#676 | ||
So where are the updates from yesterday?!?!?!?!?!?!?!!?!?!?!!?!?!?!!?
I will say to you what I said in flatlander's build. Quote:
JFI Member #7: Helping out the Scammed 2004 Rubi: Ready to Kill the Chrome! Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s Do the Jeep Wave :D 0|||||||0 Take 95% of what I say as a joke/sarcasm!-Thomas |
#677 | |
I'm a big meanie head
Eat. Sleep. Jeep. Repeat. That's all it's been. Too tired to update tonight. Another early/long day tomorrow. Cross your fingers. I just might be driving it home tomorrow night. LOTS of pics coming. Stay tuned.
::SELLING:: Hornblasters Shocker S4 horn set with some extras $210 shipped. (It is not OBA, just an accessory for OBA) "LCOG" isn't cheap and it certainly isn't easy. If you think so, you are doing it wrong. If you aren't willing to put in the effort, don't label your build "LCOG". You are just a cheap ******bag. |
#678 |
Under Construction
Been working like crazy the last couple of days, tires are mounted with airsoft BB's, truss's are welded up with the exception of the shock mounts, front axle is bolted up to the arms, rear coil spring relocators are in, and we finally got the tie rod ends. Yet to do: machine knuckles for 1 ton rod ends, reassemble the front axle, reassemble rear brakes, bend rear brake lines, cut off and weld on new upper track bar mount, weld up shock mounts, install front drive shaft flange adapter, finish installing rear axle, adjust all control arms to length, do steering alignment, bleed brakes, and I'm sure there is more that I'm not thinking of yet. Once work slows down a little we may have time to post all the pics, but not right now. For now it's sleep time.
#679 |
jeep looked good last night, all I can say is that those tires are awesome.
Like they said, started getting it linked up, ran into a few road blocks, but thats expected. I took lots of pics (while they worked) but they shouldnt get posted until tonight or tomorrow cus their asses better be working right now |
#680 |
Wow, you guys really got a lot done.
James, like my sig says, it is either a joke or sarcasm 90% of the time. Get some sleep, be well rested. Can't wait for the pics. I am also surprised that you guys are getting the axels in already, I didn't that that was going to happen yet.
#681 |
Keyser Soze
The back end is sitting on it's tires
#682 |
TITS
Just got a picture message of the Pumpkinator sitting on all 4s.....mmm mmm mmm.
#683 |
so where is my pic?
/me steals imped4now's phone Ahhhhh, that is beautiful
#684 |
looking good
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs |
#685 |
issues man, issues....if you are religous, say a prayer for James' sanity
Oh, but the jeep looks sick |
#686 | |
TITS
James is lucky that the Jeep Gods' favorite color is Impact Orange. Therefore, things will work out just fine. |
#687 |
Sorry for the lack of updates. I'll post as soon as this hiccup is figured out. I'm really unhappy right now and want to get this figured out before it seems as if I'm badmouthing anyone. Bear with me. Hopefully this gets resolved today. I'll get some pics up after work tonight.
#688 |
Under Construction
I'll help out a little for an update, it's sitting on all four tires but we still have some bugs to work out with the suspension. Otherwise, we are waiting on a tapered reamer to show up, so we can modify the passenger side knuckle and pitman arm for the new 1 ton steering(that isn't supposed to be here till Thursday some time, so thats the largest hang up), still need to route the brake lines on the rear axle, hook up the rest of the brakes, bleed the brakes, weld up the shock and sway bar mounts on both axles, need to do the rear outboard kit yet, hook up the flange adaptor for the front drive shaft, and get a measurement for the rear drive shaft.
I'll let James tell the rest of the story. |
#689 |
Keep the faith man, you are getting so close!!
#690 |
TITS
James, make sure you are eating. At this point in my build (when I realized the truss was welded on at the incorrect angle), I concentrated solely on the jeep and not my own health. By this point, I had lost 10 lbs and was almost to insanity. EAT and give Megan some lovin every night.
![]() But seriously, everything will be fine. At least you don't have to cut off one of your beautiful trusses due to stupidity. |
| Tags |
| custom, indyorv, jk, lots o' spares, orange, pitbull, pumpkin, rockers, rubi axles, skinny pedal, tnt, triangulated, truss, tube fenders |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
