#1 | |
Project Triple-B
This is a Backwards Budget Build. I'm shooting for a LCG (This was my original idea long before LCG became a 'trend') Jeep intended for comfort, practical use, and performance. It's backwards because I'm focusing on important and useful components of the Jeep first, instead of bolting on a 4" lift and 33s and then wondering why it doesn't perform like it should
.The '98 TJ was a steal with a Salvage title, making it a perfect candidate for a budget build. 4.0, AX-15, 30/35, 3.07 gears, 31" tires (OEM was 205/75-15 or 27.5"), and 158k on the ODO. Runs as good as new. 1st stage plan: $1,000 budget 1 - Replace wheels/oversized tires with Treadwright tires on a set of oem steelies. 2 - Front tow hooks 3 - Custom rear bumper for a better departure angle 4 - Fender flare trimming 5 - Interior paint/trim change & restoration 6 - Basic sound system improvement 7 - Communications (CB radio/antenna) 8 - Lock the front differential 9 - 2" front/1.25" rear spacer lift 10 - V8 ZJ tie rod 11 - Basic armor (if funds are left) 2nd stage plan: $1,500 budget 1 - LOWER GEARS (DIY?) 2 - Chromoly axles (if D35 is kept) 3 - Highline, Metalcloak, or flat fenders 4 - 31-33 inch tires (depends on gears available) 5 - On-board Air ![]() ![]() ![]()
#2 |
sounds interesting. ill be watching this build
Photographer at heart Have questions about something photography related? Click here!Like Coheed and Cambria? Join the club! My Jeep Build My Photography (New as of Jan. 25th) 1982 Motorcycle Build |
#3 |
The first change was to pull the CD changer from the trunk. CDs were skipping over small bumps on the road - it would never make it on the trail.
Next, I pulled the front bumper end caps, then threw on the wheels/31" tires from my XJ to see what they looked like. I like the look of the 31s on stock configuration, but with some less-backspaced wheels, and some fender/flare work (highline or similar later), 33s should not be a problem (after gears, of course). ![]() Last edited by 2GPS4ME; 05-27-2010 at 01:57 AM.. |
#4 |
As of late, I have done the following:
- Install Crown Automotive mirror movers (to go doorless) - Install adjustable door straps - Tightened the parking brake - Chose a color for the headlight bezels, swaybar cover, and fender flares - Bought a set of Treadwright tires @ 235/75-15 Next on the list: - Fender flare painting & trimming - Interior makeover (eliminating the overwhelming puke tan color) - Front tow hooks - Swaybar DQ installs More pics to come. Gotta have the pics, or it's just wasted typing. ![]() Last edited by 2GPS4ME; 06-10-2010 at 01:51 PM.. |
#5 |
Crown Automotive #57005 mirror movers - $28.99
Rubber stubby antenna - $3.99 (TJ didn't have an antenna at all). ![]() Last edited by 2GPS4ME; 04-13-2010 at 01:19 PM.. |
#6 |
Front tow hooks/keepers installed - $29.98
I also removed the front swaybar until I get the disconnects installed. The color on the swaybar cover is what will be used for the fender flares. Krylon Fusion textured charcoal - $5.99 for a can. Will also be painting the bezels. Bright, shiny chrome = ![]() Last edited by 2GPS4ME; 04-13-2010 at 01:19 PM.. |
#7 |
#8 |
Had to make the Jeep custom to myself.
'Trail Tested' (instead of 'Trail Rated', for you newbies) - $5.98 ![]() |
#9 |
Nice start, you'll be happy with the treadwright atg's. I'm more than impressed with my set.
1988 Cherokee laredo: 4.0L/auto/4x4,c4x4 tow hooks, d-ring reciver hitch camo paint 1995 Cherokee: HO 4.0L/auto/4x4, 3.5 custom lift, 31/10.5/r15s treadwrights. 1985 CJ-7 3in shackle lift bald 31's 1993 Cherokee (wrecked/parts) |
#10 |
Well, I did some swapping the other day, and a new friend will be constructing a nice hi-profile rear bumper with integrated receiver, etc.
That will finish the recovery points for the TJ! |
#11 |
Comparison of the worn out door straps vs. the new adjustable straps - $8.99
#12 |
Upcoming...
- Install CB radio and antenna (from my CJ) - Changing trans fluid to Redline MT-90 (Hoping to help the 1st-to-2nd shift blues) - Powertrax Lock-Rite is in the mail for the Dana 30! |
#13 |
#14 |
Quadratec 'built' a TJ in stages, so I'm doing the same. But differently.
As of now, STAGE 1: Treadwright tires (ATG) - $297 D30 Powertrax Lock-Rite - $175 Front tow hooks - $29.98 Rear bumper - $Traded parts Mirror Movers - $28.99 Door Straps - $8.99 1.25" spacers - $40 Spray paint - $5.99 Rubber antenna - $3.99 Front rotors/pads - $101.04 Decals - $5.98 TOTAL = $696.96 Last edited by 2GPS4ME; 06-10-2010 at 04:40 PM.. |
#15 |
TITS
Nice job man, very thrifty.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
