#91 | ||
Updates are coming I promise I've just been really busy lately ![]()
My "YJ Unlimited" Build-Up Thread |
#92 | |
Understandable. Just get to work on it!
www.offroadjunkies.net www.pgh-offroad.com -OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap. -Rio Red 1995 Ford Mustang- Daily Driver Quote:
#93 |
Keep em coming loving it so far
#94 | |
2004 TJ |
#95 |
updates???
ok so i check this for updates everyday and i'm pretty sure
i have this whole thread memorized by now... anyways please more updates i want to know how this is coming along =] ![]() |
#96 |
Junior Member
Waiting for another update . . . . .
#97 |
Vermonter
i want updates. both you and "envy" stopped posting. i want to know how its all coming along
#98 |
No Updates?
Hope the YJ is comin' along, miss seein' the progress though.
#99 |
yeah sorry i've been pretty busy lately progress is still coming its just been a little slower for a while as I've been juggling another project (installing a 440 cc big bore kit into my 400EX but now thats all done and over with so now I can go back to putting my full attention into the jeep. The top is really really close I havn't been taking pictures because I brought the jeep home (it was about 30 miles away before when I was working on it so that I could have a nice warm shop but it was to far to drive daily so I brought the top home and I've been working on it in the shed in my backyard. Kinda cramped, and its colder than the shop before so it takes about twice the time for the resin to harden). Comin up soon will be sandblasting of the frame and getting it cleaned up and then I'll be putting the body on the frame.
#100 |
So I'm pretty sure all of you have given up and thought that I've died. I havn't.. I ordered some stock windows that were supposed to fit the stock LJ top but when they got here they were ones for a TJ not an LJ so I sent them back and re-ordered the new ones. luckily it was COD so i didn't have to pay for them. Also I got the Disc Brake brackets tonight man these things are beefy.. I went with the bolt ons because the inspection places would like to see the bolt ons rather than the weld-ons. A few grade 8's and they'll be more than strong enough. I may even weld them on to the housing after the inspection just for added strength. I bought these though because they are pre-bent and dont have a need for a cheap crappy spacer design like other distributors.
![]() And what they will look like mounted. (Picture is of a D70, not a 14Bolt, so they are slightly different) ![]()
#101 |
Those look nice. Ready to see the finished top, sucks about the windows.
#102 |
Well this isn't really the update that most of you guys want to hear, but needless to say today was pretty much the worst day in a long long time and I don't exactly know when I will be able to work on the Jeep again it might be a few weeks. But here are the 1 ton axles that I will be putting under it eventually.
1978 Ford F-350 Kingpin High Pinion D60 w/35 spl. inners and outers.-$850 ![]() GM 14 Bolt. 30 spl... - Came with a Detroit Locker and a low gear ratio carrier (4.56 and numerically higher, so that I can run my 5.38's) -$200 ![]() Both axles came with free, stock-sized tires. This will make it easier to wheel around during the build-up rather than the 40's all the time. Front axle has Dual-Piston calipers, and the rear axle will recieve a disc-brake upgrade with E-Brake compatible calipers so that I won't have to run a line-lock. Front axle will recieve Double-Shear Hi-Steer arms, an Eaton electronic E-locker, and both will get regeared to 5.38:1 :sigh:
#103 | |
Bomb proof.
#104 |
Hopefully things have gotten better? I miss this thread!
______________________________________ In Process: 2002 4.0L and NV3550 Swap |
#105 |
Still not quite back to normal just yet, I work with my Dad and our boss kinda through us under the financial bus a few weeks ago so I havn't been able to dump a bunch of money into the Jeep right now so I've been doing the free stuff like buffing all the suspension tabs/leaf spring perches off of the axles and getting them cleaned up and ready to be rebuilt. And I have been saving up extra side money so that I can finally purchase my own MIG welder and not have to borrow other peoples welders (I have an arc of my own, but its just not the same). I will post up a picture tommorrow of the cleaned up axles they look pretty good. And with my tax return (which I should be getting the beginning of next week) I will be able to pick some speed back up on the Jeep and get it going steady again. Just to let everyone know I'M NOT GIVING UP ON THIS JEEP, ITS JUST A SMALL SPEEDBUMP.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
