Quantcast Project "YJ Unlimited" Build-Up - Page 8 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Project "YJ Unlimited" Build-Up
Old 02-14-2009, 12:27 AM   #106
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
props man, hang with it. good thread!
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
2009 COTY
Originally Posted by wgirvine View Post
You want my opinion? Ok… Shut the hell up... That’s my opinion.
chris87xj is offline   Reply With Quote
Old 02-14-2009, 12:31 AM   #107
Barrio
looking great!!!!!!!!!!
www.offroadjunkies.net
www.pgh-offroad.com
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline   Reply With Quote
Old 02-14-2009, 10:28 PM   #108
ak4774
I love this thread, hang in there and good luck
ak4774 is offline   Reply With Quote
Old 02-14-2009, 10:29 PM   #109
95greenrio
What type of fiberglass fabric and resin are you using? Is it holding up pretty well?
1995 YJ Rio Grand - work in progress
95greenrio is offline   Reply With Quote
Old 02-15-2009, 12:05 AM   #110
frontlinedude
AWESOME!! Nice work so far. Keep it up.
Can't wait for more
'97 BLACK TJ Sport
4.0L 5 speed Man.
4in lift
35"x13.5 Toyo Open Country M/T
Herculined
frontlinedude is offline   Reply With Quote
Old 02-17-2009, 11:16 PM   #111
DylanAnd
i know i've posted on here a couple of times
already but you doing great man keep it up
i'm so stoked to see this jeep finished
DylanAnd is offline   Reply With Quote
Old 02-25-2009, 07:03 PM   #112
chocflip201
So just a little update... things are a little better than they were before so now I can finally get working on the Jeep again. .
Some things that I've accumulated for the project since the last post-
-2nd frame (you'll see why shortly)
-My own MIG welder
-A pair of front racing seats
-Half doors
-A metal-cutting capable band saw
-Replacement body bushing mounts
And I've
-Cleaned up/stripped suspension related brackets/sandblasted/repainted both axles.
-Have gotten the body off of the trailer finally getting it all ready to go.
So now I will start work on the frame stretch. I know exactly how I'm going to do it and if all goes right and I do a good job, the joint will be seamless and very strong and only someone with an educated eye will be able to tell where I stretched it. Stay tuned! *sigh* glad to be working on the YJ again.
I'll post some small pics up of all the new parts.
chocflip201 is online now   Reply With Quote
Old 02-27-2009, 10:13 AM   #113
whittlecj
1980 CJ7
Welcome back, now post progress pictures!
______________________________________
In Process: 2002 4.0L and NV3550 Swap
whittlecj is offline   Reply With Quote
Old 02-27-2009, 02:32 PM   #114
varent
lol. always remember that jeeps eat speed bumps for breakfast. so when life becomes a speed bump you dont really have to worry too much. lol
varent is offline   Reply With Quote
Old 03-01-2009, 04:14 PM   #115
1992 renagade
Keep up the good work man and post some update when you can. Project looks great and it seems like you have a plan that is working great for you.
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications www.atozfabrication.com
Blue Mountain Jeep Alliance www.bmja.org
Delaware jeep Association www.delawareja.com
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline   Reply With Quote
Old 03-10-2009, 10:02 PM   #116
chow40cal
Thats a crazy undertaking. I once cut 13.8 inches out of a chevy shortbed and put my body up on a K10 chassis. I was about 17 at the time too. You're bringing back some great memories. Keep up the work.
chow40cal is offline   Reply With Quote
Old 03-16-2009, 11:30 AM   #117
lifted1992yj
where's the updates?
lifted1992yj is offline   Reply With Quote
Old 03-16-2009, 12:23 PM   #118
ibreakmyJEEP
1974 CJ5
Yea i want more
Take it out and play with it!
ibreakmyJEEP is offline   Reply With Quote
Old 03-16-2009, 07:29 PM   #119
chocflip201
Getting ready to file mutiny are we?
__________________________________________________ ______
Well I'll fill you in some.... When I was taking the black section of the body off (Jeep #2) I broke off one of the body mount bolts (at the very back of the tub).. IT KICKED MY @$$ for hours.. I ended up breaking: 2 drill bits, and and easy out... then I ended up cutting out the "Body Mount Retainer" (the threaded steel block that sits inside the tub).. .Then I tried everything to get the bolt out and ended up breaking another drill bit, and dulled 2 more... so I went to the stealership and ordered a new one... ($9 ) and then I remembered that I had another one (from the part of the red tub that I cut off) and so I canceled my order, then went and hacked the other one out of the tub... wrestled that bolt out......
Bought the right body mount bushing set finally... (other ones didn't work) and sandblasted both sections of frame... there was some decent rust underneath the rear upper shock mounts on both sides so I'm in the middle of fixing that (I'm doing a write up on "Seamless frame rust repair") .. hopefully tomorrow or wednesday I will conjoin the two frames and will have some pics for you guys!
Oh also my gasket kit came finally from SummitRacing so when I get my frame all done up I can rebuild the engine...
Old 03-18-2009, 04:11 AM   #120
chocflip201
K well I decided not to do a write up on the frame repair because its just my way of doing it and you may have another way... but I will post step by step pics of what I did....
Phase 1- Destruction
So when I cut off my rear shock mount brackets, I noticed that underneath was rusted pretty badly... and after sandblasting the frame I was able to knock a hole in one side with a screwdriver... (this was the only spot that was rusty... everywhere else was fine and rust free)... so I decided it was best to just replace that section... so I sprayed the frame down with some rustoleum primer to prevent the newly sandblasted frame from rusting, then I grabbed the angle grinder with the wire wheel attachment and scrubbed off where I wanted to cut out...
Side-1 (passengers)
Side-2 (drivers)
Then I figured out where the edges of the rust damage was, and using my handy-dandy square and some masking tape, I marked the areas of where I wanted to remove... (even though one side was a little worse than the other... I cut out identical peices)
Now I wanted to remove any possiblites of stress risers by having a sharp corner where the frame could end up cracking...and so I wanted nice rounded corners... so I marked in 1/4" each way on each corner with a dummy punch...
And then drilled a 3/16" pilot hole....
And then followed with a 1/2" drill bit...
And finally played connect a dots!... With a cutoff wheel on an angle grinder...(my fav tool to cut with.. makes a nice straight clean cut.)
In all reality I probably could have gotten away with doing it another way... but I didn't want to risk any chances of having thin material there and end up cracking...
This is just one way to do it.. and its the way that I liked best and the way that I chose....
I had to do a lot of running around today (grr... had to pay another speeding ticket today...so I wasn't able to get much more finished as I wanted to... but tomorrow it should all be back together and then I can conjoin the frames!... Just to let everyone know before hand.... I will reinforce this area to eliminate a weak link in the frame...
Glock Forum
