The Pumpkinator's Build Thread - Page 16 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > The Pumpkinator's Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 08-12-2009, 11:31 PM   #226
RockRodHooligan
RockRodHooligan's Avatar
Originally Posted by Bennettj13 View Post
I've yet to install the body lift. If I get the Jeep back from the shop tomorrow, I'll probably do that then. When dealing with the MML, we loosened all the body mounts. They came out without a hitch. It WILL be an uneventful day.
You know it might go ok, now that I think about it things only go wrong when it's just me and you working on the Jeep. I know it's not my direct fault(ORO sent the wrong parts, the bolt broke off while you were wrenching), maybe it's the polar opposite of 3rd times a charm. Guess you'll find out tomorrow.
96 XJ:Parking lot Pre-Runner
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline   Reply With Quote Quick reply to this message
Unread 08-13-2009, 11:59 AM   #227
Bennettj13
Well, the machine shop just called and said they are finally getting to the Jeep now. The guy said he'd start it tonight and probably finish it in the morning. So bleh. So much for the body lift today.
::[B]SELLING HALF OF MY JEEP[/B]::
[url]http://www.jeepforum.com/forum/f33/?uid=152304[/url]
Bennettj13 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2009, 11:03 PM   #228
Bennettj13
The machine shop ran into problems, so I get to keep waiting. They didn't get to it like they thought they were going to. So, they are taking care of whatever, and they said I'll get it back tomorrow. I'm tired of waiting. Here's hoping.
Unread 08-17-2009, 08:51 AM   #229
gribbles
damn....well good luck bro! You place that order yet?
IndyORV
My Jeep
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline   Reply With Quote Quick reply to this message
Unread 08-17-2009, 09:37 AM   #230
Bennettj13
No TNT order yet... complications have come up. I'm working through them still. I think I should have it figured out here soon.
Unread 08-18-2009, 12:15 AM   #231
Bennettj13
No Jeep today either. I called the shop twice, left two messages. Tomorrow I'm going to stop by. If they try to pull any ****, we are going to go around. I can feel it now. Just one more chunk out of my build money. With everything else going on, it's getting more and more aggravating. Grrr.
Unread 08-18-2009, 11:37 PM   #232
Bennettj13
I picked up the Jeep at 3. It's done. The guy did a great job. 180 bucks total. But the guy replaced all the bolts (even the ones we did). Basically I paid 180 bucks for a MML install that took almost a full week. Meh. Either way, I met the owner of the shop, who actually ended up doing the work, and is a cool *** dude. He wanted to know if I'd bring the Jeep by when it's done. On top of that, he wants to come wheeling with us sometime. Apparently he's got dirtbikes and quads, and his buddy has a an old cutlass on a blazer frame. I suppose it's one of those things that I'll have to see to appreciate. haha
On an unrelated note, the TNT order has officially been placed. Lots of goodies there...
Front Tube Fenders 4.5" Flare
Rear Tube Fenders 4.5" Flare W/ Extended Wheel Well Opening Corners Cut for Flush LED Lights
Rocker Guard W/ Step
JK to TJ Front Axle Truss
JK to TJ Rear Axle Truss
TNT LA Upgrade W/ High Clearance Bellypan
Extended Stainless Steel Brakelines
Outboard Rear Shock Kit
Y-Link Limit Strap Kit
Custom Draglink
Custom Front Trackbar
Bob and Rod at TNT are both awesome. I can't say enough about those guys.
I also updated the first post.
I'm probably putting the BL on tomorrow. There is about 1/4" between the fan and shroud now. And I'm thinking that I'm one good bump away from fan destruction. So, the BL is currently a priority.
Unread 08-19-2009, 08:28 AM   #233
gribbles
I
eh....you'd lose your shroud before the fan would go....mine used to rub like hell
IndyORV
My Jeep
2007 WK CRD
Unread 08-19-2009, 11:01 AM   #234
Imped
Imped's Avatar
Awesome!!! Dude, that's the sexiest single order I've ever seen. I can't wait for it to arrive so I can rub my greasy fingers all over the beautiful welds.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 08-19-2009, 11:10 AM   #235
INCA
agreed! that is an amazing order! cant wait to see it!
INCA is offline   Reply With Quote Quick reply to this message
Unread 08-19-2009, 11:59 AM   #236
Bennettj13
It is indeed sexy. I'm going to get some of that seam sealant stuff for the tubes to finish them up all nice and pretty. That's down the road though. The tubes probably won't go on until I can take some time off, and spend a few full days working on them. I'll have to clean them up, hit them with seam sealant, grind them, prime them, pull the stock fenders, mount the tubes, pre-mount everything under the fender and drill all the holes for lights f/r, unmount all that, take the fenders off, have Rod paint them, then remount them, install the lights, and then we should be good to go. It's going to be a stressful few days. I HATE electrical work, so I am really going to try and pawn that off on someone, not going to lie. It just pisses me off to no end.
I figure the tubes will go on first. I can worry about getting the axles on and the lift in after that. Then comes the other stuff, like checking to see if the air tank will fit under the jeep, running air lines, air horns, finishing getting the winch wired up, and any of the other random **** I'm not remembering off of the top of my head.
Anyways, time to head over to do the BL.
PS, the TNT order is 720 lbs... lol the UPS dude is going to hate me forever.
Unread 08-19-2009, 03:11 PM   #237
spyder6
Got that Toyota chit
spyder6's Avatar
2010
lol my UPS guy is always curious what im ordering. hes going to hate me for my upcoming 1000 lb order
i hope its all delivered on the same day
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 08-19-2009, 05:50 PM   #238
Bennettj13
I got the BL in. It took about 30 minutes (haha Connor). I screwed around forever picking up the garage and **** getting my junk and tools out of the way for my mom since I kinda took over since I've been working on the Jeep over there. I've still got a hell of a rake to the front from the winch. I'm going to need to put spacers up front. But I'm not going to screw with it until the TNT **** is all on. No pics today, it was raining like crazy, so I didn't bother. Anyways, that's it for today.
The Jeep doesn't look lowered anymore lol.
Unread 08-19-2009, 07:57 PM   #239
Imped
Imped's Avatar
Good job man. I assumed you would work slower.
OlllllllO
Float Test Build
IndyORV
Unread 08-20-2009, 08:52 AM   #240
gribbles
well Connor, you just automatically added in the standing around and talking time - or the breaking something time that you usually incur
jk buddy
IndyORV
My Jeep
2007 WK CRD
76% lcog , custom , custom suspension , indyorv , jeep on jackstands , jk , lots o' spares , orange , overcompensating , pitbull , pumpkin , rockers , rubi axles , skinny pedal , slowest build in history , tjk , tnt , triangulated , truss , tube fenders
