Project "VICTIMIZED" (Pic heavy build thread) - Page 7 - JeepForum.com
post #91 of 236 Old 02-02-2014, 04:23 PM Thread Starter
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
Rear fenders and rocker guards
Necromancer_tat is offline
post #92 of 236 Old 02-02-2014, 04:46 PM Thread Starter
Necromancer_tat
post #93 of 236 Old 02-06-2014, 03:38 PM Thread Starter
Necromancer_tat
Today I picked up a new Diehard Platinum battery from Sears.com. It's $229 at Sears, but $183 online right now and you can pick it up from your local Sears auto store.
For those that don't know, the Diehard Platinum is made by Odyssey Batteries, and the same exact battery by Odyssey is over $300!!! https://www.google.com/shopping/prod...ed=0CHgQpiswAg
The best bang for the buck battery wise for a Jeep!
post #94 of 236 Old 02-07-2014, 05:13 PM Thread Starter
Necromancer_tat
I ordered some rims from Savvy a bit ago, and like Gerald says, I emailed him and told him what I wanted, he quoted me an awesome price, and I placed my order...
Flash forwards a few weeks and.....
When I got home from work today, and these were on my front porch:
Opening up the thin box presents me with A beadlock ring wrapped in a hairnet style protective cover:
The beadlock ring, almost as pretty as an angels halo!
The bead retention surface, machined to a jewled perfection!
The recessed holes for the bolt heads so they don/t get dammaged on rocks:
These rings are a half inch thick!
Also inside the thinner box is another smaller box, filled with grade 8 zink plated bolts and washers:
Inside the larger box is a rim, covered in another hairnet styled protective cover:
Inside the hairnet is some protective foam, a sticker, and an instructions sheet:
These rims are gorgeous! I've dated girls that didn't look this good!
Very high quality machine work through out!
This is my second set of Raceline rims, and the next time I need rims they'll be the top of my list again! The amount of quality that you get for the price is unmatched IMO! It would be a hard sell to talk me into buying something else!
post #95 of 236 Old 02-16-2014, 04:48 PM Thread Starter
Necromancer_tat
Uh oh! I can has welder!!!
post #96 of 236 Old 02-16-2014, 05:18 PM Thread Starter
Necromancer_tat
post #97 of 236 Old 02-16-2014, 05:29 PM Thread Starter
Necromancer_tat
post #98 of 236 Old 02-18-2014, 03:49 PM Thread Starter
Necromancer_tat
Finishing up my tire carrier.
post #99 of 236 Old 02-18-2014, 04:23 PM Thread Starter
Necromancer_tat
post #100 of 236 Old 02-19-2014, 03:39 PM Thread Starter
Necromancer_tat
post #101 of 236 Old 02-19-2014, 03:57 PM Thread Starter
Necromancer_tat
post #102 of 236 Old 02-19-2014, 07:36 PM
gst95dsm
Chop, Wheel and Rebuild..
gst95dsm's Avatar
Why does it look so tall? Put the new wheels/tires on already!!
gst95dsm is offline
post #103 of 236 Old 02-20-2014, 03:07 AM Thread Starter
Necromancer_tat
Thats the 4" Currie/Savvy lift kit. I still need to install the 1" body lift before I install the 35's. I'm also focusing on the stuff that I need to make it pass Va. safety inspection. I need to switch out my headlights and tail lights, and I need to add front side marker lights and I think I should pass after that.
I still have the UCF UHC tummy tuck and engine skid, the brown dog 1" MML, a 1" body lift, Novak cable shifter to install, and then I'll put the rims and tires on after that.
I also need to fix the front of the frame so I can reinstall my front bumper and install my winch, and I need to install my front driveshaft and adjust my front pinion angle, and I need to figure out which OBA I'm going to use, and then get it installed and plumb up the front ARB locker and install the switches.
I still have a lot to do. Its frustrating having most of the stuff but no time to work on the Jeep.
post #104 of 236 Old 02-20-2014, 07:05 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
PM me if you are thinking of selling the rear lights.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #105 of 236 Old 02-20-2014, 07:25 AM
gspup
5" of lift with 35's will give you some nice belly clearance...it looks like you can stuff the 35's on as is so we can all see how it's gonna look. Just sayin.
gspup is offline
