Project Ton Ton - 1 Ton Cherokee HP60/14b - Page 4 - JeepForum.com
post #46 of 301 Old 09-28-2011, 04:39 PM
86cherokeek20
1986 XJ Cherokee
wow yeah hopefully ya can get your moneys back...i risk alot of money on cheaper products then read the reviews...sofar ive been lucky but idk if id trust those lol...good luck to ya tho
Bruno the jeep-boatsides, 14b, dana60, linked, tubeframed-exo to come-build in progress!
tow rig-92 f150 with 351 and 4 spd
86cherokeek20 is offline
post #47 of 301 Old 09-30-2011, 12:50 AM Thread Starter
andrewmacc
Ordered the FX-R projector kit. Pricey, though.
All ready to get regeared. I take it to my guy tomorrow afternoon. He's got a pretty full schedule so he'll plug away at it for a few days before I get it back. But for the price, there's no argument. $300 for 2 axles.
Also you'll noticed it's stripped down for a disc brake swap. This last second revision shiet is really pressing on my wallet, there's another $350 for disc brakes.. Still have to get tube for the 3 link, there's probably another $300.. then driveshafts. Then fluids. And shifters.
Crap.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #48 of 301 Old 10-06-2011, 08:22 AM Thread Starter
andrewmacc
Well, been pretty busy this week with non-Heep related stuff. Sold a truck, had some personal crap, got my tattoo, etc etc, but I did manage to pick these up:
Patterns look good:
Metalmart will have my steel tomorrow so I can finally make my crossmember.. I can't turn this thing around to rip out the front until I can get the jack out from the transmission, so that's sort of put things on hiatus.
Oh, ordered some RuffStuff disc brake adapters, and the appropriate hardware from RockAuto including new dually studs. Always funny to hear people getting crazy deals.. sounds like I need to make some friends in high places! Everyone always goes "oh you can disc brake swap for under $200!" Yeah? Well, the brackets cost $50 + shipping, and more often than not you should use new studs, which are about $40, and then rotors set you back around $40 each, and then calipers the same. Then there's shipping if you get it online (because even with shipping costs, it's cheaper than at Lordco).
Also noticed how inconveniencing it is to no longer have a girlfriend with a pickup truck.. Used to be a simple matter of seeing if she was free, now it's a game of "let's see what poor friend I can hassle into helping me out this time"..
Note to self: next girlfriend should have pickup truck. (I jest. Mostly.)
post #49 of 301 Old 10-11-2011, 08:26 PM Thread Starter
andrewmacc
Haven't done much Jeep stuff this week.
Pulled out the exhaust today, I also zipdisc'd off some of the inner pinch seam of the frame rail so I can weld on some inner frame plating. Mocking up the crossmember, trying to get the right size for the box tubing, and the positioning for the tranny mount.
I'll have to reroute my exhaust. If need be I can always notch the crossmember and plate the area.
Just taking a break.. someone once said "it's easy to cut steel, but it's not as easy for it to grow back", so I've been taking pieces off it so I don't have too much of a gap.
Obviously this is just with it sitting there, it will be flush with the frame rails.
post #50 of 301 Old 10-13-2011, 06:12 PM
1stblack97ZJ
lookin good man!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #51 of 301 Old 10-14-2011, 03:24 AM Thread Starter
andrewmacc
Making the crossmember. Just trying to get measurements correct before I weld anything in. I have a "play" space of a couple inches, so I should have no excuse for messing up.
Exhaust will certainly be interesting, though.. :\
And looky! Real HIDs, not the fake crap, so I won't be blinding anyone:
post #52 of 301 Old 10-14-2011, 03:45 PM Thread Starter
andrewmacc
These guys are huge:
6 1.25" heims, axle side control arm, 10* link tower, frameside lower link, and frameside 10* upper link bracket.
Ready for the disc brake swap. I just need hard and soft lines.
post #53 of 301 Old 10-14-2011, 03:55 PM
jkl
Ruff Stuff?
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #54 of 301 Old 10-14-2011, 04:09 PM
Bama_WJ
Everything is looking nice!
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #55 of 301 Old 10-14-2011, 06:42 PM Thread Starter
andrewmacc
Originally Posted by jkl View Post
Ruff Stuff?
You bet.
Great products, good deals, great service, and fast shipping.
Thankya! Now that I'm more or less done accumulating parts, it should be all progress pics from now on.
post #56 of 301 Old 10-17-2011, 09:18 PM Thread Starter
andrewmacc
Just slapped the hubs on the rotors. Still have to bolt up the bracket and caliper, and then obviously brake lines.
Was tacking up the frame stiffeners, but I made a boo boo. So off it comes, and I'll have to reclean the metal. I got nervous with the sheet metal and I had the welder set way, way, way low. So now the metal is dirty from my bird crap tack, so out comes the grinder tomorrow.
You may notice that I drilled holes for plug welds, but didn't do any in the area by the crossmember.
Well, I will have to be drilling three 1-3/8" holes into that spot (for the 1" OD sleeves) for the crossmember bolts to bolt all the way through the frame channel... so I didn't exactly want to mess up and have a hole an inch away from where I needed a bigger hole. :\
However, that means I'm really not excited to drill such a big hole all the way through: the 3/16" stiffener, the frame, and the 1/8" inner plating. I don't even know how I'm going to accomplish that.
post #57 of 301 Old 10-20-2011, 09:46 AM Thread Starter
andrewmacc
So the PO is a freaking idiot.
That's the "hole" that's made on the inside of the frame rail for the dumb Crusty's inner frame reinforcement to slide through the rail. AT MOST, that hole should be an inch... ROUND. Likely it's only supposed to be 5/8". Instead, I can fit an entire 2x2 piece of square tube if I knock off the "slag"/drooped metal from the sloppy torch work.
I knew about this earlier, obviously, when I took the long arms off, but it didn't hit me til now that it's going to affect my work. So now I have to cut it up, slam some tube in there, weld it up, and try to get my crossmember mounting holes away from those FOUR freaking gaping holes.
So the plan is:
3 of the holes are of the approximate size for some 2" OD HREW tube, so I will drill all the way through, slide it in, weld it up, grind it flush, THEN weld on all the frame plating. The other 1 hole, as pictured, is a friggin' square, so I'll clean it up and ram some 2"x2" square tube in there and do the same.
Of course, one of these holes is directly in the way of where I want one of the new crossmember's mounting holes. Agh.
post #58 of 301 Old 10-20-2011, 02:35 PM
justanotherjpr
Looks painful. If you use a good hole saw and a right angle drill cutting the holes for the sleeves will still stuck but won't be quite as bad.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #59 of 301 Old 10-20-2011, 03:47 PM Thread Starter
andrewmacc
Yeah I'm pretty *******ed frustrated right now.
This is where I'm at. One of them was a good shape for a 2x2 box tube, the others are 2" OD 1/8" wall HREW. Problem is, because of how messed up the holes on the inside were... my plasma cutting got sloppy because I had no idea what I was matching it up to, IMO, where I needed to open the holes. So I didn't really help much.
And of course I tried to put it together with my stick welder, with 1/8 rod at 90 amps, and it just melted the framerail even more, creating like another 1/4" gap at the bottom. I really don't want to upload that picture. I'll get it figured it, I'm not too worried, and it'll be stronger than before. Plus when I fill in the holes, it gets plated inside and out with the frame stiffeners and 1/8" on the inside.
I have 2 friends offering to come down and take a look, they're both pretty handy with a MIG (one of them is the stainless TIG welder, he's been my close friend since I was 4).. so maybe they can pull it off where my SMAW was burning through.
post #60 of 301 Old 10-20-2011, 04:37 PM
86cherokeek20
1986 XJ Cherokee
wow, i seriously need to get back to watchin threads havent been on in a while looks like alot of progress ha been made, LOOKIN GOOD! keeep it up man
yj project cage013 Jeep Builds 5 08-01-2011 12:40 PM
my 3year project became a 6month project gattaca37 Jeep Builds 7 03-21-2011 03:49 PM
Project: Take II TJ zeke6785 Jeep Builds 8 12-19-2010 02:45 PM
74 CJ5 project troybrns Jeep Builds 5 01-02-2010 01:23 PM
My 89 xj project Cory88 Jeep Builds 6 12-13-2009 06:23 PM
