Project Wrong way. - Page 51 - JeepForum.com
post #751 of 1028 Old 10-21-2012, 11:11 AM
bigdhamYJ
My guess is by now it has become a pile of broken parts that have sat for years and rusted to the ground but magically reassembled themselves because the mighty antiJF spirit within this rig is too strong to be forgotten! A machine of this caliber must be a unicorn! IT CAAAAAAAAAANNNNNNTTTTTT BEEEEEEEE REEEEEEEAAAAAAAAAALLLLL!!!!!!
"Who knew coolant keeps the motor cool?"
Check out my Heep "build"
http://www.jeepforum.com/forum/f22/bigdhamyjs-1993-yj-build-slow-1284516/
bigdhamYJ is offline
post #752 of 1028 Old 10-21-2012, 02:03 PM
9703tj
Originally Posted by aw12345 View Post
You know that you are going to have rubbing issues front and rear right.
35's stuffed get into the fenders pretty good these will do the same plus with the steering cranked and a front wheel stuffed you will rub bad on the back of the front fenders. Also start messing with geometry in the rear, raise the lower control arms on the rear axle, it will take care of a lot of the wheel hopping. Trust me it works and isn't all that much work
Thanks for the heads up about the rubbing! I plan on doing a little bit of work to the suspension, but I'm not sure how much I want to do to the axles that are in it now. I'm going to start hoarding parts to upgrade to wontons, and once I've got everything I need to make the switch I'll be swapping everything all at the same time.
Originally Posted by midnight_f150 View Post
I think this build is heading toward the darkside but I'm going to enjoy watching this build that some will call a JF epic fail.
Originally Posted by TJRHD View Post
Has it exploded yet?
Lol! I just got the other two tires installed on the other side today. I might take it wheeling next weekend and see how it does in Pungo.
9703tj is offline
post #753 of 1028 Old 10-21-2012, 02:04 PM
9703tj
I didn't know my Jeep had Anti JF in it?
9703tj is offline
post #754 of 1028 Old 10-21-2012, 02:09 PM
aw12345
See no anti anything in yer lil Jeep. Just a 4 popper with some nice shoes is all!
All you want to screw with is where the lower control arms attach to the rear axle. Get the bolt holes in the lower axle side mounts even with the center line of the axle. Makes the lil Jeep climb better with a lot less wheel hopping
Kinda like this
Flat
Not so flat
aw12345 is offline
post #755 of 1028 Old 10-21-2012, 02:10 PM
TJRHD
Hey Art, can you drill a new hole higher up on the factory ca bracket? Would that even be enoigh to help?
NOT A HATER
TJRHD is offline
post #756 of 1028 Old 10-21-2012, 02:19 PM
aw12345
Hey Art, can you drill a new hole higher up on the factory ca bracket? Would that even be enough to help?
Yes you can and yes it helps
aw12345 is offline
post #757 of 1028 Old 10-21-2012, 02:21 PM
TJRHD
Thanks, i was thinking about doing that and it may be something that necro could do cause he is in a similiar situation.
NOT A HATER
TJRHD is offline
post #758 of 1028 Old 10-21-2012, 02:24 PM
bigdhamYJ
Haha, just poking fun at it again. Have to say man, those 37's and racelines look preeeeeeety nice!
post #759 of 1028 Old 10-21-2012, 03:48 PM
9703tj
Kinda like this
Flat
Not so flat
I can change the lowers without having to mess with the uppers?
You took the exact question I was gonna ask right outtamy mouf!
Lol, Thanks!
9703tj is offline
post #760 of 1028 Old 10-21-2012, 03:49 PM
9703tj
Today I painted the hubs on my axles (Thanks Alex!) since I'm not running center caps with these rims. Then I put together the 2 drivers side rims and tires and installed them on the Jeep. Then I took a ride up to Walmart to get some groceries and see how it rides. It rode pretty good for the most part, typical Bias ply Swamper ride. It's funny to hear the air soft pellets all fall to the bottom of the tires as I slow to a stop.
9703tj is offline
post #761 of 1028 Old 10-21-2012, 04:01 PM
99_TJ_Wyoming
Time to change your signature, you found it.
(FFS dont start up with the avatars again though)
When you getting the 5th Irok & beadlock for the display out back?
99_TJ_Wyoming is offline
post #762 of 1028 Old 10-21-2012, 04:41 PM
9703tj
I'm actually selling the tire carrier. I plan on just carrying a spare in my tow rig. I'll prolly find a worn down bald 38" tire for $50 on craigslist and use it as a trail spare. The hard top and tuffy security deck enclosure are for sale as well.
9703tj is offline
post #763 of 1028 Old 10-21-2012, 04:49 PM
aw12345
Yes
aw12345 is offline
post #764 of 1028 Old 10-22-2012, 04:44 PM
9703tj
Ribbit!
9703tj is offline
post #765 of 1028 Old 10-22-2012, 04:45 PM
9703tj
Yes
Can I also do the same thing to the fronts? My lower control arm mounting brackets are all banged and bent up on the front...
9703tj is offline
Project Manager special was Project Wifey-(TJ Wrangler) wfochris Jeep Builds 42 10-22-2011 04:00 PM
my 3year project became a 6month project gattaca37 Jeep Builds 7 03-21-2011 02:49 PM
That's just all wrong. never monday Jeep Builds 51 10-22-2010 10:22 AM
Am I posting in the wrong areas??? capejeepguy67 Jeep Builds 6 09-13-2010 02:00 PM
