17-2009, 07:50 PM   #958
Bennettj13
Bennettj13's Avatar
It's a lot of BSing, but you can see how much I flip flopped back and forth. You did a great job on yours man. It's impressive. I'm in the same position you are though. Finally drivable, but not wheelable.
::SELLING::
Old 11-17-2009, 07:51 PM   #959
Dmcastino
Wow, that steering is just massive! I'd like to see someone try and bend that tie rod
Dmcastino is offline   Reply With Quote
Old 11-17-2009, 07:53 PM   #960
Bennettj13
Bennettj13's Avatar
Last I knew they were going to be 37x12.50 R17's next. They aren't on the site just yet. Shoot an email to tireinfo@pitbull. I think that's the addy, it's on their site I know. Don't tell him I sent you though. He's been getting all kinds of emails and phone calls because of me haha. Actually tell him James said to quit slacking and get them out.
::SELLING::
custom, indyorv, jk, lots o' spares, orange, pitbull, pumpkin, rockers, rubi axles, skinny pedal, tnt, triangulated, truss, tube fenders
Glock Forum
